> car idling at 1000 rpm
post Feb 28, 2008 - 5:17 PM
hongkongnerdboy
Joined Jul 26, '07
From riverside,CA
uhmm no idea.. but is it suppose to? i see peole say 750.... but mines like at 1000 :[
Replies (1 - 10)
post Feb 28, 2008 - 5:28 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
Mine too. When it first starts it sits at 1600, but once it warms up it stays right at 1000.
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Feb 28, 2008 - 5:46 PM
DEATH
Joined Dec 19, '07
From tx
you guys should check the vacuum lines running to your idle control valve - that's not normal. Not that it's a real problem - it will just eat more gas but I personally think the engine runs smoother at 1K then it does @ 750 - probably less wear from some theories I've seen. Any higher than that and you start working into the more wear catagory.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Feb 28, 2008 - 6:00 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Mine idles at like 1100, I've been trying to figure this out too.
post Feb 28, 2008 - 6:11 PM
DEATH
Joined Dec 19, '07
From tx
There is a thread with a decent how to on here about this - search for it and you should find everything you need to know.
EXT: WRC/TRD/404
post Feb 28, 2008 - 6:23 PM
Celicav
From Virginia
What does this have to do with Forced Induction? This topic should be moved.
post Feb 28, 2008 - 6:34 PM
GriffGirl
Joined Feb 7, '07
well thanks for pointing it out, hall monitor
post Feb 28, 2008 - 8:44 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
it may (or may not) have something to do with age and there being carbon buildup on the valves and gunk in the intake and vacuum routing. My old engine had a lot of miles on it and idled high like that. The rebuilt clean one doesn't, idles around 695-780 once it's warm. It took some getting used to at first, I felt like something was wrong. Try some Seafoam.
I <3 Dustin---07/16/06
post Feb 29, 2008 - 3:08 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i bled my friend's coolant lines and it seemed to have fixed his high rpm idle.. not sure exactly how that works but maybe has something to do with the cts.
post Feb 29, 2008 - 9:08 PM
alltracman78
Joined Aug 9, '06
From Ma
Most likely either the ISC valve is bad/gunked up or you have a small vacuum leak [for those of you with the 5S/7A].
It's also possible the ignition timing is off, or a bunch of other small things.
If you really care, begin by checking the first two.
QUOTE(GriffGirl @ Feb 28, 2008 - 6:34 PM) [snapback]647342[/snapback]
post Feb 29, 2008 - 9:19 PM
Rymaster
Joined Feb 20, '08
From Abingdon, Maryland
QUOTE(thespacepanda @ Feb 28, 2008 - 5:28 PM) [snapback]647285[/snapback]
2x
same thing my celica does
Lo-Fi Version Time is now: September 2nd, 2026 - 5:29 AM
