Jul 23, 2008 - 5:10 AM
Enthusiast ![]() Joined Jul 12, '08 From QLD, Australia Currently Offline Reputation: 0 (0%) |
in my Australia spec 1997 SX theres no beeping for headlights when u leave them on and key off, i was wondering if anyone knew how to add in my own beeper/sound thingy?
Jul 23, 2008 - 8:30 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
I'm not sure where the parts are in the 6th gen celica, but as for the wiring of it, you'd find that little Gold flat Toner and trace the wires back, that'll be your melody box. Replace that. (its got a constant ground, and an Triggered positive, The timer to separate the beeps is built into the melody box)
IDK where to get a custom melody box though... My cousin once took one out of a "Independence Day Alien" so that his lil' S-10 Roared This post has been edited by D-Man: Jul 23, 2008 - 8:31 AM -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Jul 23, 2008 - 12:56 PM
Don't your headlights turn off anyway when you open the door?
Jul 23, 2008 - 12:59 PM
Do yours?
Jul 23, 2008 - 1:13 PM
Yeah, they sure do. They did in my 4Runner too. And now my fancy-pants JDM fogs do too.
Jul 23, 2008 - 4:14 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
they will turn off a min or so after you open the driver's side door. atleast they did in my 97. i wouldn't know in my 99 because my door sensor is messed up and doesn't know when i open the door so they'll just stay running. i'll tell you this much. when i first got my car i kept having to get jump starts
Jul 23, 2008 - 4:18 PM
Not my car... Nope. The lights only turn off by them selfs after the battery is dead. Even then, there is still a little hue of light emitting from them...
This post has been edited by D-Man: Jul 23, 2008 - 4:18 PM -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Jul 23, 2008 - 5:23 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
if you have an alarm/starter (not sure if it goes for all types), your lights will no longer shut off with the ignition..
Jul 23, 2008 - 7:14 PM
I have an alarm and they shut off... but mine's a factory alarm or something, it says Toyota on it. Hmmh.
Jul 23, 2008 - 7:37 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
I'm not sure about Australian models but in both US and Canadian models the wiring for the auto cut-off for the lights is included in the integration relay box.
It's located in the fuse block that is behind the driver side interior kick panel, right under where all the interior fuses are. The alarm theory is not necessarily true, it depends on how it was installed. I have a non-Toyota alarm and my headlights auto shut off just fine. -------------------- |
Jul 23, 2008 - 7:51 PM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
The relay I believe works like this:
i.If the engine is running with the headlights on and then you turn the engine off and open the driver's door the headlights will automatically shutoff. ii.If you turn the headlights on while the car is not running then they wont shutoff if you open the driver's door. You can add a reminder to the system by using two or more relays and some sort of buzzer. -------------------- ![]() 98% completion --- aaRon |
Jul 23, 2008 - 11:26 PM
ohk ill have to test whether they turn off or not, i have a factory alarm buit the chick i got the car off said she had it disabled cause it kept going off, and not the remote shat itself and its heaps to buy a new one and i dont even know if my alarm is good or not
Jul 25, 2008 - 1:29 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
i have no alarm at all and my lights go off if i turn them off or if i open the door
-------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Jul 25, 2008 - 4:30 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
on jdms the headlight circuits are so simple they don't even turn off when the starter motor is cranking (accessories do though), i think you have to have your key out and your door open to hear the monotonous high pitch sound of the headlight warning, because when your key is in you should have a continuous beep beep beep when you open your door (regardless of headlights on/off) to warn you that you left your keys in the car -- this is triggered by a small plastic attachment screwed onto the bottom of your ignition barrel which completes a circuit when the key is in, if you don't have that, then that may be whats stopping your headlamp warning aswell
This post has been edited by delusionz: Jul 25, 2008 - 4:31 AM -------------------- Mike W
Jul 25, 2008 - 8:03 AM
nope my beeping beeps well. But my headlights dont shut-off. Maybe it's the relay that Lubu was talking about...
Jul 25, 2008 - 8:15 AM
my car still beeps when the keys are left in the ignition in the 'OFF' position while the door is open..
but still my headlamps don't shut off even with the keys removed.. there were a few times were my car died because i left my lights on, i couldn't help myself but show off my hids during the day.. lol it was working like it should though before i had my alarm/starter put in This post has been edited by azian_advanced: Jul 25, 2008 - 8:16 AM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Jul 26, 2008 - 3:04 AM
haha just tested how the lights turn off wwhen u take the key out and leave the lights on, it worked and now i feel retarded
| Lo-Fi Version | Time is now: July 31st, 2026 - 11:37 AM |
