> Engine Oil, best typr/brand
post Jan 11, 2008 - 11:28 PM
SeverX13
Joined Dec 4, '07
From Northeast Pennsylvania
whats that best oil to use on a celi?
Replies (1 - 19)
post Jan 11, 2008 - 11:39 PM
post Jan 18, 2008 - 8:50 PM
lipweb
Joined Jul 7, '06
From usa
what about castrol GTX 10w 40?? Is that good for celicas? I use it on my other ride.
post Jan 18, 2008 - 10:42 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
Dude, motor oil is motor oil. If your celica has a motor, then motor oil is probably fine to use. (assuming you're not buying O'Reilly brand oil or something worse) You wanted to know the best kind for a celica, batman answered.
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Jan 19, 2008 - 12:10 AM
Rusty
Joined Nov 5, '07
From New Zealand
BUT more importantly, it should go through a good oil filter. I suggest a TRD oil filter :L(ultra filteration & flow)
post Jan 19, 2008 - 2:59 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
i use royal purple with a k&n oil filter
post Jan 19, 2008 - 6:00 AM
Kadett
Joined Mar 17, '05
From The Netherlands
QUOTE(Rusty @ Jan 19, 2008 - 6:10 AM) [snapback]632251[/snapback]
Unless you live in Europe and the OEM Toyota filter is the same quality/build as the TRD oil filter.
About the Oil:
On a rebuild engine I wouldn't use anything else then Motul, otherwise every reknown brand is good enough. Castrol/Mobil1 etc
post Jan 19, 2008 - 11:39 AM
97GTinKC
From KC
Amsoil Series 3000 0W30 full synthetic
post Jan 19, 2008 - 2:55 PM
laff09
Joined Jul 28, '06
From Delaware
I prefer Castrol GTX.. unless your rocking a rebuild. Really a matter of preference imho. Check out def's engine in Stefs 7a rebuild thread, daaamn clean and he used dino oil.
post Jan 20, 2008 - 12:05 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(laff09 @ Jan 19, 2008 - 2:55 PM) [snapback]632398[/snapback]
the type of oil he used really isn't what made that much of a difference. its regular oil changes and having an engine that isn't burning oil that makes it that clean. in my old engine, the oil control rings were worn and doing nothing at that point which caused the massive oil burning, and when I switched to synthetic in a failed attempt to make things better it cleaned too much out and I began to have massive leak problems.
I use Mobil1 synthetic 5w-30 in my rebuild because in the long run it'll keep the oil passages cleaner and it won't gunk up as much.
I <3 Dustin---07/16/06
post Jan 20, 2008 - 1:30 AM
laff09
Joined Jul 28, '06
From Delaware
QUOTE(hurley97 @ Jan 20, 2008 - 12:05 AM) [snapback]632495[/snapback]
I thought that picture of a worn oil control ring was from defs engine? But yeah ofcourse regular oil changes has a huge impact on engine life
post Jan 20, 2008 - 11:29 AM
Rusty
Joined Nov 5, '07
From New Zealand
how often do you guys do yours? every 5,000km 10,000km or more?
I do mine every 5
post Jan 20, 2008 - 11:55 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(laff09 @ Jan 20, 2008 - 1:30 AM) [snapback]632510[/snapback]
they were. his engine was starting to burn oil but he just stopped driving it and swapped instead of driving with bad oil control rings for 30k miles.
post Jan 20, 2008 - 11:56 AM
laff09
Joined Jul 28, '06
From Delaware
ahhh gotcha
post Jan 22, 2008 - 3:47 AM
trdproven
Joined Aug 2, '05
From Guam
Oil is oil but of course don't get the super generic ones, at least get one with a recognized name. for oil filters there are premium versions of the regular ones or just stick with an OEM toyota filter.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 22, 2008 - 10:39 AM
celicaracer18
Joined May 23, '04
From Meridian, MS
on any toyota motor you NEED to go with oem toyota, or k&n / mobil 1
or some other brand with an anti drain back valve. its cruicial to not have dry starts on toyota motors or any kind, thats why whey are notoriouse for burning oil, becasue people use cheap oil filters.
post Jan 22, 2008 - 12:04 PM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
what about on a 7afte? is mobil 1 good enuf or something else shud be used?
post Jan 22, 2008 - 1:06 PM
99Celica
Joined Nov 1, '07
From Santa Barbara, CA
I use Amsoil, works well and actually cleans out the engine. Only problems are it seems to burn and is a little expensive.
post Jan 22, 2008 - 1:18 PM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
Valvoline 5w30 and Wix filters. cheap and gets the job done.
-Brian
post Jan 22, 2008 - 2:27 PM
celicaracer18
Joined May 23, '04
From Meridian, MS
i would suggest toyota, mobil 0ne or k&n filter if you have a corolla, tundra or supra it doesn't matter
Lo-Fi Version Time is now: September 14th, 2026 - 9:03 AM
