> Stef's 7AFTE Tech/Project, First Dyno run pg16
post Sep 30, 2007 - 8:29 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
So first things first, with the help of Garrett's Turbo Tech 103 (Expert), I did the compressor flow map calculations... try to follow along, if you have any questions just ask...
here are the EQUATIONS:
and the CALCULATIONS (for a 7AFE with a target of 200hp at the flywheel):
then you need to plot some numbers on the COMPRESSOR FLOW MAP of your choice
I got a small Garrett 2052 which should be enough for my goals
From just looking at different compressor flow maps you'll learn a lot. In general, the closer the turbine and exhaust housing sizes the wider your power range will be but the maximum boost level is limited. When the sizes are significantly different you'll notice the compressor map will look taller and thinner, that gives you a smaller RPM range you can boost in but you can achieve higher boost levels in that range.
This post has been edited by hurley97: Jul 24, 2009 - 5:13 PM
I <3 Dustin---07/16/06
- hurley97   Stef's 7AFTE Tech/Project   Sep 30, 2007 - 8:29 AM
- - presure2   good stuff steff, keep it comin!   Sep 30, 2007 - 8:53 AM
- - jcbass7   this is going to be a good thread   Sep 30, 2007 - 11:50 AM
- - Piloter   Hey guys, I'm the Piloter who's doing the ...   Sep 30, 2007 - 5:00 PM
- - hurley97   I have already bought a turbo. When I get some tim...   Oct 2, 2007 - 10:22 PM
- - lagos   damn girl, you got more projects then the ghetto...   Oct 2, 2007 - 10:26 PM
|- - hurley97   QUOTE(lagos @ Oct 2, 2007 - 11:26 PM...   Oct 3, 2007 - 5:13 AM
- - hurley97   but for now I'll introduce the rest of my turb...   Oct 2, 2007 - 10:38 PM
|- - celicast3sgte   QUOTE(hurley97 @ Oct 2, 2007 - 8:38 ...   Oct 3, 2007 - 7:16 PM
- - OrbitalGT95   I have a feeling your lil ST is gonna kick some se...   Oct 2, 2007 - 10:44 PM
- - playr158   steph do you mind if i add this to the 7afte stick...   Oct 3, 2007 - 7:15 AM
|- - hurley97   QUOTE(playr158 @ Oct 3, 2007 - 8:15 ...   Oct 3, 2007 - 4:27 PM
- - playr158   thanks chica   Oct 3, 2007 - 5:07 PM
- - CelicaST_CALI   dan are u a m0d?   Oct 3, 2007 - 7:37 PM
- - lagos   QUOTE(hurley97 @ Oct 3, 2007 - 5:27 ...   Oct 3, 2007 - 11:13 PM
- - nik   another 7afte project keep up the great work oh an...   Oct 4, 2007 - 10:31 AM
- - hurley97   my turbo is here... and its little, just like ever...   Oct 6, 2007 - 6:53 PM
- - 1bwilson   Use a coke can next time , big hands or little t...   Oct 6, 2007 - 7:02 PM
- - presure2   mmm yummy turbo!   Oct 6, 2007 - 10:14 PM
- - Blakout16   that looks similiar to my turbo hmm!   Oct 6, 2007 - 11:17 PM
- - Hanyo   that looks like such a small turbo. I can't ...   Oct 7, 2007 - 1:54 AM
- - Valo666   thats a pretty small turbo...looks like you should...   Oct 7, 2007 - 12:59 PM
- - Celiracer18   what are the specs for the turbo?   Oct 7, 2007 - 10:18 PM
- - Harold_Fastwaker   Looks like an AR.50(x). Which will be fine for 1...   Oct 8, 2007 - 4:13 AM
- - Blakout16   that is small... makes mine look HUGE ... haha ;D   Oct 9, 2007 - 12:09 AM
- - Bricy   I figured I'd bump this up and see how the pro...   Oct 31, 2007 - 12:19 AM
- - normality78   im quite positive he can reach 200 on flywheel wit...   Nov 1, 2007 - 1:18 AM
- - 95celgt   u must mean SHE can reach that goal   Nov 1, 2007 - 10:57 AM
- - Steevo   This thread is awesome.   Nov 1, 2007 - 12:20 PM
- - hurley97   I got some Supra lime green top 315cc injectors fr...   Nov 1, 2007 - 12:51 PM
- - doGGy   Everything looks perfect so far - oil return is in...   Nov 1, 2007 - 12:59 PM
- - lagos   yeah, the safc is the major flaw in your setup so ...   Nov 1, 2007 - 2:19 PM
|- - OrbitalGT95   QUOTE(lagos @ Nov 1, 2007 - 7:19 PM)...   Nov 1, 2007 - 3:23 PM
|- - hurley97   QUOTE(lagos @ Nov 1, 2007 - 3:19 PM)...   Nov 3, 2007 - 5:33 AM
- - 95celgt   Amazing work stef! This makes me want to buy m...   Nov 1, 2007 - 3:37 PM
- - normality78   ops sorry. whahahaha. i wasnt know is a lady. yeah...   Nov 2, 2007 - 4:12 AM
- - Panswed   what kind of turbo header are you going to use?   Nov 3, 2007 - 11:54 AM
|- - hurley97   QUOTE(Panswed @ Nov 3, 2007 - 12:54 ...   Nov 3, 2007 - 5:28 PM
- - hurley97   Newly acquired items: Walbro 255lph Fuel Pump GSS...   Nov 16, 2007 - 8:36 AM
- - LewFX   isnt a 255 fuel pump extreme for a 7a? i hear a 18...   Nov 16, 2007 - 10:28 AM
|- - trdcelica94   QUOTE(LewFX @ Nov 16, 2007 - 9:28 AM...   Nov 18, 2007 - 2:47 AM
- - jcbass7   nice nice stef!! what are you going to us...   Nov 16, 2007 - 10:36 AM
- - 1bwilson   Looking good, witchhunter does a great job with in...   Nov 16, 2007 - 3:46 PM
- - x_itchy_b_x   awesome, is some sorta step cousin way I contribut...   Nov 16, 2007 - 3:59 PM
- - hurley97   QUOTE(jcbass7 @ Nov 16, 2007 - 10:36...   Nov 16, 2007 - 5:00 PM
- - celicast3sgte   fascinating. wayy more in depth 7afte build than a...   Nov 16, 2007 - 7:42 PM
- - x_itchy_b_x   id use an oem cobra pump also. least thats what iv...   Nov 16, 2007 - 8:50 PM
- - normality78   damn... i was just thinking of the pro and cons us...   Nov 17, 2007 - 2:38 AM
- - trdcelica94   NICE!also good choice on the turbo...   Nov 18, 2007 - 2:44 AM
- - jcbass7   steff, can you run the IC anywhere in the engine b...   Nov 18, 2007 - 10:15 AM
|- - hurley97   QUOTE(jcbass7 @ Nov 18, 2007 - 10:15...   Nov 18, 2007 - 5:10 PM
- - hurley97   Here's my Excel Spreadsheet Parts List. the gr...   Nov 19, 2007 - 12:25 PM
|- - CelicaST_CALI   QUOTE(hurley97 @ Nov 19, 2007 - 9:25...   Nov 20, 2007 - 9:18 PM
- - jcbass7   nice spreadsheet, i need to start one of those.. a...   Nov 19, 2007 - 8:20 PM
- - normality78   damn... you put me on shame. I cant even do out ta...   Nov 19, 2007 - 8:21 PM
- - elvasoshexai   i had a spreadshhet too but it ended up so disorga...   Nov 19, 2007 - 11:26 PM
- - celicast3sgte   i know i got that price beat... :-/ hahaha im up t...   Nov 20, 2007 - 7:57 PM
- - celicast3sgte   btw, are you going to add a wideband o2 to that li...   Nov 20, 2007 - 9:25 PM
|- - hurley97   QUOTE(celicast3sgte @ Nov 20, 2007 - 9...   Nov 21, 2007 - 6:46 AM
|- - jesterwr217   QUOTE(hurley97 @ Nov 21, 2007 - 6:46...   Nov 21, 2007 - 12:23 PM
- - hurley97   I am considering the Innovate Motorsports LC-1 Wid...   Nov 23, 2007 - 6:51 AM
- - lagos   The only difference is that the AEM doesn't co...   Nov 23, 2007 - 6:35 PM
- - Celiracer18   Logworks2 is Amazing. I have the LC-1 but i havent...   Nov 23, 2007 - 7:38 PM
- - frosty   This is coming across as a nice build, keep it up...   Nov 23, 2007 - 8:40 PM
- - hurley97   I just ordered an Exedy Racing Stage 2 Cerametalli...   Nov 23, 2007 - 8:54 PM
- - x_itchy_b_x   a small half radiator from a civic would also work...   Nov 24, 2007 - 12:45 PM
- - normality78   perhaps using kcar type? im using one as my radiat...   Nov 24, 2007 - 12:52 PM
- - OOBE   You should have no problem with hitting the 200 HP...   Nov 27, 2007 - 9:45 PM
|- - hurley97   QUOTE(OOBE @ Nov 27, 2007 - 9:45 PM)...   Nov 28, 2007 - 7:34 PM
|- - OOBE   QUOTE(hurley97 @ Nov 28, 2007 - 6:34...   Nov 29, 2007 - 12:31 AM
- - hurley97   I bought the Innovate LC-1 -- $271.95 shipped...   Nov 28, 2007 - 7:29 PM
- - normality78   cant wait to see your engine run live...   Nov 28, 2007 - 8:31 PM
- - hurley97   I like the quote at the bottom of your sig... I ki...   Nov 29, 2007 - 4:54 PM
- - OOBE   Be my guest, girl. The more proud owners, the merr...   Nov 29, 2007 - 8:32 PM
- - Shocker   i gues i need it in mine too. i too need a stand ...   Nov 29, 2007 - 11:41 PM
- - OOBE   Yes, it does suck. For other cars, it works, but a...   Nov 29, 2007 - 11:46 PM
- - hurley97   My clutch was also delivered yesterday. its an Exe...   Dec 5, 2007 - 10:00 PM
- - OOBE   Hahahaha CLEVER.   Dec 5, 2007 - 10:56 PM
- - m0dd3d1   How the hell do you learn all of this! Damnit...   Dec 6, 2007 - 1:10 AM
- - jcbass7   Good stuff steff, keep it up   Dec 7, 2007 - 10:25 AM
- - x_itchy_b_x   i like your idea! neato (spanish for neat) you...   Dec 7, 2007 - 10:28 AM
- - hurley97   I know... I think I'm a little scared of it......   Dec 8, 2007 - 7:10 AM
- - celicast3sgte   haha scared of it how???   Dec 8, 2007 - 3:46 PM
|- - hurley97   QUOTE(celicast3sgte @ Dec 8, 2007 - 3...   Dec 11, 2007 - 7:20 AM
- - fran   Nice project! Nice clutch!... im pretty ...   Dec 8, 2007 - 6:02 PM
- - i_want_vtec   did any of you guys look into this while you were ...   Dec 10, 2007 - 7:36 PM
- - frosty   QUOTE(hurley97 @ Dec 11, 2007 - 12:2...   Dec 11, 2007 - 11:22 AM
- - celicast3sgte   naw itll be fine. ive driven all sorts of clutches...   Dec 20, 2007 - 9:32 PM
- - lagos   QUOTE(hurley97 @ Dec 11, 2007 - 7:20...   Dec 20, 2007 - 10:57 PM
- - hurley97   its been almost a week now, I've got about 250...   Dec 20, 2007 - 11:08 PM
- - lagos   nice! it will smooth out more and more as its ...   Dec 20, 2007 - 11:44 PM
- - FortuneCookie   Nice. Good job on the efforts.   Dec 31, 2007 - 1:45 PM
- - hurley97   update: I think I am falling in love with my clutc...   Dec 31, 2007 - 7:16 PM
- - celicast3sgte   comin along nicely. whats the projected ET? sorry ...   Dec 31, 2007 - 11:42 PM
- - hurley97   I've run into some financial issues but I...   Jan 8, 2008 - 7:21 AM
- - FortuneCookie   Wow. Still alot of work to be done. But hey, look ...   Jan 9, 2008 - 2:28 AM
- - hurley97   I may also want to get a turbo timer. I'm stil...   Jan 9, 2008 - 10:46 PM
- - lagos   QUOTE(hurley97 @ Jan 9, 2008 - 10:46...   Jan 9, 2008 - 11:01 PM
|- - 6strngs   QUOTE(lagos @ Jan 9, 2008 - 8:01 PM)...   Jan 10, 2008 - 1:28 AM
- - normality78   yes u can, all u need to is get the harness which ...   Jan 10, 2008 - 2:13 AM
4 Pages V   1 2 3 > »
Lo-Fi Version Time is now: August 27th, 2026 - 5:54 AM
