> 400whp caladina powered FF 6gc, stock bottom end
post Dec 6, 2007 - 4:26 PM
jgreening
Joined Jan 17, '04
From Illinois
It may be a repost but I thought I would post it up anyway:
Thread on www.mr2.com
post Dec 6, 2007 - 4:44 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE(jgreening @ Dec 6, 2007 - 4:26 PM) [snapback]620279[/snapback]
and GUESS what i have to say about THAT.....
MUHHAHAHAHAHAHA!!!! THANKS FOR THE INFO!!! only a few more months....
post Dec 6, 2007 - 4:53 PM
Whose car is this?
This post has been edited by Supersprynt: Dec 6, 2007 - 4:54 PM
post Dec 6, 2007 - 4:59 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
just be sure to put collision insurance on this one hahahahahahhaha
good luck cant wait to see it
post Dec 6, 2007 - 5:06 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
i just asked the author of that thread (rickyb) who owned it i need to talk to that guy....
post Dec 6, 2007 - 5:27 PM
interesting comments by ricky in that thread, jay.
seems like he's finding some new things out about the gen4 3s...
sounds like a HELL of a ride.
post Dec 6, 2007 - 7:46 PM
wonder if the owner is on here.
post Dec 6, 2007 - 8:01 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
i know for a fact that herbalife has a 330 whp caldina (the actual car) he gave me some pointers...and knows where to get aftermarket parts for that motor
post Dec 6, 2007 - 8:03 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
I've never seen a 1 piece manifold/turbine like this. Looks like an awesome setup though.
http://i80.photobucket.com/albums/j177/all...ac/IMGP3128.jpg
FlickR
post Dec 6, 2007 - 8:13 PM
chacha
Joined Dec 29, '05
From So-Cal
EAST, share some info with us on the after market parts for the ST215 engine...my choice is runninng in the middle of the ST205 engine and the ST215...
This post has been edited by chacha: Dec 6, 2007 - 8:14 PM
post Dec 6, 2007 - 9:50 PM
frosty
Joined Sep 1, '04
From Alabama
QUOTE(BLINKYxMUNKEY @ Dec 7, 2007 - 1:03 AM) [snapback]620362[/snapback]
interesting...smooth flow...nice numbers...
I'm curiouse though, what are the specs on the head? more specifically, valve diameter and cam specs....
This post has been edited by frosty: Dec 6, 2007 - 9:53 PM
CLOSED on 25 acres!
-shop coming soon....
post Dec 7, 2007 - 7:45 AM
pitcelica
Joined Jan 28, '07
From Québec, Canada
I know that the exhaust cam is the same as ST185 and ST205. Here's my guess for the intake cam :
Specs of stock ST185 cams:
Ex, max cam lift 8.2 mm, 236°, max lift at 118° BTDC, open 56° BBDC, close 0°
In, max cam lift 8.2 mm, 236°, max lift at 110° ATDC, open 8° BTDC, close 48° ABDC
Overlap 8°
Specs of stock ST205 cams:
In, max cam lift 8.7 mm, 240°, max lift at 113° ATDC, open 7° BTDC, close 53° ABDC
Overlap 7°
Specs of stock ST215 cams:
In, max cam lift 8.7 mm, 244°, max lift at 113° ATDC, open 7° BTDC
This is my guess for the 4th gen cam specs
For the valve spec, according to the EPC, 4th gen 3sgte intake valve aren't interchangeable, so they aren't the same as other gen. According to the EPC, the exhaust valves of the 4th gen are the same as the 3rd gen ST205 one. So, find the diameter of the ST205 exhaust valve and you will know the spec of these 4th gen exhaust valves.
I own a 4th gen too. If I disassemble the head, I'll take measurement to have the spec of the head.
post Dec 7, 2007 - 10:52 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE(chacha @ Dec 6, 2007 - 8:13 PM) [snapback]620369[/snapback]
wow pit! this info is pretty useful! though im no gear head, im always trying to learn more.
Chacha, sorry, dont have much in the way of aftermarket available here BUT i will try to get a hold of herbalife to find out what after market parts he had on his, im pretty sure he had an AEM fuel rail slightly modified but the caldina he has is in jamaica, and i dont have the list of stuff he has in my mail, will get back to ya on it if i can though
post Dec 7, 2007 - 3:01 PM
6strngs
Joined May 12, '06
From Wilmington, NC
Oh god, the place where this thing was tuned is seriously less than a mile from my house! I've got to find this beast so I can get a ride in it! bowdown.gif
post Dec 7, 2007 - 4:55 PM
QUOTE(6strngs @ Dec 7, 2007 - 3:01 PM) [snapback]620646[/snapback]
you should go there an have ricky tune your car.
post Dec 7, 2007 - 5:16 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(lagos @ Dec 7, 2007 - 1:55 PM) [snapback]620692[/snapback]
sounds good to me! maybe he'll give me a special mr2oc.com member discount! (haha, I wish) but seriously, I think I'm gonna give him a PM and see if he could do it.
post Dec 7, 2007 - 11:44 PM
chacha
Joined Dec 29, '05
From So-Cal
where is he located and where was the info on the little tuner place, did i miss it? maybe ill go and check him out since he's in cali...if he's done 4th gen swap...maybe he'll consider doing one for me biggrin.gif...
post Dec 8, 2007 - 1:45 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(chacha @ Dec 7, 2007 - 8:44 PM) [snapback]620811[/snapback]
livermore CA is about an hour east of san francisco.
post Dec 9, 2007 - 12:33 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
So, as I can seen, a lot of people want to know what are the aftermarket parts are available for the ST215 3SGTE engine. Here's are some parts that are bolt on :
-Adjustable cam gear (AEM, Fidanza, HKS, OBX, ATS). Any cam gear kit for 3SGTE will fit.
-XS Power SSAC ST205 manifold/downpipe used with a ST205 turbo will convert the one-piece ST215 manifold/turbo to a nicely upgradeable ST205 Ct20b turbo kit. You can add to this a t3/t4 adaptor and you will be able to use a t3/t4 turbo (like I did on my ST215 swap)
-Pistons, rods, crankshaft are all the same for ST205 and ST215
-The injectors are the same as the ST205 one, so, if there is a 3rd gen fuel system available, it will fit the ST215 too.
-The exhaust camshaft is the same as the ST205 one. So an HKS 264/272 exhaust camshaft will bolt on. For the intake, I don't know if the HKS one would fit. Next year, when money will allow it, I'll buy a HKS264/264 camshaft kit and I'll know if the intake camshaft fit or not.
-You can remove the top ATA intercooler and add a FMIC as easy as any other 3SGTE.
The things that need heavy custom work is the ECU/wiring harness, ignition component (because of coil-on-plug). In my case, I used a Megasquirt II ECU with Ford EDIS wastespark ignition system and everything works nicely.
The other aftermarket parts like BOV, wastegate, air intake, boost controller etc, can be fitted easily like on any other 3SGTE engine.
So plz, stop saying that the ST215 engine isn't easily modifyable, there are plenty of parts that can be used to give a lil more hp to this unknown beast.
Thanks
Sam
Lo-Fi Version Time is now: June 22nd, 2026 - 7:50 PM
