> Caliper paint, is not high temp, learned the hard way, lol
post Jan 24, 2008 - 2:00 PM
anyways, heres why.
post Jan 24, 2008 - 2:32 PM
hongkongnerdboy
Joined Jul 26, '07
From riverside,CA
i dont get it
This post has been edited by playr158: Jan 24, 2008 - 2:33 PM
post Jan 24, 2008 - 2:38 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
bummer. Nice shade of red though.
Can one use high-temp paint on calipers though?
post Jan 24, 2008 - 2:52 PM
Rusty
Joined Nov 5, '07
From New Zealand
did you do your strut brace aswell?
post Jan 24, 2008 - 3:02 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
imagine...its hotter in the engine bay than brakes
post Jan 24, 2008 - 3:15 PM
QUOTE(hongkongnerdboy @ Jan 24, 2008 - 2:32 PM) [snapback]634085[/snapback]
i dont get it
look at the heat shield, the paint burned. haha
on the calipers is nice, the strut bar is nice. guess the shield gets too hot everynow and then laugh.gif
it said on the can, high temp. guess not high enough. Anyways lesson learned. rolleyes.gif
post Jan 24, 2008 - 3:50 PM
xruffwvrydax
Joined Dec 19, '07
From Huntington, WV
there should be a base coat that you put on first, it will more than likely be silver. you put that on and it helps for higher temps then you add your other paint on that and it should work.
post Jan 24, 2008 - 6:04 PM
DEATH
Joined Dec 19, '07
From tx
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jan 24, 2008 - 6:11 PM
Celicav
From Virginia
It is actually 1200 Degree paint, and you can get the Dupli Color readily at Autozone, Pep Boys, Advanced Auto, etc. I am planning on painting my head shield too. For the GT, how many bolts do you have to unscrew to get it off?? Thanks
post Jan 24, 2008 - 6:14 PM
DEATH
Joined Dec 19, '07
From tx
3.
And they do make 1600 degree also - just have to look a little harder for it.
EXT: WRC/TRD/404
post Jan 24, 2008 - 6:20 PM
Celicav
From Virginia
QUOTE(DEATH @ Jan 24, 2008 - 4:14 PM) [snapback]634175[/snapback]
3.
3 Bolts??? Look closely at his pic. There are at least 5 bolts on the upper heat shield, then probably 4 on the lower shield! I'm just wondering if there are any hidden that I cannot see.
post Jan 24, 2008 - 6:32 PM
DEATH
Joined Dec 19, '07
From tx
laugh.gif Sorry - was thinking about the turbo heat shield. I haven't had a stock header on a 5S in 3-4 years. laugh.gif
EXT: WRC/TRD/404
post Jan 24, 2008 - 7:01 PM
azian_advanced
Joined Apr 18, '05
From Calgary
powder coating is probably the best method for these kinds of applications.. unless there is a paint that can withstand exhaust temperatures.. iono
post Jan 24, 2008 - 7:53 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
is that masking tape on your intake hose?
I <3 Dustin---07/16/06
post Jan 24, 2008 - 8:36 PM
masking tape hehe
caliper paint is good till about 500*
you're manifold gets to about 1200*
post Jan 24, 2008 - 8:56 PM
Yeah 500deg paint is good for the valve cover but not the heat shield. I painted mine with the 1200deg (or whatever it was) but used a 500deg clear coat on it. The clear started to discolor and peal away, while the 1200deg paint was just fine.
post Jan 24, 2008 - 11:51 PM
Rusty
Joined Nov 5, '07
From New Zealand
well its nice to know that someone liked the job I did on my strut brace :L
post Jan 25, 2008 - 12:25 PM
GriffGirl
Joined Feb 7, '07
I was admiring the strut brace myself, too (now that I'm the new owner of a fancy new strut brace/bar/thingie)
post Jan 25, 2008 - 4:27 PM
yes its masking tape. laugh.gif it adds 25 hp
there is only one hidden bolt, is the one that connects a s shape piece of metal to the engine and manifold. Not difficult to get to.
the rest of screws are all visible. no probl.
Lo-Fi Version Time is now: September 18th, 2026 - 5:12 AM
