> Brembo front rotors installation, how to...
post Feb 19, 2007 - 4:06 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
I have decided change my brake rotor to better ones and here is my story biggrin.gif
not cheapest but reasonable price for "plug-and-play" part.
2. removing wheel
nice to have tools...
- usual tools for wheel take off
- something for stubborn screws (like WD-40)
- hammer (handy every time biggrin.gif)
- wrench 17 and 14
3. removing caliper
by those two screws remove caliper away...
...by two wrenches (like picture below showing... one for holding, and second for un-screwing... sorry I can't describe that better kindasad.gif)
4. removing brake pads and caliper mounting
remove pads is easy, that hardest part are caliper mountings held by two screws...
those two bolts were rusted and stubborn unbelievably!!! W/o WD-40... (and hammer help sometimes) it could not be done... my car almost fell off the lifting jack during that kindasad.gif.
5. removing rotor
nothing but rust holds that disc -> just gently knock on and it fell off...
you can see all that rust (after hammer work smile.gif) and really bad condition of inner part of rotor.
6. just make it look good and re-assemble everything...
now it's done... just put everything back on (plus in my case use some direct-to-rust-metal-paint for rusted parts).
note: you maybe would need push back caliper piston if new rotor is wider or you change brake pads (recommended) by some pliers like this:
(I don't know how you call that)
plus:
QUOTE(azian_advanced @ Feb 19, 2007 - 4:42 PM) [snapback]528279[/snapback]
...just as a tip, lubricate the inside of the pistons inside the rubber seal.
And results you can see below smile.gif:
This post has been edited by malpaso: Feb 20, 2007 - 1:56 AM
- malpaso   Brembo front rotors installation   Feb 19, 2007 - 4:06 AM
- - Slick   Nice! What made you go with these rotors r...   Feb 19, 2007 - 6:29 AM
|- - malpaso   QUOTE(Slick @ Feb 19, 2007 - 12:29 P...   Feb 19, 2007 - 6:38 AM
|- - Slick   QUOTE(malpaso @ Feb 19, 2007 - 1:38 ...   Feb 19, 2007 - 7:37 AM
- - 6strngs   ah, you beat me to it. I was gonna do a write up w...   Feb 19, 2007 - 7:25 AM
|- - azian_advanced   QUOTE(6strngs @ Feb 19, 2007 - 6:25 ...   Feb 19, 2007 - 10:42 AM
|- - malpaso   QUOTE(6strngs @ Feb 19, 2007 - 1:25 ...   Feb 20, 2007 - 1:54 AM
- - DeW_H0e_GT   vote for sticky!!!!!!   Feb 20, 2007 - 11:18 PM
- - hurley97   looks good. I want to know how you like those ...   Feb 20, 2007 - 11:26 PM
|- - malpaso   QUOTE(hurley97 @ Feb 21, 2007 - 5:26...   Feb 21, 2007 - 5:00 AM
- - wind   i hope you replaced the brake pads as well....   Feb 21, 2007 - 3:16 PM
- - trdcelica94   how much did those brembo cost at the dealer?   Feb 22, 2007 - 3:26 PM
- - Rockford   Malpaso what kind of brake pads do you buy??? for ...   Mar 10, 2007 - 8:06 PM
|- - malpaso   QUOTE(Rockford @ Mar 11, 2007 - 2:06...   Mar 11, 2007 - 3:23 AM
|- - 6strngs   QUOTE(Rockford @ Mar 10, 2007 - 5:06...   Mar 12, 2007 - 1:52 AM
|- - Rockford   QUOTE(6strngs @ Mar 12, 2007 - 2:52 ...   Mar 20, 2007 - 12:19 AM
|- - 6strngs   QUOTE(Rockford @ Mar 19, 2007 - 10:1...   Mar 20, 2007 - 1:17 AM
|- - malpaso   QUOTE(6strngs @ Mar 20, 2007 - 7:17 ...   Mar 20, 2007 - 2:09 AM
- - 6strngs   I did my front and rears today. sorry, I didn...   Mar 11, 2007 - 1:57 AM
- - TomPoz   Good write-up, Martin. I will use it when putting ...   Mar 11, 2007 - 4:24 AM
- - Alan   Nice Martin. Did you Do it alone? Nice one man   Mar 11, 2007 - 5:25 AM
|- - malpaso   QUOTE(Alan @ Mar 11, 2007 - 11:25 AM...   Mar 12, 2007 - 1:46 AM
- - kamax   thanks for the write up... was so easy, i decided ...   Mar 18, 2007 - 11:32 PM
- - beno   Is there any noise from the slotted rotors? How mu...   Mar 21, 2007 - 10:56 PM
|- - malpaso   QUOTE(beno @ Mar 22, 2007 - 4:56 AM)...   Mar 22, 2007 - 2:22 AM
- - 6strngs   braking is better, though that may be due to the h...   Mar 22, 2007 - 9:57 AM
Lo-Fi Version Time is now: August 11th, 2026 - 8:27 PM
