Oct 12, 2007 - 5:05 PM
Enthusiast Joined Jan 22, '05 From Oakland, California Currently Offline Reputation: 0 (0%) |
Hi, when I start my car it's up and running just fine: the temperature gradually increases to an optimal level. However, when I start driving at high speeds, my temperature mysteriously drops down to the lowest level. It goes back up when it is stopped. Can anyone tell me what is wrong with my car? I appreciate the help. Thanks!
JOhn |
Oct 12, 2007 - 5:13 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
QUOTE(TargetXeno @ Oct 12, 2007 - 11:05 PM) [snapback]604452[/snapback] Hi, when I start my car it's up and running just fine: the temperature gradually increases to an optimal level. However, when I start driving at high speeds, my temperature mysteriously drops down to the lowest level. It goes back up when it is stopped. Can anyone tell me what is wrong with my car? I appreciate the help. Thanks! JOhn sounds to me like your thermostat could be on the way out, and it's letting too much water into the rad. it's a pretty cheap part and easy to change so probably worth doing -------------------- |
Oct 13, 2007 - 7:16 PM
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From St. Paul, MN(USA) Currently Offline Reputation: 8 (100%) |
yeah...mine was the same as yours too....that would be your thermostat like manphibian said. If you drive it too long it will over heat....i learned it the hard way...
Oct 14, 2007 - 12:03 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
yep thermostat
| Lo-Fi Version | Time is now: August 26th, 2026 - 7:08 AM |
