> Car making squealing noise
post Sep 29, 2007 - 11:18 PM
CAMAricer
Joined Jul 25, '07
From San Francisco
Hi guys, got a weird problem. Hope someone can help me.
My car is making a high pitch squealing noise when the car is parked and I turn the wheel hard (all the way) in either direction (let's say to get out of a parking spot). If I let up just a bit (return the wheel towards it's neutral position), the noise stops. Also, at night when I do the same thing with the headlights on, I can see the lights get slightly dimmer. Soon as I let off, the lights return to normal. So I think there might be a connection there.
I first noticed this problem when I changed the break pad on my car (for the first time). I ended spilling some break fluid over the rotor/caliper and haven't used brake cleaner to clean it up yet, don't know if this info helps or not.
2002 SC430 (WC) - 19" SSR Comp-H, Daizen swaybars, Sparco Demons, JDM Soarer conversion, carbon fiber spoiler, Injen intake, front strut bar, drilled/slotted Brembo rotors
1997 Celica ST (DD) - 17" ADR, ViS Zyclone CF hood, ViS CF hatch, K&N intake, Invader body kit
post Sep 30, 2007 - 12:15 AM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
QUOTE(CAMAricer @ Sep 30, 2007 - 12:18 AM) [snapback]600179[/snapback]
thats belt chatter replace your belts
BOOST GETS YOU LAID!!!!
post Sep 30, 2007 - 12:36 AM
CAMAricer
Joined Jul 25, '07
From San Francisco
Oh, that's right. I had my belts replaced a few days before that (timing and serpentine belts). I'll go back to the mechanic and see what's up. Thanks.
QUOTE(jesterwr217 @ Sep 30, 2007 - 12:15 AM) [snapback]600184[/snapback]
post Sep 30, 2007 - 1:57 AM
Blakout16
Joined Jul 3, '04
From Yakima, WA
if you just got new belts then - most like they are just needing some tightening ... thats very normal for new belts to stretch out alittle bit.
post Sep 30, 2007 - 10:52 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(Blakout16 @ Sep 30, 2007 - 12:57 AM) [snapback]600192[/snapback]
mine does the same thing but only if it's cool outside (or so it seems)
from what i have been told it's the power steering. is there a power steering belt?
post Sep 30, 2007 - 12:04 PM
jesterwr217
Joined Feb 27, '07
yea if u just had them replaced sounds like they are a lil loose
post Oct 4, 2007 - 4:37 PM
BigRog95
Joined Oct 1, '07
From Greensboro, NC
Yeah, my celica was doing that when I first got it, but I just got all 3 belts replaced and its as good as new!
MySpace <- Where I reside
post Oct 7, 2007 - 9:40 PM
94CelicaDragon
Joined Oct 1, '07
From Sacramento, CA
Funny no one metioned this...Have you checked your power steering pump/fluid? My pump went out, I just got a new one. It still has a leak, so I think I might need a new resivoir(Or however you spell It). It made that sound all the time, you probably have air In your line's, which Is what make's that noise. -Phil
post Oct 8, 2007 - 6:39 AM
BigRog95
Joined Oct 1, '07
From Greensboro, NC
Hm, never even thought about that...That very well could be it too. Check belts and steering pump/fluid lvl!
Hope you fix it.
post Oct 9, 2007 - 3:40 PM
CAMAricer
Joined Jul 25, '07
From San Francisco
So I went to the shop that put the belts on and the guy said he thought one of the belts was kinda loose, so he "fixed" it a few seconds. Now the noise is almost completely gone (95%) but when I make a hard turn on the wheel (like all way) I can barely make out the sound.
I'm thinking I'm just being picky now, but should I continue to monitor this sound or is it not really a big deal?
Oh, I'll check the power steering fluid today too to see it it's low or anything.
Lo-Fi Version Time is now: May 20th, 2026 - 2:07 PM
