> advance timing?
post Jun 7, 2007 - 12:23 PM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
How do I go about doing something like this?
Replies (1 - 16)
post Jun 7, 2007 - 12:33 PM
I wouldn't on your car.
post Jun 7, 2007 - 12:35 PM
Daftboy
Joined Jun 30, '06
bitter has on his... i do not see what the big deal would be....plus i run 94 octane all the time thanks too me not having to pay for gas biggrin.gif
post Jun 7, 2007 - 12:52 PM
we'll do it at DWG, just bring a timing light.
post Jun 7, 2007 - 12:53 PM
Daftboy
Joined Jun 30, '06
sounds like a plan dustin....ill put it in the trunk now
post Jun 7, 2007 - 1:34 PM
The reason I say I wouldn't is because of the increased risk in detonation. If your getting 94 octane this will def. help.
post Jun 7, 2007 - 1:49 PM
Daftboy
Joined Jun 30, '06
the one by me still sells 94.....they also have Cam2-100 octane
post Jun 7, 2007 - 1:59 PM
airfron
Joined Jul 31, '05
From Southern California
i've advanced my timing just the same... i haven't seen any negative side effects in anyway. just be sure to use the proper gas and you'll be fine. i run 91 octane with no problems.
post Jun 7, 2007 - 2:00 PM
Daftboy
Joined Jun 30, '06
ok...but HOW do i do it...lol..I need to take off the cap. then in there is there a weight or something...help me out =p
post Jun 7, 2007 - 2:02 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
it can easily be done at the DWG meet. We almost did it last year to my GT at the track.
Kawi Love
post Jun 7, 2007 - 2:30 PM
QUOTE(Daftboy @ Jun 7, 2007 - 3:00 PM) [snapback]566123[/snapback]
http://www.toyotacelicaonline.com/timing.htm
post Jun 7, 2007 - 2:36 PM
airfron
Joined Jul 31, '05
post Jun 7, 2007 - 2:49 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
hmm, so instead of 95 WHP, i shoulld now have about 105 WHP (16* btdc)
post Jun 7, 2007 - 6:58 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
i also replied to his PM with that link. i did my timing before i had a tach, so i cant give exact numbers....
but stock in 1st gear at about 30mph i felt this little surge of power , advancing timing made that surge a steady pull but i choked a little nearing 5500-5700rpm, the header opened it up and i no longer feel as if the engine is gasping. advancing timing made the engine feel much more twitchy and responsive at lower rpms and it felt like it pulled with a little more power. i'm ok on 89 octane, but as i said in my PM, every engine is different. my innards are very clean and my compression is even all across, my engine is in good shape. if your engine isnt in good shape then i suggest you dont do this as it adds more stress to the top of the piston and the first ring by exerting peak pressure against them longer.
post Jun 7, 2007 - 10:57 PM
Its helpful to post the links so other people can search and get answers too.
post Jun 8, 2007 - 7:55 AM
Bitter
Joined Mar 11, '06
you posted the same link 2 of us sent him in PM's.
post Jun 8, 2007 - 11:08 AM
QUOTE(Bitter @ Jun 8, 2007 - 8:55 AM) [snapback]566346[/snapback]
Yeah I saw that. But when someone has the same question, its helpful to post it in the forum so they can receive the same link also, savvy?
Lo-Fi Version Time is now: August 25th, 2026 - 2:38 PM
