> amber oil light, amber oil light comes on when driving
post Jun 15, 2008 - 4:15 PM
coly
Joined Jun 15, '08
From n.ireland
hi folk's
just signed up to your forum after accidently coming across it, great site so far
i have recently bought a g6 98 celica but unfortunatly it had no drivers manual with it
and a amber oil light has come on oil level ok and all the rest of the levels are all a 100%
but after driving for a while the light comes on .
can anybody shed any (pardon the pun) light on this problem
muchly appreciated
coly
post Jun 15, 2008 - 6:44 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
it means its sensing low oil pressure.
post Jun 15, 2008 - 10:01 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I think somone knocked the connector off the sensor.
94 Celica gt white (sold)
post Jun 20, 2008 - 7:04 AM
GT202
Joined Feb 14, '07
From UK
common problem on the 3sge, the oil level sensor usually fails and is around £100 from mrT
you can bypass it by connecting the two wires that go to the sensor together
iirc jdm's dont have this warning light anyway
post Jun 20, 2008 - 8:11 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE (GT202 @ Jun 20, 2008 - 8:04 AM) *
Woah - this is an incredibly bad idea. Obviously oil is very critical to your engine's life expectancy. If I were you I would first buy an aftermarket Oil Pressure Gauge for under $20 and hook it up and see if your oil pressure is normal. If so get another new OEM sensor and hook it up. If not and it looks like your sender is reporting that you do indeed have a low oil pressure then you need to take steps to remedy this problem.
Driving around with low oil pressure is a quick way to kill your new engine. Man I can't believe someone on here would give advice like that. mad.gif
QUOTE (bccentaur3 @ Jun 15, 2008 - 11:01 PM) *
Also check this as bccentaur said - it is very easy and very common for this to happen. Happened to me on water temp recently.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jun 20, 2008 - 5:56 PM
GT202
Joined Feb 14, '07
From UK
errm, its a caution light for the oil LEVEL not the oil pressure
and if you look after your car properly you will be doing oil level checks regularly anyway
post Jun 20, 2008 - 6:34 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
No, they're right. The stock sender senses low oil pressure, when the oil level is low the pressure is reduced.
Assuming your sender is not faulty and your level is fine like you say, you could have a problem with your oil pump.
This post has been edited by hurley97: Jun 20, 2008 - 6:37 PM
I <3 Dustin---07/16/06
post Jun 21, 2008 - 2:30 AM
GT202
Joined Feb 14, '07
From UK
UK spec GT has,
amber light = oil level
red light = oil pressure
coly is in the UK
post Jun 21, 2008 - 10:08 AM
coly
Joined Jun 15, '08
From n.ireland
QUOTE (GT202 @ Jun 21, 2008 - 2:30 AM) *
UK spec GT has,
coly is in the UK
cheers everyone for all your sugestions i think GT202 hit the nail on the head usually in the uk
red = for danger
amber = for warning
and this car is a uk spec car, talking to a few helpful diagnostic guys and some say this is a problem the newer toyota's
are experiencing oil level sensor failing, done the usual checks and apart from the light on everything seems ok changed oil and filter just in case.
again cheers everyone for all your sugestions.
next step change oil level sensor i'll let you know how it works out.
coly
post Jun 21, 2008 - 6:36 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
interesting. do the symbols look different or is the only difference in the color?
post Jun 28, 2008 - 2:56 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
I realize this may not apply to you, but my comes on occasionally during hard cornering or if my oil level is low. I've been having issues with my valve seals leaking oil into the cylinder so I usually just change my oil when I have this issue to correct the oil levels.
post Jul 7, 2008 - 1:56 PM
Ugglan
Joined Jan 8, '08
From Sweden
I have the same problem but I have checked the oil pressure and I'm sure the oil level sensor is broken, so I have a paperclip that disconnectiong the kabel so that the light doesn't light up every time...
But now for my question, how much do you pay for a new one? Here in Sweden they are way to expensive...
//Johan
post Jul 16, 2008 - 4:20 AM
nitrate
Joined Jun 20, '06
From Lancashire England UK
I'm in the UK and have a 94GT. The engine is a 3sge and all the time i've owned it the oil level light has always been on. If i knew were the sensor was ( belive me i've looked ) i'd just jump the pins to shut it off. I really don't think the light is nessasary... you should know when your loosing or burning oil. Its nothing to do with the preasure so dont worry about it. If anyone has a piccy of the sensor or can tell me were the plug for it is supposed to be i would apprecite it.
Leigh
post Jul 16, 2008 - 4:23 AM
Ugglan
Joined Jan 8, '08
From Sweden
I don't have a picture today but if you remove the plastic under the enging you should see a cable going in (or hanging loose) at the bottom of the engine. It not that hard to see but I think you have to remove the plastic to get to it...
//Johan
Lo-Fi Version Time is now: September 1st, 2026 - 8:50 PM
