Jul 19, 2008 - 12:21 AM
Enthusiast Joined Jul 18, '08 From az Currently Offline Reputation: 0 (0%) |
Hello,on monday I bought my Celica,so I am new.But my question is,why would the car never ever go above 3k RPM?And so far pretty much the top speed I can achieve is around 70 MPH.Anyone have any ideas?the only mods I have done thus far is my short ram intake,and it did it before I installed it. Much thanks,SV
Jul 19, 2008 - 1:11 PM
does it run rough?
Jul 19, 2008 - 4:03 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
is it an automatic?
Jul 19, 2008 - 4:59 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 2, '08 From Fort Worth, Texas Currently Offline Reputation: 9 (100%) |
well i have an auto st and when i just cruizing at low speeds it never goes above 3k but when i stomp on it goes to 6k so i wouldnt thinks its an auto thing
Jul 19, 2008 - 6:01 PM
well an ST should be able to go faster than 70mph, thats for sure :lol: i know theyre slow but not that bad.
Jul 20, 2008 - 12:49 AM
Enthusiast ![]() Joined Jul 4, '08 From rhode island Currently Offline Reputation: 1 (100%) |
her a silly question is your overdrive on or off that would make a difference on rpms, also I would check the timing to make sure it right. I have 95 auto gt it goes way above 3000 rpms. when I am cruise about 75 or 80 it below 3000 rpm.
check all the rountain stuff like spark plugs all that good stuff. Is there a check engine light on? Does it run rough like the other member said? |
Jul 20, 2008 - 12:29 PM
well i have an auto st and when i just cruizing at low speeds it never goes above 3k but when i stomp on it goes to 6k so i wouldnt thinks its an auto thing that's the way the auto transmission shifts. It uses your throttle position to determine when to shift, ie. if you're just cruising your throttle position is probably below say 30% so it shifts at 3k RPM every time, if you're throttle position is say 60% the ECU will determine you're trying to get somewhere faster and let the transmission build up the RPMs to give you more torque. It will also make a difference in gear changes when you have overdrive on or off. With overdrive off it's basically only using 3 of it's 4 gears and changes the shift points accordingly. -------------------- |
Jul 20, 2008 - 1:22 PM
Enthusiast ![]() ![]() Joined Feb 6, '08 From charleston, sc Currently Offline Reputation: 0 (0%) |
about the 70mph thing
my governor is set at 100 so...yeah... ps how do i take the governor off? -------------------- myspace!!
go FULL THROTTLE or go home |
Jul 20, 2008 - 3:19 PM
lol,the only 'governor' on the 7afe is its cut off at 6500ish rpm or its lack of power to push the car any faster. the little geo has been past 100 before, 110 o on the speed and about 6000 rpm on the tach in 3rd (automatic).
Jul 20, 2008 - 6:33 PM
I would not play with the governor unless your use it for drag or race they make it very hard to remove and by pass. I personal would not play with it but I beat there someone who done it.
Jul 20, 2008 - 8:44 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Hello,on monday I bought my Celica,so I am new.But my question is,why would the car never ever go above 3k RPM?And so far pretty much the top speed I can achieve is around 70 MPH.Anyone have any ideas?the only mods I have done thus far is my short ram intake,and it did it before I installed it. Much thanks,SV There are a few things that could cause an artificial 3000rpm rev limit: - Ignition timing is way off - Mechanical timing is way off - Wrong igniter - Wrong coil Have you ran the ECU trouble codes? -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jul 21, 2008 - 12:17 AM
I kinda worded that wrong
Jul 21, 2008 - 12:26 AM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) |
94-95 is OBDI, 96+ has OBDII
Jul 21, 2008 - 8:03 AM
I kinda worded that wrong If you rev it up in neutral does it go above 3500 rpm? -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jul 23, 2008 - 10:42 AM
Enthusiast Joined Dec 25, '07 From Pittsburgh, PA Currently Offline Reputation: 0 (0%) |
Hello,on monday I bought my Celica,so I am new.But my question is,why would the car never ever go above 3k RPM?And so far pretty much the top speed I can achieve is around 70 MPH.Anyone have any ideas?the only mods I have done thus far is my short ram intake,and it did it before I installed it. Much thanks,SV If its an auto check to make sure the overdrive switch is off. |
Jul 24, 2008 - 1:52 AM
Okay,the car is a manual,and if it's in neutral,it still winds up alot at 3k.I am in the process of doing the plugs,(Should of taken like 5 minutes,but Autozone sold me a bent plug.)And aswell,how would I check ignition timing,and mech timing?I have never ventured into transverse mounted engine until now.Much thanks,SV
| Lo-Fi Version | Time is now: June 26th, 2026 - 4:10 AM |
