May 17, 2008 - 11:47 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
Hello,
Quick questions, is the starter relay the same as the EFI relay (94 5sfe) I replaced both with new ones because my EFI relay went bad (needed a good smack to work) and in doing so broke the cap off the starter relay and belive it to be broken too as when I try to start the car nothing happens and all other connections etc look good. It was easy to get a new EFI relay but most places did not have the starter relay or were not able to locate it in there system. only napa had it but when I put it in I found they sold me the exact same relay as the EFI? the part numbers on the stock onces are diffarent, the OEM starter relay number is "28300-10020 156700-0503" (both numbers on the cap) I tested where the power going into the relay is and there on diff prongs, I really think there diff and napa screwed me. Also if there diff what would be the harm of using the wrong one other then it not starting? Thanks, Chris. -------------------- ![]() |
May 18, 2008 - 9:48 AM
order one from the dealer.
| Lo-Fi Version | Time is now: July 30th, 2026 - 3:59 PM |
