> safc wtf!!
post May 22, 2007 - 11:07 AM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
tryn to wire this thing in and yea i dont think the how to is right....i wired the whole thing up and it didnt even come on! so i went to every wire to find the ig power wire and i found that but idk if i wanna try to start the car because the other wires may be hooked up wrong thanks to that how to. can somone send me the correct wiring diagram
BOOST GETS YOU LAID!!!!
post May 23, 2007 - 8:16 AM
jesterwr217
Joined Feb 27, '07
hmmm its funy how alot! of ppl have this installed on their cars here but noone is willing to help.......
post May 23, 2007 - 8:22 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Here is the engine control schematic for your 95 ST:
http://www.celicatech.com/vfewdsou/1995/95...ic/engcon7a.pdf
This should be all you need.
post May 23, 2007 - 11:34 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(jesterwr217 @ May 22, 2007 - 9:07 AM) [snapback]560420[/snapback]
that's cause the how to is how to install it on a GT! the GT and ST probably have different ECU's, and thus, different pin-outs. ask hurley97 or Dr_Tweak if they have the pinout for the ST.
post May 23, 2007 - 11:51 AM
jesterwr217
Joined Feb 27, '07
QUOTE(WannabeGT4 @ May 23, 2007 - 9:22 AM) [snapback]560806[/snapback]
you would not believe how much this helped just by looking at it haha it kinda matches up with the how to but they counted backwards when naming the ecu pinouts. im gona give it a try tomorrow before work and we'll see what happens but im still not too sure on the ig power...
post May 23, 2007 - 12:06 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
heres my thread on my 97ST http://www.6gc.net/forums/index.php?showtopic=45724&hl=
and presure2's on his 94GT http://www.6gc.net/forums/index.php?showtopic=22175&hl=
IIRC I found the pinouts to be the same but the wire colors were different. you should not go by wire color alone anyway, you need to double check the pinout and connector
I <3 Dustin---07/16/06
post May 23, 2007 - 12:09 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
I was wondering if someone could do a writeup on this and make it a sticky, as this would be some really useful info...i would, but i dont have a 3sgte, lol
(\__/)
post May 24, 2007 - 10:27 AM
jesterwr217
Joined Feb 27, '07
hooked it up and everything works perfect thanks alot guys!!
Lo-Fi Version Time is now: August 23rd, 2026 - 1:37 PM
