> any1 know how to use seafoam??
post Dec 11, 2007 - 6:34 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
can anyone post up a "how to" on this amazing seafoam stuff i've been hearing about in alot of other forums as well as this/
Replies (1 - 19)
post Dec 11, 2007 - 7:16 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
go to Autozone and buy a can. there are directions on the back. a lot of people use the pcv hose as their vacuum line to suck it through.
I <3 Dustin---07/16/06
post Dec 11, 2007 - 10:45 AM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
you can also pour it in the gas tank, and into the oil.
post Dec 11, 2007 - 10:48 AM
The directions are on the bottle.
QUOTE(hurley97 @ Dec 11, 2007 - 7:16 AM) [snapback]621692[/snapback]
You mean take the hose off the PCV right.
This post has been edited by Supersprynt: Dec 11, 2007 - 10:49 AM
post Dec 11, 2007 - 11:10 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
yeah the hose for the pcv, or if you have an st, there is a circular cap with several small hoses leading to it you can detatch one of these and hit the throttle as well. but be careful IF YOU PUT IT IN YOUR OIL be sure to change your oil soon afterwards (it cleans out deposits and may do harm if you leave the seafoam in their for too long)
post Dec 11, 2007 - 11:13 AM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
i bought 2 cans + a longer vac hose so i could slightly rev car while sucking it thro vacuum..
1 can in gas tank w/ car off
1/3 in crankcase w/ car off
2/3 thro some vacuum line connected to tps w/ car on and slightly revving and let it die when it sucks up last bit
wait 40min
turn on car. rev it until no more smoke and then drove it around for 20min
then i changed oil 1 week later
then changed oil again slightly earlier than regular 3000miles...
and replaced fuel filter
hope that's rite...
06 Civic EX
My For Sale Thread
post Dec 11, 2007 - 11:49 AM
Do this at night if you can. The amount of smoke that seafoam creates can draw a bit of unwanted attention in the day time.
post Dec 11, 2007 - 1:21 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I put the Seafoam into an Arrowhead Water bottle that had the "sport cap" on it - instead of the pop-up sippy thing on water bottles, it had a little flip-top the same size as the pop up ones that was blue instead of the usual white. Use a knife or scissors to open up the nozzle a bit wider, and the opening is a perfect size to fit a vacuum line into. It created a great vacuum to suck the seafoam up neatly and easily.
post Dec 11, 2007 - 2:37 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
cool cool i'll prolly do the pcv sucky thingy. and drop some in my oil.
i'll prolly wont try the gas tank route.
post Dec 11, 2007 - 3:40 PM
chacha
Joined Dec 29, '05
From So-Cal
i tried it...poured inside the the vavle cover by opening the oil cap, fed to vacuum line, & gas tank...i followed direction and no smoke came out at all...weird though...maybe my engine is clean...but it seem impossible...something should come out...at least a little bit of smoke...but i got nothing...did it right on the spot of the autozone shop...kindasad.gif don't know if something went wrong...i didn't want to say anything about it because i didn't see any smoke..not even a puff...so i just changed my oil after rev(s) mutilple of time annoying those around me and left....kinda felt..well...really no feeling... frown.gif
This post has been edited by chacha: Dec 11, 2007 - 3:41 PM
post Dec 11, 2007 - 4:18 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
That is weird. I mean, when I did it on mine, it smoked but not too much. It wasn't as dramatic as when I had a bad turbo and a broken piston at the same time, but it was thick enough to draw attention.
post Dec 11, 2007 - 4:21 PM
step 1: go to the beach with a bucket
post Dec 11, 2007 - 5:39 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
step:2 wait for a tidal wave to catch as much seafoam as you can
post Dec 11, 2007 - 5:45 PM
manphibian
Joined Oct 13, '06
From UK
step 3: Remove crabs from bucket ensuring that suitable protective clothing is used.
post Dec 11, 2007 - 5:59 PM
GriffGirl
Joined Feb 7, '07
QUOTE(manphibian @ Dec 11, 2007 - 2:45 PM) [snapback]621846[/snapback]
Dude, you said crabs
heh heh
post Dec 12, 2007 - 5:59 PM
can anyone post a pic showing exactly wich little hose in the gt. Since there is more than 1 biggrin.gif
post Dec 12, 2007 - 6:55 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
wow! NO smoke?!? thats real strange i took mine out and almost caused an accident! apparently i still had some more to get out after i rev'd it in the driveway.
post Dec 12, 2007 - 7:01 PM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(chacha @ Dec 11, 2007 - 12:40 PM) [snapback]621804[/snapback]
you pull off a vaccum line that did not give enough suction.
It is so easy to use seafoam. i dont know why people have such a hard time doing it. start your engine, pull off any vaccum hose. Put your finger on the open end of the hose. If you feel it sucking on your finger then your good. If the hose does not suck onto your finger you go the wrong hose.
I used the big brake booster hose because it was 1) long enough 2) gave a good ammount of suction. 3) easy to find.
post Dec 12, 2007 - 7:20 PM
Chanh55
Joined Jun 29, '03
Youtube is your friend...
http://www.youtube.com/watch?v=2hrasAYG42g
lots of vids.
post Dec 12, 2007 - 10:40 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i did mine 2 years ago... but we have it under a different name here, not seafoam.
and as suggested, try to do it at night. also it would be best to do it near the highway and then start driving. works best while revving imo.
Lo-Fi Version Time is now: May 27th, 2026 - 1:18 PM
