> The fensport celica
post Sep 19, 2007 - 1:26 PM
frosty
Joined Sep 1, '04
From Alabama
I thought I would start a new post instead of hijacking kcizzles redline mag topic.
I went to fensports site and read the spec list on the 7th gen celica and pondered something.
Why did they use a modified 4wd corollas rear subframe instead of the st205's? The used a st205's rear differential though.
I'm already sending them an e-mail directly asking about it, but just didn't know what anybodys thoughts on here about it was?
I understand that it's a 7th gen celica but if they have to modify the subframes then why not keep it all "celica"?
CLOSED on 25 acres!
-shop coming soon....
post Sep 19, 2007 - 3:41 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(frosty @ Sep 19, 2007 - 12:26 PM) [snapback]597336[/snapback]
my only guess is because the 6th gen is a bit smaller so the 6th gen would be too big. other than that i wouldn't be able to tell you.
also i think this belongs in off topic
post Sep 19, 2007 - 6:15 PM
frosty
Joined Sep 1, '04
From Alabama
I got an e-mail from fensport. Here's their answer:
The corolla awd shares virtually the same chassis and floorpan as the celica G7, so the subframe essentially bolts on, takes all the stock suspension arms,which means the wheels are in the correct place, and then only the diff carrier is modified to suit the gt4 diff.
TheGT4 subframe is cumbersome and heavy and doesn`t fit the new celica at all.
It also means I can enter the car in more events as the chassis is virtually stock
Best Regards
Adrian
That's very interesting to know.
CLOSED on 25 acres!
Lo-Fi Version Time is now: June 24th, 2026 - 12:18 AM
