> Just a quick question
post May 28, 2007 - 12:33 AM
Bricy
Joined Mar 28, '07
From Odenville, Alabama
I was just wondering if doing 80+ mph daily is going to hurt my engine in some way. My commute to work is 60 miles round trip. Just wanted to make sure I'm not going to hurt anything tongue.gif
post May 28, 2007 - 12:49 AM
Culpable04
Joined Apr 17, '06
From New Jersey
as long as you do the proper maintenance on the car, it should be just fine.
post May 28, 2007 - 12:53 AM
Bricy
Joined Mar 28, '07
sweet. Yeah I'm pretty anal about oil changes and changing spark plugs, is there anything else I need to worry about?
post May 28, 2007 - 12:57 AM
forkee
Joined Nov 13, '02
From So Cal
worry about your tires. going at such a high rate of speed for an extended period of time wears them out faster than doing the speed limit. check tire pressure every time you fill up your gas and make sure tread is good.
post May 28, 2007 - 1:37 AM
bman
Joined May 14, '07
From Long Island
the guys above pretty much said it all... although i try not to go above 75 because i feel uncomfortable with the high rpm - on a manual at least
94 Celica ST - CAI, CarPuter, many interior mods!
post May 28, 2007 - 10:13 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
the higher RPM driving will eventually cause the car to burn oil. you'll notice it going through a lot more oil than it used to.
here's my thread about the problem I'm having: http://www.6gc.net/forums/index.php?showtopic=44346&hl=
Jeremy (alltracman78) gives a lot of good info and pretty much explains how bruning oil is almost a normal thing if you do a lot of high RPM driving
I <3 Dustin---07/16/06
post May 28, 2007 - 10:24 AM
Kadett
Joined Mar 17, '05
From The Netherlands
If you get the engine warm first (first 6 miles not above 2500 rpm) and then raise the speed abit untill you reach 80mph you should be fine. Especially when changing oil often.
About the Tyres with forkee said. I can vouch for that frown.gif Only been 14000 km (roughly 9000 miles) and now I already need to replace the front tyres. Guess 255BHP and alot of sprinting (40-110mph etc etc) will hurt your tyres greatly smile.gif
Lo-Fi Version Time is now: August 25th, 2026 - 2:20 AM
