Dec 7, 2007 - 5:20 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) |
I haven't tested this theory but it sounds possible. For those who want to make carbonfiber molds but don't have the equipment. Do think it is possible to liquify silicone and use it as a hardening agent for carbionfiber wrap? Like say you want a carbonfiber wrapped valve cover. Could you lay carbon fiber material on you valve cover and evenlly spread or spray liquid silcone on it alow it to dry and recieve the same effect as fiberglass resign and hardener? Its sound possible. What do you think?????
This post has been edited by Lil-Joe101: Dec 7, 2007 - 5:25 AM -------------------- From Japan to Texas my st202 follows me.
![]() Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
Dec 7, 2007 - 8:29 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
Its not gonna happen.
You will get Dry CF from inside, and it wount stick to the surface. Resin softens CF / FG and penetrates into it, plus it kinda melts the CF / FG and goes through it onto the surface. -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Dec 7, 2007 - 7:25 PM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 10, '07 From lodi, ca Currently Offline Reputation: 9 (100%) |
if you used silicone wouldnt that melt under the heat of the motor leaving you with a soggy mess and a ruined valve cover? like u said u woudl melt it first then put it on what keeps it from melting again. i dont know the melting point it just doesnt seam likely to me that it woudl work
| Lo-Fi Version | Time is now: August 11th, 2026 - 9:53 AM |
