> Air Breathers- Who uses it??, ive bought one dunno if i should put it on....
post Feb 18, 2008 - 1:01 AM
MarcoGTS
Joined Oct 11, '06
From Montclair, So. Cal
yeah ive bought one and i was just wondering who have/has used it?? whats the pro and cons?? and where do you install it?? is it good for the engine?? Thanks!
Replies (1 - 9)
post Feb 18, 2008 - 1:45 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
is that the little filter that hooks onto the crank case vent?
94 Celica gt white (sold)
post Feb 18, 2008 - 1:54 AM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
If by crank case you mean valve cover, I think that's what he's talking about.
post Feb 18, 2008 - 2:02 AM
xs94st
Joined Aug 11, '07
From Corona, CA
they are cool to have, mainly just for looks..but i believe that when u get ur car smogged u shouldnt have it on and reconnect the hose between the valve cover and intake manifold.
it pretty much is supposed to minimize the amount of oil that may vaporize and eventually head to the intake mani.
i think.
they are 9.99 for the filter at pepboys.
Pandelica 2.0 in progress.
post Feb 18, 2008 - 2:45 AM
MarcoGTS
Joined Oct 11, '06
haha sorry for bein a noob on this but any pics?? hahaha
post Feb 18, 2008 - 2:49 AM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
if you are indeed talking about pvc libe that usually goes from the rocker cover to the inlet mani you should use a catch can.
the idea of it is to vent positive crank case preasure.
a catch can will catch catch oil that usually would have got back into your inlet mani and hence into your engine, lowering your octane rating of the fuel and taking away hp, and making your plenum all dirty and **** on the inside.
You can either vent the catch can to atmosphere (via the filter you speak of) or run it plump back into the inlet mani.
ok so the arrows are pointing to the catch can (that one i made but you can buy them easily enough) the larger hose comes off the rocker cover, the smaller one is a direct crankcase venting line, and as you can see i have the filter on top so it vents to atmo. Inside there is baffles so the oily air simply cant go straight out the vent is has to negotiate its way past plates and so on, this causes the oil to catch in the bottom, and not go out the filter.
This post has been edited by Cuts_the_Pilot: Feb 18, 2008 - 2:55 AM
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Feb 18, 2008 - 2:59 AM
MarcoGTS
Joined Oct 11, '06
so....u can only use it if you have a turbo??? what happens if its a non-turbo? where do you put it then??
post Feb 18, 2008 - 5:15 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(MarcoGTS @ Feb 17, 2008 - 11:59 PM) [snapback]642705[/snapback]
Yes. You can use it if you are non-turbo. It would go in the exact same place on a Turbo or N/A application.
post Feb 18, 2008 - 8:19 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
just use a catch can, the little filter will endup oil soaked and leak oil onto your engine.
post Feb 19, 2008 - 10:57 AM
crandsberry
Joined Jul 22, '07
From alexandria, VA
this has been talked about on the CAI threads all the time
Okay, as you face the engine:
port on the right edge of the valve cover = fresh air inlet
port on the back edge of the valve cover, w/ a hose to your manifold = funky oily air outlet, incudes the PCV valve which you should be replacing at regular intervals.
Cuts is right, with the gases ported to the manifold it does let all kinds of nastiness build up in there, but the manifold vacuum helps pull the gases out.
As for the air inlet, slap an air breather filter on there.
It looks cool, cuts down on hoses, and it'll pass any emissions check.
OBD-II makes me a sad panda
Lo-Fi Version Time is now: September 15th, 2026 - 6:36 PM
