Nov 15, 2007 - 2:58 AM
Enthusiast ![]() ![]() Joined Oct 18, '07 From Orange County, CA Currently Offline Reputation: 3 (100%) |
whenever my car is cold and I start it for a little while sounds like right behind the dash on the by the engine firewall, it sounds like water being poured. and the faster i drive faster the water sound is. i don't have any coolant leaks, changed my radiator recently(it was making the sound before and after the radiator change)new radiator upper hose, and new thermostat and water pump. what can be causing this water pouring sound?
Thanks in advance, Jason -------------------- |
JasonX poor coolant circulation??? Nov 15, 2007 - 2:58 AM
GrimReaper If the engine's temperature is normal, you hav... Nov 15, 2007 - 3:52 AM
JasonX QUOTE(GrimReaper @ Nov 15, 2007 - 12... Nov 15, 2007 - 8:14 PM
LewFX did you add the coolant in right? Nov 15, 2007 - 8:26 PM
JasonX QUOTE(LewFX @ Nov 15, 2007 - 5:26 PM... Nov 15, 2007 - 8:46 PM
MaskedMan You might have air in the system. Nov 15, 2007 - 9:16 PM
JasonX QUOTE(MaskedMan @ Nov 15, 2007 - 6:1... Nov 16, 2007 - 12:14 AM
celica3sgte Take your radiator cap off, then start the car and... Nov 16, 2007 - 12:23 AM
JasonX QUOTE(celica3sgte @ Nov 15, 2007 - 9... Nov 16, 2007 - 12:31 AM
Bitter may help to put the front of the car up on jacksta... Nov 17, 2007 - 9:42 AM
JasonX QUOTE(Bitter @ Nov 17, 2007 - 6:42 A... Nov 17, 2007 - 3:19 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 3rd, 2026 - 7:45 PM |
