Jan 31, 2007 - 2:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
QUOTE(lagos @ Jan 31, 2007 - 11:53 AM) [snapback]523074[/snapback] doggy... cant you just tune one map for 75-100% throttle and just have emanage interpolate the rest of the corrections? Lagos - tuning for the WOT - its not a problem - cuz you basicly are tuning at only last to rows of the table - but adjusting Cruise mode - its was hard... Cuz driving condition might change instantly - while the same might happen with the boost - so we had to find optimum mode and tune it up... Its still the car runs at about 11.5-12.5 A/F ratio on Wideband, so its on the very safe side... Sometimes while cruising it hits 10 mark so its abit too rich - but atleast it is safe... Aint gonna talk about fuel consumptions... -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Jan 31, 2007 - 2:13 PM
Enthusiast ![]() ![]() Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) |
QUOTE(doGGy @ Jan 31, 2007 - 2:05 PM) [snapback]523077[/snapback] QUOTE(lagos @ Jan 31, 2007 - 11:53 AM) [snapback]523074[/snapback] doggy... cant you just tune one map for 75-100% throttle and just have emanage interpolate the rest of the corrections? Lagos - tuning for the WOT - its not a problem - cuz you basicly are tuning at only last to rows of the table - but adjusting Cruise mode - its was hard... Cuz driving condition might change instantly - while the same might happen with the boost - so we had to find optimum mode and tune it up... Its still the car runs at about 11.5-12.5 A/F ratio on Wideband, so its on the very safe side... Sometimes while cruising it hits 10 mark so its abit too rich - but atleast it is safe... Aint gonna talk about fuel consumptions... What plugs are you using? -------------------- |
Jan 31, 2007 - 2:20 PM
QUOTE(Alan @ Jan 31, 2007 - 12:13 PM) [snapback]523080[/snapback] QUOTE(doGGy @ Jan 31, 2007 - 2:05 PM) [snapback]523077[/snapback] QUOTE(lagos @ Jan 31, 2007 - 11:53 AM) [snapback]523074[/snapback] doggy... cant you just tune one map for 75-100% throttle and just have emanage interpolate the rest of the corrections? Lagos - tuning for the WOT - its not a problem - cuz you basicly are tuning at only last to rows of the table - but adjusting Cruise mode - its was hard... Cuz driving condition might change instantly - while the same might happen with the boost - so we had to find optimum mode and tune it up... Its still the car runs at about 11.5-12.5 A/F ratio on Wideband, so its on the very safe side... Sometimes while cruising it hits 10 mark so its abit too rich - but atleast it is safe... Aint gonna talk about fuel consumptions... What plugs are you using? NGK Iridiom 6 -------------------- Ex celica owner - just a guy from other side of the pond...
Jan 31, 2007 - 2:21 PM
Good, quite Hot! as it is slightly rich This post has been edited by Alan: Jan 31, 2007 - 2:21 PM -------------------- |
Jan 31, 2007 - 2:35 PM
ive never used the emanage, so these are more like retarded questions then they are advice...
but, when you tune for cruise, can you just bump down the injector duty cycle far enough to where you see your o2 sensor start to kick in and let the ecu figure out how to take it to a stoich cruise or idle ? then interpolate from there, to your WOT run to make a smooth transition? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 31, 2007 - 3:26 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
so does the 2 bar map help or does it not really matter as far as using the emanage,
Jan 31, 2007 - 3:45 PM
![]() Enthusiast ![]() ![]() ![]() Joined Nov 25, '04 From Warsaw, Poland Currently Offline Reputation: 1 (100%) |
Well done, Romas. Numbers are impressive. Can't wait for pics and dyno charts, but even more for Martin to come to me and show me "The Beast".
-------------------- '94 ST202 - tuned, highly apprieciated, but sold.
'99 ST205 - imported, legalized, Stage 1 completed. For slow driving: Yamaha XVS650 Drag Star. The most recent addition to the family and for the family: Toyota RAV4 2.0 VVTi Celica-Club Poland - Everything you want to know about your favourite car ... in Polish |
Jan 31, 2007 - 6:37 PM
QUOTE(doGGy @ Jan 31, 2007 - 1:44 PM) [snapback]523073[/snapback] I let the numbers speak for me High Boost mode (0.9 bar) 206hp / 296Nm Low Boost mode (0.5 bar) 176hm / 225 Nm At 0.9 bar - its imposible to handle it - first of all - wheels spin is crazy (on 14" winter tires - you can imagine Now - everything is finally finished - tomorow will be positing Pics and Dyno Sheets... BTW - martin is on the way here already nice job romas. hell if the emanage blue can only do fuel correction based on TPS, its not very good for tuning for boost. with the EM ultimate, you can choose which signal its based off. you can use the map voltage, boost pressure, or TPS. -------------------- Former Team 5SFTE pro member ;)
Feb 2, 2007 - 12:40 AM
Oook Here are the final pics of the enine bay and some goodies. Its 7.30am in the morning and after 1 hour im gonna drive to pic up Martin from other city and drive back here for him to see his car and start his journey back home
As for now - enjoy: ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Feb 2, 2007 - 12:54 AM
Looks great Romas, my hat is off to you.
you know the first thing Martin is gonna do is paint that valve cover red... how's the tune for daily driving ? get that sorted out ? -------------------- |
Feb 2, 2007 - 1:08 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) |
that is teh sex. major kudos to you mr romas. hands down the best 7afte i've seen. martin's one lucky guy. you should get a video of his reaction when he sees it and post it here.
Feb 2, 2007 - 1:23 AM
QUOTE(Batman722 @ Feb 1, 2007 - 10:54 PM) [snapback]523344[/snapback] Looks great Romas, my hat is off to you. you know the first thing Martin is gonna do is paint that valve cover red... how's the tune for daily driving ? get that sorted out ? Thanks Dustin -------------------- Ex celica owner - just a guy from other side of the pond...
Feb 2, 2007 - 2:53 AM
Enthusiast ![]() ![]() ![]() Joined Apr 17, '06 From under your bed. Currently Offline Reputation: 4 (100%) |
Nice Romas! Good work. I'm surprised that you've been able to boost 12.5. I was always thinking you could only hit that much with a fully built 7AFE.
Feb 2, 2007 - 3:57 AM
The beauty and the beast.
Well, you guys can expect more pics from my planned meeting with Martin on his way home. -------------------- '94 ST202 - tuned, highly apprieciated, but sold.
Feb 2, 2007 - 4:34 AM
QUOTE(TomPoz @ Feb 2, 2007 - 1:57 AM) [snapback]523385[/snapback] The beauty and the beast. Well, you guys can expect more pics from my planned meeting with Martin on his way home. Martin is already on the way to ya Tom I will be waiting for the pics and responses from your side once he gets to ya -------------------- Ex celica owner - just a guy from other side of the pond...
Feb 2, 2007 - 10:06 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
QUOTE(ExSane @ Feb 2, 2007 - 1:53 AM) [snapback]523376[/snapback] Nice Romas! Good work. I'm surprised that you've been able to boost 12.5. I was always thinking you could only hit that much with a fully built 7AFE. The people who never even had experience with a turbo 7A started that silly rumor. I've boosted 15 PSI untuned many times and the engine is as good as it ever was. Compression is still 220-220-215-220. -------------------- |
Feb 2, 2007 - 10:17 AM
Enthusiast ![]() ![]() Joined Mar 25, '06 Currently Offline Reputation: 0 (0%) |
sorry if im OT a bit here, but is 220 the best possible compression for the 7aFE ? Also, if someone has extra time, could you tell me or direct me to a site that tells me approximately how compression numbers are derived ? (Ie. Is it a function of stroke length, volume... what ?) Thanks!
P.s. Doggy, you are inspiring me to turbo -------------------- ----- '94 ST hatch --- Yellow ----- |
Feb 2, 2007 - 3:39 PM
QUOTE(doGGy @ Feb 2, 2007 - 4:34 AM) [snapback]523387[/snapback] Martin is already on the way to ya Tom I will be waiting for the pics and responses from your side once he gets to ya So Martin arrived few hours ago. I saw the beauties (Martin's GF and Celica -------------------- '94 ST202 - tuned, highly apprieciated, but sold.
Feb 2, 2007 - 9:30 PM
QUOTE(OOBE @ Feb 2, 2007 - 10:06 AM) [snapback]523416[/snapback] QUOTE(ExSane @ Feb 2, 2007 - 1:53 AM) [snapback]523376[/snapback] Nice Romas! Good work. I'm surprised that you've been able to boost 12.5. I was always thinking you could only hit that much with a fully built 7AFE. The people who never even had experience with a turbo 7A started that silly rumor. I've boosted 15 PSI untuned many times and the engine is as good as it ever was. Compression is still 220-220-215-220. yeah i hit 17psi a few times ,the motor loves the boost -------------------- ![]() |
Feb 2, 2007 - 10:12 PM
does the 7afe have a knock sensor?
| Lo-Fi Version | Time is now: August 29th, 2026 - 12:57 AM |
