Jun 21, 2008 - 11:27 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 26, '07 From riverside,CA Currently Offline Reputation: 0 (0%) |
recently my car battery died and after i jump started it there was a constant ticking sounds, you hear it from the inside and all the lights including the ac lights and clocks light flicker on and off with the sounds. and if you look outside the side turn lights also flicker on and off with the sounds. does anyone know how to fix this?
-------------------- QUOTE(thespacepanda @ Feb 21, 2008 - 4:37 PM) [snapback]644164[/snapback] When I worked for Pizza Hut our store won a health code violation. |
Jun 22, 2008 - 6:31 AM
recently my car battery died and after i jump started it there was a constant ticking sounds, you hear it from the inside and all the lights including the ac lights and clocks light flicker on and off with the sounds. and if you look outside the side turn lights also flicker on and off with the sounds. does anyone know how to fix this? your battery may have died for a reason. get the alternator checked, it might not be pumping enough juice... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jun 22, 2008 - 4:25 PM
well battery died...from leaving headlights and fogs on >.>
Jun 23, 2008 - 5:27 PM
soo no other helpful advice?
Jun 23, 2008 - 6:26 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
sounds like a short somewhere before a relay for the illumination causing the relay to click on and off
I would have to get the wiring book and look into it more though -------------------- |
Jun 24, 2008 - 6:37 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 27, '02 From Derry,NH USA Currently Offline Reputation: 9 (100%) |
Ticking,like a chiming sound? If so,that could potentially be bad.
| Lo-Fi Version | Time is now: September 12th, 2026 - 5:34 AM |
