> WTB: EGR!, COMPLETE! thread may be closed now
post Mar 3, 2007 - 5:19 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I need the EGR valve (and any other EGR part you can spare) from a pre-96 GT with a manual transmission that is also california spec (can be celica, camry, mr2, etc. just needs to be for 5sfe). I know that that's kinda specific but it needs to be. A brand new one from a dealership will cost $118 just for the valve itself and I'm not 100% sure that that's my problem. if you have spare EGR parts I'll take what you have (valve, sensor, tubing, etc.) thanks
This post has been edited by 6strngs: Mar 9, 2007 - 10:10 PM
Replies (1 - 7)
post Mar 4, 2007 - 7:36 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Pm'd
post Mar 5, 2007 - 8:27 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
PM me I have a EGR valve, sensor, from a 7afe. Advanced auto parts website shows same p/n for both 1.8 and 2.2.
post Mar 5, 2007 - 10:20 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I've already bought the EGR parts from toyotacrazy. Thanks though
post Mar 8, 2007 - 10:10 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
I know you probably already got this figured out but you had PMed Dustin and he said I would check at work to make sure you could use the one you bought...
there is no difference between Cali and non-Cali spec EGR valves, and we would use the same part for 94 as for 95 (and as you already know a different one for 96-99) so with what you bought should be perfectly fine. smile.gif
I <3 Dustin---07/16/06
post Mar 9, 2007 - 12:07 AM
6strngs
Joined May 12, '06
From Wilmington, NC
thank you! I recieved the new EGR today. hopefully putting in on tomorrow and then hopefully no more check engine light!
post Mar 9, 2007 - 7:42 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(6strngs @ Mar 9, 2007 - 12:07 AM) [snapback]534507[/snapback]
cool, let me know how it works out for you.
post Mar 9, 2007 - 10:09 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(toyotacrazy @ Mar 9, 2007 - 4:42 PM) [snapback]534847[/snapback]
I've pulled the EGR off and put it back on enough times now trying to fix my problem that I was able to get this new one on in about 10 minutes. it seems to have fixed my problem! Thank you!
this thread may now be closed.
Lo-Fi Version Time is now: July 6th, 2026 - 2:48 AM
