May 25, 2007 - 8:54 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
As some of you know, I've been gathering parts together for a 5sfte turbo project which I hope to finish soon. I should have a fairly large sump of money coming in in the next few days which I will use to buy the rest (or as much of the rest as I can) of the parts. Not only that but my parents will be leaving town for about 10 days on monday, leaving me with garage space to work in. The week of june 3rd-10th I will have a weeks paid vacation from work, so I will have plenty of time to work on it then. Anyway, here's what I've got so far:
2 bar map sensor: ![]() 460cc RX7 injectors: ![]() 3sgte oil pan: ![]() 3sgte oil and coolant lines, oil feed line from stealthmodeperformance.com, oil pressure sending unit from tunertoyz (thanks to Dew_Hoe_GT). Earl's -3an to 1/8" NPT fittings. The 3rd fitting on the T near the 3s oil line is plugged; I just needed an adaptor to connect two male threads and stealthmode included the tee. ![]() oil line modified with the -3an threads from an earl's fitting. Welding done by my welding instructor. TIG welding ftw! ![]() 3sgte manifold, with EGT bung that will get plugged (not enough room for EGT gauge on my A-pillar! lol) ![]() intercooler ![]() 2.25" intercooler piping, mr2 BPV on a section of stock mr2 IC piping, about 4 silicone couplers, 1 2.25"-2.50" transition coupler, and 6 or so worm-gear clamps ![]() A'pexi AFC Neo: ![]() Lotek A-pillar pod, and AEM UEGO wideband o2 (hooked up to power, but not to the engine yet), will be filling the other two slots with a boost and oil pressure gauge ![]() And there you have it. For the IC piping, I was told it was 2.5" piping and included couplers and T-bolts... unfortunately, it turned out to be 2.25" piping, only included 4 2.25" couplers, only one 2.25" to 2.50" transition, and a couple worm gear clamps... it also included 3 2.00" couplers and 6 T-bolts which only fit the 2.00" couplers which do me no good... those 3 couplers + t-bolts are up on ebay now to help pay for the other couplers and clamps I need. If anybody has any used 2.25" couplers, 2.25" t-bolt clamps, 2.25-2.50" transistion couplers, or a 45* elbow coupler, let me know! also still needed: Turbo and downpipe (Negative is supposed to get these to me, but he hasn't replied to any PMs from me for 11 days and counting oil filter recolation kit gauges (oil pressure and boost) walbro fuel pump VTV for the mr2 BPV magnaflow muffler (to be mated to a 3" custom exhaust I plan to get) couplers, T-bolts, elbow, and transitions for ic piping if anybody has anything on that list they could sell to me, that would be awesome! So yeah, go ahead and comment away! EDIT: can anybody tell me what size the outlet on the CT-26 twin entry turbo is so I can get the correct sized 45* elbow. I assume it's 2.25" since the section of mr2 IC piping is 2.25" This post has been edited by 6strngs: Aug 3, 2007 - 4:11 PM -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
6strngs It is finally time.... for boost! May 25, 2007 - 8:54 PM
slvr_celica_GT_816 good luck with the build May 25, 2007 - 10:33 PM
Gary Looking good.
The ID of the hose that connects to... May 25, 2007 - 10:42 PM
lagos i think its actually closer to a 2in ... but dont ... May 25, 2007 - 11:12 PM
6strngs if it really is 55mm, then it's 2.16", so... May 25, 2007 - 11:48 PM
presure2 QUOTE(6strngs @ May 26, 2007 - 12:48... May 26, 2007 - 8:11 AM
purepunishment pmed you May 26, 2007 - 6:09 PM
6strngs update... sorta. Ordered the spark plugs and gauge... May 30, 2007 - 11:04 PM
presure2 QUOTE(6strngs @ May 31, 2007 - 12:04... May 31, 2007 - 5:35 AM
Gary QUOTE(presure2 @ May 31, 2007 - 6:35... May 31, 2007 - 7:56 AM
6strngs I recieved my fuel pump and oil filter relocation ... Jun 1, 2007 - 11:59 PM
presure2 youll end up regretting buying the screw on block ... Jun 2, 2007 - 12:04 PM
6strngs QUOTE(presure2 @ Jun 2, 2007 - 10:04... Jun 2, 2007 - 1:06 PM
presure2 QUOTE(6strngs @ Jun 2, 2007 - 2:06 P... Jun 2, 2007 - 1:35 PM
6strngs got my couplers and T-bolt clamps yesterday. but t... Jun 4, 2007 - 3:36 AM
shin i had the same oil filter adapter like you did.. a... Jun 4, 2007 - 10:44 AM
WALKER Is this the Canton adapter?
Second one down 90° R... Jun 4, 2007 - 1:09 PM
presure2 QUOTE(WALKER @ Jun 4, 2007 - 2:09 PM... Jun 4, 2007 - 4:41 PM
jcaron9gt4 why yes it is.....and yea, i bought that same one ... Jun 4, 2007 - 4:26 PM
WALKER QUOTE(jcaron9gt4 @ Jun 4, 2007 - 3:2... Jun 4, 2007 - 4:58 PM
6strngs QUOTE(jcaron9gt4 @ Jun 4, 2007 - 2:2... Jun 4, 2007 - 6:06 PM
DippedInSauce QUOTE(6strngs @ Jun 4, 2007 - 6:06 P... Jun 4, 2007 - 8:45 PM
6strngs QUOTE(DippedInSauce @ Jun 4, 2007 - 6... Jun 4, 2007 - 11:30 PM
jcaron9gt4 it resricts how much oil goes into your turbo. so... Jun 4, 2007 - 5:01 PM
WALKER QUOTE(WALKER @ Jun 4, 2007 - 3:58 PM... Jun 5, 2007 - 12:17 PM
OOBE You'll spend more gas money on getting there. ... Jun 4, 2007 - 11:42 PM
jcaron9gt4 the oil restrictor is 1/8 npt Jun 5, 2007 - 2:11 PM
WALKER QUOTE(jcaron9gt4 @ Jun 5, 2007 - 1:1... Jun 5, 2007 - 2:28 PM
6strngs Reiceved my other gauges and the spark plugs. I... Jun 5, 2007 - 3:38 PM
6strngs Prosport gauges from twosrus.com. I've got the... Jun 5, 2007 - 11:24 PM
DippedInSauce yo nathan, your inbox is full. im trying to get ah... Jun 5, 2007 - 11:26 PM
6strngs Recieved my exhaust manifold gasket, valve cover g... Jun 6, 2007 - 1:33 PM
jcaron9gt4 buy some L brackets from home depot or something a... Jun 6, 2007 - 2:16 PM
6strngs QUOTE(jcaron9gt4 @ Jun 6, 2007 - 12... Jun 6, 2007 - 3:11 PM
laff09 Whats NPT Jun 6, 2007 - 2:26 PM
WALKER QUOTE(laff09 @ Jun 6, 2007 - 1:26 PM... Jun 6, 2007 - 2:31 PM
laff09 QUOTE(WALKER @ Jun 6, 2007 - 2:31 PM... Jun 6, 2007 - 2:34 PM
WALKER QUOTE(6strngs @ Jun 6, 2007 - 2:11 P... Jun 6, 2007 - 4:25 PM
6strngs QUOTE(WALKER @ Jun 6, 2007 - 2:25 PM... Jun 6, 2007 - 10:21 PM
presure2 QUOTE(6strngs @ Jun 6, 2007 - 11:21 ... Jun 7, 2007 - 5:21 AM
6strngs not much of an update but:
gapped the spark plugs ... Jun 7, 2007 - 2:26 AM
6strngs got some properly sized vacuum hose to hook my boo... Jun 9, 2007 - 11:15 PM
6strngs ok, so I recieved the new fuel pump bracket today ... Jun 14, 2007 - 1:45 AM
presure2 QUOTE(6strngs @ Jun 14, 2007 - 2:45 ... Jun 15, 2007 - 5:15 AM
6strngs QUOTE(presure2 @ Jun 15, 2007 - 3:15... Jun 15, 2007 - 8:40 AM
presure2 QUOTE(6strngs @ Jun 15, 2007 - 9:40 ... Jun 15, 2007 - 5:52 PM
95CelicaST There is a guy up here in washington selling a low... Jun 15, 2007 - 6:42 PM
milnersXcoupe Pull off those 'rubber' Oil Lines and inst... Jun 15, 2007 - 7:06 PM
6strngs Wow... I really hate having to buy things twice...... Jun 15, 2007 - 7:37 PM
jcaron9gt4 well you should be fine for a bit without the brai... Jun 15, 2007 - 7:47 PM
6strngs ok, so I finally went out and tried to install the... Jun 15, 2007 - 9:35 PM
NgoFcukinWay if you're still trying to reach negative, i ca... Jun 16, 2007 - 1:00 AM
6strngs Yeah, if you can get in touch with him and tell hi... Jun 16, 2007 - 1:08 AM
NgoFcukinWay QUOTE(6strngs @ Jun 16, 2007 - 1:08 ... Jun 24, 2007 - 11:04 PM
6strngs QUOTE(NgoFcukinWay @ Jun 24, 2007 - 9... Jun 25, 2007 - 12:47 AM
6strngs went and picked up my toyota parts. Here's the... Jun 16, 2007 - 2:37 PM
6strngs Got the other O2 sensor bung welded on for only ... Jun 16, 2007 - 3:48 PM
jcaron9gt4 I also placed the order for the oil restrictor
H... Jun 17, 2007 - 9:13 AM
NuclearHappineS oil pressure should be about 10psi per rpm... the ... Jun 17, 2007 - 9:37 AM
6strngs QUOTE(NuclearHappineS @ Jun 17, 2007 - 7... Jun 17, 2007 - 12:30 PM
CaliJeff what muffler shop did you go to for the modificati... Jun 17, 2007 - 3:51 PM
6strngs QUOTE(CaliJeff @ Jun 17, 2007 - 1:51... Jun 18, 2007 - 12:19 AM
jcaron9gt4 i may be mistaken, but i dont think that the trans... Jun 17, 2007 - 4:41 PM
CaliJeff i don't like 30 min muffler. The Livermore muf... Jun 18, 2007 - 11:46 AM
6strngs yeah, 30 minute muffler wasn't my first choice... Jun 18, 2007 - 1:35 PM
CaliJeff I think i heard good things about them too. I thin... Jun 18, 2007 - 1:52 PM
6strngs alright everybody! big news! I got my oil ... Jun 20, 2007 - 12:54 AM
x_itchy_b_x Sweet, looks like youll be joining the 5sfte club. Jun 20, 2007 - 11:49 AM
6strngs I'm searching all over for a wastegate actuato... Jun 20, 2007 - 3:29 PM
WALKER QUOTE(6strngs @ Jun 20, 2007 - 2:29 ... Jun 20, 2007 - 3:57 PM
6strngs QUOTE(WALKER @ Jun 20, 2007 - 1:57 P... Jun 20, 2007 - 8:19 PM
WALKER QUOTE(6strngs @ Jun 20, 2007 - 7:19 ... Jun 21, 2007 - 11:48 AM
x_itchy_b_x did you already clock the turbo? Jun 20, 2007 - 8:36 PM
6strngs QUOTE(x_itchy_b_x @ Jun 20, 2007 - 6... Jun 20, 2007 - 8:49 PM
x_itchy_b_x oh, np. its when you turn the compressor side/cold... Jun 20, 2007 - 9:50 PM
6strngs QUOTE(x_itchy_b_x @ Jun 20, 2007 - 7... Jun 20, 2007 - 10:06 PM
6strngs I'm so confused. I was looking at the turbo mo... Jun 20, 2007 - 10:57 PM
elvasoshexai one of those coolant line places is supposed to be... Jun 20, 2007 - 11:15 PM
6strngs QUOTE-additional cover for extra hole on turbo (is... Jun 20, 2007 - 11:19 PM
6strngs I placed an order for a 2.75" filter on ebay ... Jun 21, 2007 - 1:07 AM
elvasoshexai why didn't you just get a 2.5 -> 2.75 reduc... Jun 21, 2007 - 8:06 AM
6strngs QUOTE(elvasoshexai @ Jun 21, 2007 - 6... Jun 21, 2007 - 10:05 AM
shin iirc i think ya have to custom your wastegate with... Jun 21, 2007 - 1:40 PM
6strngs are you sure it's clocked? could I just... unc... Jun 21, 2007 - 3:26 PM
WALKER QUOTE(6strngs @ Jun 21, 2007 - 2:26 ... Jun 21, 2007 - 3:41 PM
6strngs tubo and manifold together.... yeah it's clock... Jun 21, 2007 - 3:47 PM
x_itchy_b_x just clock it again? its a giant C-clamp ring. gra... Jun 21, 2007 - 4:00 PM
WALKER QUOTE(x_itchy_b_x @ Jun 21, 2007 - 3... Jun 21, 2007 - 4:37 PM
x_itchy_b_x yes, its fun to learn to fabricate. actually i thi... Jun 21, 2007 - 6:54 PM
6strngs well, there's a couple hard to find parts from... Jun 21, 2007 - 11:36 PM
6strngs ok, I was able to "un-clock" it in like ... Jun 22, 2007 - 12:46 AM
6strngs ok, found part numbers, here they are for everyone... Jun 22, 2007 - 1:28 AM
6strngs ok, so today I ordered these parts:
2 studs (one f... Jun 22, 2007 - 12:55 PM
bufferdan 1st toyota parts probably coulda got it to you mon... Jun 22, 2007 - 1:15 PM
6strngs QUOTE(bufferdan @ Jun 22, 2007 - 11... Jun 22, 2007 - 1:28 PM
6strngs ok, got a nut for the shaft from OSH. in case anyo... Jun 22, 2007 - 6:06 PM
jcaron9gt4 wow man, cant wait for this thing to be done for y... Jun 23, 2007 - 8:54 AM
6strngs got my filter today, here it is on the now unclock... Jun 24, 2007 - 2:24 AM
6strngs toyota dealership called yesterday. said they had ... Jun 27, 2007 - 1:26 AM
6strngs is anybody even following this thread at all anymo... Jun 29, 2007 - 12:54 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 25th, 2026 - 8:37 PM |
