> rotors warped as car shakes on braking?, probably need new pads and rotors :(
post Jun 12, 2008 - 4:43 PM
Crzybakerdog
Joined Apr 18, '03
From milwaukee, wisconsin
ok so i have neglected getting pads checked so now i think my rotors are warped since the car shakes when pushing the brake pedal. Anyone know where a good deal to order rotors and probably pads is?
post Jun 12, 2008 - 6:57 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
Brembo OEM blank replacement rotors from TireRack and OEM Toyota brake pads from your local dealer.
DO NOT get cross drilled and slotted rotors. Your brakes are too small to take away surface area by drilling holes or making slots which actually makes them less efficient.
I have tried a lot of brake pads. Metallic compound pads will make a whole lot of noise and eat away at your rotors faster and groove them. I have tried ceramic pads and they are significantly quieter for the most part, they still make noise but its a higher pitch which is why you don't hear them most of the time, but the compound is too hard and will warp your rotors again eventually. Since getting OEM replacement pads I have had absolutely no noise ever, and they have worn the rotors nice and even.
This post has been edited by hurley97: Jun 12, 2008 - 6:58 PM
I <3 Dustin---07/16/06
post Jun 19, 2008 - 4:11 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Isn't ceramic compound material what our OEM is?
post Jun 19, 2008 - 4:22 PM
DEATH
Joined Dec 19, '07
From tx
Nah - OEM is organic. Hands down the best compromise between function, wear and sound for our cars.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jun 19, 2008 - 6:34 PM
GriffGirl
Joined Feb 7, '07
Maybe STs have ceramic compound for OEM - I could swear I've seen ceramic recommended as OEM replacement for my car on at least tirerack.com, other sites too I think
post Jun 19, 2008 - 6:43 PM
Tech9ine
Joined Jun 28, '05
From MB, Canada
check your calipers too just incase. i had the same problem and one of the rods on my caliper that put pressure on the pads had siezed, making constant pressure on one portion of the disc. It was the culprit for warping my rotors and causing the shaking.
post Jun 19, 2008 - 7:46 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
stay away from axxis pads. ive had bad experiences with them, even the ceramics
post Jun 19, 2008 - 9:15 PM
monkey
Joined Nov 21, '07
From I-59 -N- 610 Houston, Tx
depending on how bad your rotors are warped you can get them machined down at a dealership or other shop....
post Jun 19, 2008 - 9:23 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE (GriffGirl @ Jun 19, 2008 - 7:34 PM) *
I think they just mean that the compound it's made of meets or exceeds OEM quality, which is what they usually mean even if it isn't true.
post Jun 19, 2008 - 9:57 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
QUOTE (Tech9ine @ Jun 19, 2008 - 6:43 PM) *
When the piston on the caliper seizes up, do you have to replace the whole caliper? Because I think this is what is happening to me.
94 Celica gt white (sold)
post Jun 19, 2008 - 10:01 PM
Tech9ine
Joined Jun 28, '05
From MB, Canada
i think you can get a caliper rebuild kit or something, not too familiar. From what i understand, your ability to pull the pieces of your current caliper are what make this easy or hard. But if that doesnt work you'll want to replace them.
This post has been edited by Tech9ine: Jun 19, 2008 - 10:02 PM
post Jun 20, 2008 - 2:22 PM
creis
Joined Jan 10, '04
From Shoreline, WA
I dont agree with that... (maybe stay away from disks both drilled and slotted but just one of the 2 I dont think takes enough surface away to hurt more then it gains) I've got cross drilled brakes and love them, far better then solid breaks, stopping distance wise and break fade wise. I deff recommend getting cross drilled as long as there a decent brand (no no-name crap) I'm using ceramic pads too and love em (there starting to whare out now but the disks are in great shape.) evenrthing depends on the brands, my disks are brimbos, my pads are raybestes ceramics (sp)
never heard of a caliper rebuild kit.... I dont know if I would trust it though.
This post has been edited by creis: Jun 20, 2008 - 2:23 PM
Lo-Fi Version Time is now: August 29th, 2026 - 12:50 PM
