Jan 13, 2007 - 1:58 PM
Enthusiast ![]() ![]() Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) |
To all 3SGTE swappers
Does any one have the same problem, if yes what can we do? This post has been edited by Alan: Jan 13, 2007 - 2:30 PM -------------------- |
Jan 13, 2007 - 2:11 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Stiff as in the shifter wont go easy into the gears?
-------------------- JDM Powerplant installed, BPU coming very soon!
QUOTE(Kadett @ Jan 13, 2007 - 2:11 PM) [snapback]517617[/snapback] Stiff as in the shifter wont go easy into the gears? Yeap its like when the clutch is not disengaging with the flywheel -------------------- |
Jan 13, 2007 - 2:49 PM
Maybe your clutch cilinder (if the is the correct translated word) is leaking/broken. Happened to a fellow member here in holland. Had to really pump the clutch quick a few times before it disengaged. Replaced it and all good.
Jan 13, 2007 - 2:53 PM
QUOTE(Kadett @ Jan 13, 2007 - 2:49 PM) [snapback]517622[/snapback] Maybe your clutch cilinder (if the is the correct translated word) is leaking/broken. Happened to a fellow member here in holland. Had to really pump the clutch quick a few times before it disengaged. Replaced it and all good. Thats my problem because my slave is 100% good no leaks, it is bleeded and still hard to shift, I finished the engine yesterday, and tryed it out today for the first time and I need fast response to shift, it 300BHP and seconed never goes in easyly,i dont want to break the gear box. I have a feeling that the clutch isnt disengaging 100%, I will try and elongate the shaft of the slave, What you think? This post has been edited by Alan: Jan 13, 2007 - 2:53 PM -------------------- |
Jan 13, 2007 - 3:17 PM
Problem with the release bearing?!
Jan 13, 2007 - 3:20 PM
Everything is new including clutch and pressure plate fork and realese bearing, i thing its the throw of the slave, still not 100% though :@
This post has been edited by Alan: Jan 13, 2007 - 3:22 PM -------------------- |
Jan 13, 2007 - 3:29 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jun 7, '05 From Corvallis, OR Currently Offline Reputation: 0 (0%) |
Might be the flywheel bearing. I doubt this is the problem, but it could be. I replaced my friends clutch last summer, and when putting the transmission back on, the shaft wasn't allinged perfect, so when we bolted it down it cracked and screwed up the bearing. It caused the clutch to not be able to engage. I doubt that's your problem, but it could be.
Jan 13, 2007 - 3:34 PM
QUOTE(tin_foil @ Jan 13, 2007 - 3:29 PM) [snapback]517634[/snapback] Might be the flywheel bearing. I doubt this is the problem, but it could be. I replaced my friends clutch last summer, and when putting the transmission back on, the shaft wasn't allinged perfect, so when we bolted it down it cracked and screwed up the bearing. It caused the clutch to not be able to engage. I doubt that's your problem, but it could be. Flywheel has no bearing, the bearing is connected to the crankshaft, As I said I drove it today to its full power Any more ideas ??? This post has been edited by Alan: Jan 13, 2007 - 3:35 PM -------------------- |
Jan 13, 2007 - 3:40 PM
Enthusiast ![]() Joined Sep 2, '05 From delaware Currently Offline Reputation: 0 (0%) |
have you checked the clutch master cylinder push rod gap? because if it isnt set right it wont allow the pressure plate to engage and disengage properly.
Jan 14, 2007 - 2:51 AM
QUOTE(1994toyotaracer @ Jan 13, 2007 - 3:40 PM) [snapback]517636[/snapback] have you checked the clutch master cylinder push rod gap? because if it isnt set right it wont allow the pressure plate to engage and disengage properly. As the clutch system is fluid base not with any linkages, all the clearances are taken, In fact as i touch the clutch pedal, there is already some movment on the fork of the clutch. Good suggestion but not the case :s This Is a real problem specially for quater mile Any other suggestion please this is really important!!! -------------------- |
Jan 14, 2007 - 3:28 AM
QUOTE(Alan @ Jan 13, 2007 - 3:34 PM) [snapback]517635[/snapback] QUOTE(tin_foil @ Jan 13, 2007 - 3:29 PM) [snapback]517634[/snapback] Might be the flywheel bearing. I doubt this is the problem, but it could be. I replaced my friends clutch last summer, and when putting the transmission back on, the shaft wasn't allinged perfect, so when we bolted it down it cracked and screwed up the bearing. It caused the clutch to not be able to engage. I doubt that's your problem, but it could be. Flywheel has no bearing, the bearing is connected to the crankshaft, As I said I drove it today to its full power Any more ideas ??? Good to know. I've never dug into a 3s tranny. My problem happened on my friends 94 teg. I know this is stupid, but you do have tranny oil in it, right? -------------------- ![]() |
Jan 14, 2007 - 3:30 AM
QUOTE(tin_foil @ Jan 14, 2007 - 3:28 AM) [snapback]517712[/snapback] QUOTE(Alan @ Jan 13, 2007 - 3:34 PM) [snapback]517635[/snapback] QUOTE(tin_foil @ Jan 13, 2007 - 3:29 PM) [snapback]517634[/snapback] Might be the flywheel bearing. I doubt this is the problem, but it could be. I replaced my friends clutch last summer, and when putting the transmission back on, the shaft wasn't allinged perfect, so when we bolted it down it cracked and screwed up the bearing. It caused the clutch to not be able to engage. I doubt that's your problem, but it could be. Flywheel has no bearing, the bearing is connected to the crankshaft, As I said I drove it today to its full power Any more ideas ??? Good to know. I've never dug into a 3s tranny. My problem happened on my friends 94 teg. I know this is stupid, but you do have tranny oil in it, right? This post has been edited by Alan: Jan 14, 2007 - 3:31 AM -------------------- |
Jan 14, 2007 - 1:16 PM
Nobody can help no more suggestions?
| Lo-Fi Version | Time is now: June 13th, 2026 - 2:52 AM |
