Jun 25, 2007 - 7:23 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 30, '06 From Augusta, GA Currently Offline Reputation: 4 (100%) |
Here's a pic of underneath my car when I was doing an oil change. I think I may have a leak because there is a spot on my driveway where I park.
![]() It looks like whatever is leaking is going everywhere. I was able to wipe it up but it may be coming back. I was told a bit ago that my valve cover gasket needs replacement, would that do this over a long period of time? Also, I think I'm missing a bolt here: ![]() Can anyone either confirm or deny this? Thanks. Also, what is that? I'm not engine savvy so help a brother out! Cheers. -------------------- 2007 Subaru Impreza WRX STi 1974 Datsun 260Z 1997 Subaru Legacy L Wagon Kind of missin' my Celica GT! Hit me up if you're ever in my area. I'm always down for a meet. |
Jun 25, 2007 - 7:32 PM
Enthusiast ![]() ![]() ![]() Joined May 3, '06 From New Hampshire Currently Offline Reputation: 2 (100%) |
I'm not completly sure but if there are other bolts around that missing one then I agree that ur missing one. All that oil is probably coming from missing that bolt, a valve cover leak wouldn't spread that much i don't think. good luck getting it all figured out and cleaned up. Cleaning it up then jacking hte car up the next day or 2 after may show you exactly where its leaking.
This post has been edited by 6gcSTVT: Jun 25, 2007 - 7:32 PM -------------------- ![]() Darin H. |
Jun 25, 2007 - 8:47 PM
QUOTE(6gcSTVT @ Jun 25, 2007 - 7:32 PM) [snapback]572038[/snapback] I'm not completly sure but if there are other bolts around that missing one then I agree that ur missing one. All that oil is probably coming from missing that bolt, a valve cover leak wouldn't spread that much i don't think. good luck getting it all figured out and cleaned up. Cleaning it up then jacking hte car up the next day or 2 after may show you exactly where its leaking. True that, I'm lucky I've got a lift at my disposal whenever I need (well, @ $5/hour you can't go wrong). Also, can anyone point out where the subframe is from this pic? A while ago it was loose, supposedly, and it's starting to rattle again and I think it may be my subframe again. I was just wondering so I could see if I need new bolts or it just needs a tighten! -------------------- 2007 Subaru Impreza WRX STi 1974 Datsun 260Z 1997 Subaru Legacy L Wagon Kind of missin' my Celica GT! Hit me up if you're ever in my area. I'm always down for a meet. |
Jun 27, 2007 - 12:26 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
Your subframe shouldn't come loose on its own like that...
Jun 27, 2007 - 12:40 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
May be the plastic washer on the oil drain bolt is melted or cracked or simply came off?
It happened to me... mine melted, i donno how but it did.... -------------------- |
Jun 27, 2007 - 10:30 PM
I don't have a washer on the drain bolt...just the bolt. So does everyone have a washer on the bolt?
Jun 28, 2007 - 7:30 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
QUOTE(m0dd3d1 @ Jun 25, 2007 - 8:23 PM) [snapback]572036[/snapback] Also, I think I'm missing a bolt here: ![]() Can anyone either confirm or deny this? Thanks. Also, what is that? I'm not engine savvy so help a brother out! Cheers. that looks to be where your transmission connects to the engine. it doesn't look like you are missing a bolt, it looks like there is one on the other side. you're probably not leaking from there but if you are it would be the rear main seal. QUOTE(m0dd3d1 @ Jun 27, 2007 - 11:30 PM) [snapback]573044[/snapback] I don't have a washer on the drain bolt...just the bolt. So does everyone have a washer on the bolt? you need a washer. thats probably your whole problem. -------------------- |
| Lo-Fi Version | Time is now: August 31st, 2026 - 10:40 PM |
