Feb 24, 2007 - 2:19 AM
Enthusiast ![]() ![]() ![]() Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
Sneak peak.. this is the new rotor.. that is a 16" 7th gen rim.
![]() Stock Rotor w/ rim installed Stock GT Rotor no rim New rotor no rim Probably be 2 versions of the brake kit. One would be a 318mm rotor designed for use on 16" or larger rims. The other would be a 323mm rotor which will only fit 17" or larger rims. Both using the same 4 pot caliper. Personally I'll be using 318mm rotor.. The price difference between the two will be pretty small.. The 318mm kit will actually be the more expensive one.. between 30-40 dollars more. Btw, these are camera phone pictures... I never thought I'd see the day when cam phone pics looked this good... -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Feb 24, 2007 - 3:42 AM
your going to need some big rims to clear the rotors/calipers
Feb 24, 2007 - 4:43 AM
Enthusiast Joined Feb 14, '07 From UK Currently Offline Reputation: 0 (0%) |
nice one! very similar to mine, excuse the tatty wheel
![]() these are 324 mm with 18 inch wheel |
Feb 24, 2007 - 1:11 PM
QUOTE(lagos @ Feb 24, 2007 - 3:42 AM) [snapback]529867[/snapback] your going to need some big rims to clear the rotors/calipers Hence the reason for 2 kits.. the 318mm kit will clear a 16" rim. I don't want people to have to upgrade to a 17 or larger if they already have 16's... -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Feb 24, 2007 - 3:14 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
very interesting.. lets see the calipers
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Feb 24, 2007 - 3:48 PM
QUOTE(celicast3sgte @ Feb 24, 2007 - 3:14 PM) [snapback]529952[/snapback] very interesting.. lets see the calipers soon. -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Feb 25, 2007 - 3:04 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
how much is a kit?
Feb 27, 2007 - 11:31 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
like I said in the other thread... if you guys need an ST to test fit the GT setup and see if it works for both let me know, I'm in the area and Corey has my number
Feb 27, 2007 - 8:08 PM
QUOTE(hurley97 @ Feb 27, 2007 - 11:31 AM) [snapback]530847[/snapback] like I said in the other thread... if you guys need an ST to test fit the GT setup and see if it works for both let me know, I'm in the area and Corey has my number Yes, Corey told me all about you..... -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Mar 6, 2007 - 10:49 AM
QUOTE(Punisher @ Feb 27, 2007 - 8:08 PM) [snapback]531027[/snapback] QUOTE(hurley97 @ Feb 27, 2007 - 11:31 AM) [snapback]530847[/snapback] like I said in the other thread... if you guys need an ST to test fit the GT setup and see if it works for both let me know, I'm in the area and Corey has my number Yes, Corey told me all about you..... oh geez... good things I hope -------------------- |
Mar 8, 2007 - 10:21 PM
Enthusiast ![]() ![]() Joined Jan 5, '05 From Upper Darby, PA(5 min away from Philly) Currently Offline Reputation: 3 (100%) |
So how much is this kit and what does it come with?
Mar 8, 2007 - 11:17 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
nice, im interested... could these come slotted?
Mar 9, 2007 - 12:56 AM
Yes, they could come slotted. Not certain about price yet, I want to keep it around a grand though...
Just from my testing so far... most people unless you have an offset of probably around +30 to +25... are going to need to use a rim spacer to fit these calipers. With my 7th gen rims, I can fit the smaller brake kit if I use a 15mm spacer.. I'll be making and selling spacers to go along with the kits.. using ARP wheel studs.. The spacers will be hubcentric. This post has been edited by Punisher: Mar 9, 2007 - 1:05 AM -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Mar 23, 2007 - 11:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
update?
Apr 9, 2007 - 12:26 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Are those ST205 brake rotors?
-------------------- JDM Powerplant installed, BPU coming very soon!
Apr 14, 2007 - 7:04 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
any updates
Jul 22, 2007 - 2:07 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
we need updates
Jul 22, 2007 - 9:36 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 28, '03 From Bloomington, IN Currently Offline Reputation: 0 (0%) |
Not to destory your sales, but no one one this forum actually needs a big brake kit. It's mostly a fashion statement unless you're roas coursing all the time. A lot of these guy could get by great with a SS lines, a Hawk/EBC pad, fresh rotors and some nice fuild. That would be perfect for the daily driver and weekend autocrosser.
It worked out great on my old 6gc, paired with the Eagle F1 gsd3's. For only about $300 or less, I saved my car from many a deer -------------------- NASA/SCCA RX-7....currently under the knife
92 Civic hatch B16 - Sold 10th anniv RX-7 - RIP The Slow Celica - Sold...and then crushed crushed due to street racing. Quote from Seinfeild: George's Boss reading a magazine: "People magazine's most beautiful people. Oh and a Celica...nothin wrong with that!" |
Jul 22, 2007 - 10:21 PM
QUOTE(SlowCelica94 @ Jul 22, 2007 - 10:36 PM) [snapback]581301[/snapback] Not to destory your sales, but no one one this forum actually needs a big brake kit. It's mostly a fashion statement unless you're roas coursing all the time. A lot of these guy could get by great with a SS lines, a Hawk/EBC pad, fresh rotors and some nice fuild. That would be perfect for the daily driver and weekend autocrosser. It worked out great on my old 6gc, paired with the Eagle F1 gsd3's. For only about $300 or less, I saved my car from many a deer i can think of a few guys on here that do need big brakes. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 22, 2007 - 11:07 PM
^i doubt SERIOUSLY doubt that anyone on this forum will make good use of a Big brake kit...except for show reasons....
a "BBK" will NOT help braking on the street or on a drag strip. (having a 3s doesn't constitute the need either) This post has been edited by playr158: Jul 22, 2007 - 11:08 PM |
| Lo-Fi Version | Time is now: September 13th, 2026 - 1:35 PM |
