Jul 8, 2007 - 8:43 PM
i know a few of you guys have the prosport gauges. i just wanted to see what you thought of them after having them installed for a while.
Jul 8, 2007 - 10:14 PM
id be interested in hearing reviews also. they look awesome i like the full sweep.
Jul 9, 2007 - 1:09 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
![]() they look great at night and are pretty accurate. they're just really hard to see during the day! -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jul 9, 2007 - 1:16 AM
do you have them wired up to light up white during the day? are they still hard to see when they are white?
Jul 9, 2007 - 1:32 AM
QUOTE(lagos @ Jul 8, 2007 - 11:16 PM) [snapback]576363[/snapback] do you have them wired up to light up white during the day? are they still hard to see when they are white? is that what that other wire is for? lol. there was one that was supposed to be hooked up to a switched source (as in, when you turn your headlights on). What I thought that would do would be to make them not light up during the day and then only light up with the headlights on, but since I didn't hook it up they are lit up blue 100% of the time. So, if I hook that up then they'll light up white during the day and blue when I turn the headlights on? do you know a good wire to hack into for a switched power source that's easy to get to? -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jul 9, 2007 - 1:38 AM
yeah the idea is that they are supposed to be bright white during the day. just buy a fuse tap and tap into your radio fuse for a switched 12v.
Jul 9, 2007 - 1:43 AM
into my radio fuse? is that really controlled by the headlight switch?
Jul 9, 2007 - 2:19 AM
i dont have these gauges, but im guessing you need.... power, ground, and illumination. get power from radio fuse, and for illumination you can splice into the light around your cig lighter or anything else that would normally turn on when you turn your lights on.
Jul 9, 2007 - 2:22 AM
QUOTE(lagos @ Jul 9, 2007 - 12:19 AM) [snapback]576390[/snapback] i dont have these gauges, but im guessing you need.... power, ground, and illumination. get power from radio fuse, and for illumination you can splice into the light around your cig lighter or anything else that would normally turn on when you turn your lights on. I've already got power from the cigarette lighter. so, that other wire going to the cigarette lighter is for the light? I'll try that out and see what happens. -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jul 9, 2007 - 10:16 AM
yeah from the light thats around th cig lighter.
alright no more tech support. i want to see some more reviews, pics and vids of these things in action. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 9, 2007 - 4:31 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) |
I have them and they look good however they are still in the box since i dont have the rest of my parts yet
-------------------- -Brian
Jul 10, 2007 - 10:01 AM
bump, anyone else?
what about the green/white gauges? do they match our interior well? do the gauges even look good in green? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 10, 2007 - 12:13 PM
a friend has the green and white ones in his wrx. i think they would match. if i didnt already have gauges i would go with those.
Jul 10, 2007 - 12:34 PM
QUOTE(lagos @ Jul 10, 2007 - 11:01 AM) [snapback]576878[/snapback] what about the green/white gauges? do they match our interior well? do the gauges even look good in green? ok here's the deal with the green gauges. Stef has them with the 2 gauge pod. they light up great in the day white, not the best pics but they are very readable in white durring the daytime. ![]() ![]() and at night they light up bright green. They cannot be dimmed and are much brighter then the stock green bulbs (pic below) ![]() now if you get some green LEDs for the stock gauge cluster, (she did later) then they will match much better, but not perfect, just much better. Here's a pic of the green LEDs in the stock gauge cluster. ![]() Now I can't find a pic of the LEDs and the guages together, I'll keep looking and post it up if I find it. my opinion pros : they are pretty inexpensive and look good cons : they aren't as easy to wire as other gauges because of the 2 color output (white/day, green/night), they can't be dimmed, they can't be wired to a dimable light source (or they won't light up properly at all), and the fittings/senders they come with are kinda generic. -------------------- |
Jul 10, 2007 - 12:46 PM
i just ordered a set of green/white premiums with peak hold
Jul 10, 2007 - 9:36 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(Batman722 @ Jul 10, 2007 - 10:34 AM) [snapback]576933[/snapback] my opinion Can't be dimmed?!?!? That is HORRIBLE. pros : they are pretty inexpensive and look good cons : they aren't as easy to wire as other gauges because of the 2 color output (white/day, green/night), they can't be dimmed, they can't be wired to a dimable light source (or they won't light up properly at all), and the fittings/senders they come with are kinda generic. Blinding, distracting, and worst of all: cop magnet... Are you sure they just don't work with the rising-ground dimming that Toyota uses? (my gauges wire up directly to the bulbs so I don't worry on my Camry... on my WRX, I had to make an inverting circuit to dim my gauges) I'll find the circuit to use if they can be dimmed from the power-side of the circuit and post it here (radio shack has all the necessary parts). -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Jul 10, 2007 - 11:35 PM
i never had any of my gauges on the dimmer anyway. i like them full blast so that they are easy to read.
Jul 11, 2007 - 8:20 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
oh man, those premiums look better than the regular 'performance' ones... i should've held out until they had the introductory gb for those premium ones
Jul 11, 2007 - 11:14 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
I believe the reason people with the blue gauges have trouble seeing them is because they don't have the color change option like the other colors, they are just blue all the time and that itself makes them harder to read in the day time.
Art, you should have told me you were thinking about buying them. I would have showed you mine in intimate detail, problems and all -------------------- |
Jul 11, 2007 - 1:21 PM
QUOTE(lagos @ Jul 10, 2007 - 9:35 PM) [snapback]577197[/snapback] i never had any of my gauges on the dimmer anyway. i like them full blast so that they are easy to read. Personal choice though! -Charlie -------------------- 2003 Subaru WRX Wagon
| Lo-Fi Version | Time is now: August 27th, 2026 - 2:09 PM |
