> Turboing a 7A-FE, all the parts and procedure
post May 16, 2007 - 9:49 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
ok im thinking of turboing my 7A-FE in about a or so.All the parts and prices are here:
Turbo=$300, header=$150 intercooler & piping & BOV=$275, oil return=$85 oil feed lines =$85 fuel pump=$100, FPR=$30-50 boost gauge=$40 boost controller=$25 check vavles = $10 misc. vac. hoses =$5-10$
Is all this correct?Feel feel to edit prices or what not,any info on how to install the turbo and other parts will be appreciated!!
EDIT:whats the gas milage of a 7A-FTE?
This post has been edited by CelicaST_CALI: Jun 28, 2007 - 4:52 PM
BANNED. for life, you moron.
Replies (1 - 19)
post May 16, 2007 - 9:55 PM
Shocker
Joined Mar 23, '06
From Nashville Tennessee
you will want somthing to keep your oil in check..Such as gauges..
post May 16, 2007 - 10:26 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
QUOTE(CelicaST_CALI @ May 16, 2007 - 7:49 PM) [snapback]558670[/snapback]
[b]turbo-350-500, header 150-250, IC/piping/bov 400, oil return/feed/restrictor 100$, fuel pump 100-150, fpr 50-120, boost gauge 40ish, controller 45-80, misc 700, safc2 250???
thats getting you closer
This post has been edited by celicast3sgte: May 16, 2007 - 10:29 PM
post May 16, 2007 - 11:16 PM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
yea total ive spent like 3000 and im still addn stuff as i go
BOOST GETS YOU LAID!!!!
post May 17, 2007 - 11:37 AM
6strngs
Joined May 12, '06
From Wilmington, NC
not quite.
manifold $200 (might have to be custom made)
turbo $500 minimum! (depends on which one) unless you can find a way to use the stock turbo from another car. like the way the honda guys use mitsubishi eclipse GST turbos, or I'm going to use a CT-26 from an mr2 turbo
downpipe $250
intercooler, piping, couplers, clamps $500-750
BOV $175
oil return $75
oil feed $50
fuel pump $120
FPR ?
boost gauge $50-200
oil pressure gauge $50-200
gauge pod $50+
boost controller $50-300
Air fuel controller $250-600
custom exhaust $300-500 + muffler
I'm not as familiar with the 7afte but those are your basic parts. I'm not sure if you need bigger injectors or not. plus you'll need to have it tuned on a dyno so add like $150-300 for that.
but seriously, don't ask us to give you the ENTIRE parts list. You're going to have read and research for months. you really need to understand what everything does. The turbo is not a simple project, and you don't even have your license yet. seriously, wait until you have the car, then do simple things like changing the oil and replacing spark plugs while you read and research and maybe you'll be ready to delve into a turbo project in several months.
post May 17, 2007 - 12:22 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
yea ive been looking at all th parts and researchering and just about ever price 6strngs put up is way over what it really is.But thx for the help!And i have really already been reseaching WHat the turbo does,psi,etc.I have a feeling im just going to buy all the parts over a year..
This post has been edited by CelicaST_CALI: May 17, 2007 - 12:26 PM
post May 17, 2007 - 12:45 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(CelicaST_CALI @ May 17, 2007 - 10:22 AM) [snapback]558891[/snapback]
my prices are pretty close to reality. except maybe the turbo and manifold. but, I think you need to have a custom manifold made, and if you're buying like a T3/T4 it'll cost like $500-1000 (i'm not really sure). If you think you can get these parts for cheaper, then go right ahead. but I paid close to these prices for my parts and I shopped around for the best deals I could find.
post May 17, 2007 - 12:51 PM
aslearvert
Joined Aug 15, '06
From MICHIGAN
What about injectors? Did someone already say that? Are they needed?
Whoops sorry I see someone already put that.
This post has been edited by aslearvert: May 17, 2007 - 12:53 PM
post May 17, 2007 - 12:57 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
Yea i think im going to go with the T-3.Ebay has a few right now under 500$.But as i said im going to wait around a year before i start building,ill just buy the parts one at a time and get the best deals.
post May 17, 2007 - 5:44 PM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
Ive been getting all the parts for a 7AFTE setup in the past few months and heres what ive come up with for the cost of doing it and where i got the parts from:
$110 - Intercooler Piping Kit with T-Bolt clamps (Ebay)
$125 - Greddy BOV (Ebay)
$160 - Gauges (AFR, electrical Boost, Oil Pressure) (DEFTRacing)
$50 - Oil feed line (Ebay)
$80 - Oil drain line (Ebay)
$35 - Oil catch can (Ebay)
$52 - Gauge Pod (Lotek 3-gauge) (Lotek's site)
$85 - MR2 MAP sensor (MR2OC)
$35 - Silicone Tee Hose for BOV (Ebay)
$270 - SAFC2 (Ebay)
$360 - Turbo from a Subaru Legacy (IHI RHB5), Manifold, FMU, 250cc 4AGE injectors, INNOVATE LC-1 Wideband O2 Sensor, Manual Boost Controller (all from a 6GC member)
$50 - OEM Supra intercooler, and 440CC 7MGTE Injectors (a local buddy)
$300 - 2.5" exhaust with a custom made flange
Total
$1712 + some time to put it all in and without tuning
with tuning it will probably be over 2k depending on how much the fees are for dyno time
feel free to PM me if you have any questions about this
-Brian
post May 17, 2007 - 8:22 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Celiracer18 @ May 17, 2007 - 3:44 PM) [snapback]558998[/snapback]
$270 - SAFC2 (Ebay)
Total
you have a manifold or a downpipe? fuel pump?
post May 17, 2007 - 8:47 PM
trd94
Joined Jan 9, '05
From green springs ohio
it really depends on how long you want it to run and last with some of the ebay stuff ,some of it is ok and you could find good deals on name brand stuff . i built my celica on a budget and got the cheap ebay knock offs and ended up buying the good stuff a month or so later and so far tuning it has cost a bit . but i am always after more.... haha
post May 17, 2007 - 8:57 PM
95st-celica
Joined Mar 29, '07
From Philly
QUOTE(CelicaST_CALI @ May 16, 2007 - 10:49 PM) [snapback]558670[/snapback]
funny you should start this post because i was seriously thinkin about doin the same thing to mine....if you do do it let me know how it works out for you...n check this out:
http://www.6gc.net/howto/turbocharge_your_7afe
1988 Dodge Aries K (sold)
post May 17, 2007 - 9:57 PM
trdcelica94
Joined Apr 29, '03
From socal
know way you can get a boost controller for $25 its like $400-$600 depending on which one your are buying
post May 17, 2007 - 10:05 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
cheap turbo project = blown motor.
Save money, and do it right. U get what u pay for. yes there are some places that you can get a "deal" but some u just have to bite the bullet, and drop the dough to get something that is going to perform.
Kawi Love
post May 18, 2007 - 4:05 PM
Celiracer18
Joined Aug 23, '05
QUOTE(6strngs @ May 17, 2007 - 8:22 PM) [snapback]559058[/snapback]
$270 - SAFC2 (Ebay)
$360 - Turbo from a Subaru Legacy (IHI RHB5), Manifold, FMU, 250cc 4AGE injectors, INNOVATE LC-1 Wideband O2 Sensor, Manual Boost Controller (all from a 6GC member) Fuel Pump
$300 - 2.5" exhaust with a custom made flange including a Downpipe
Total
I included the manifold in there somewhere, the fuel pump i forgot but it was included with the turbo and manifold. Downpipes for IHI RHBs are few and far between so a custom one is being made with the rest of the exhaust
-Brian
post May 18, 2007 - 4:15 PM
manphibian
Joined Oct 13, '06
From UK
How would someone your age get insurance on such a highly modified car?
Either insurance policies are VERY different over there or you'll be doing it illegally and not declaring?!
post May 18, 2007 - 4:27 PM
Ebay generic turbos are crap and will break quick...waste of money
MBC = 30$ EBC = 200+
post May 18, 2007 - 4:35 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Since when do you tell your insurance that you've turboed your NA car? lol.
post May 18, 2007 - 4:37 PM
DSToyo
Joined Dec 16, '06
From Maryland
^ yeah, all they need to know is what year/type of car you have, right.
This post has been edited by DSToyo: May 18, 2007 - 4:37 PM
Lo-Fi Version Time is now: September 12th, 2026 - 10:55 PM
