Jul 28, 2008 - 6:50 AM
Enthusiast ![]() Joined Nov 13, '06 From AUSTRALIA(MELB) Currently Offline Reputation: 0 (0%) |
hey i have a major problem with my drive shaft and it really $#@!$ piss me off, cause i always have to take of my rim and re-tighten the big 32 ,34 or 36 mm nut that goes on the hub and pulls the drive shaft when tighten.. after that its only good for about a days regular drive and then comes loose again and all you can hear is big CLURKS noises... does anyone know why my drive shaft nut keep coming loose???? please help guys....
thanks |
Jul 28, 2008 - 6:55 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
because it's not tight enough.
If you're talking about the axle nuts, they should be torqued to 159 ft/lbs and there should be a cotterpin that goes through the hole in the axle shaft to keep the nut from coming too far off. -------------------- |
Jul 28, 2008 - 6:59 AM
Enthusiast Joined May 17, '08 From North Liberty, IN Currently Offline Reputation: 0 (0%) |
there should be a castle nut and cotter pin that goes on there to stop it from coming loose.
Jul 28, 2008 - 5:14 PM
yeah i have torqued them both side to 159 ft/lbs and use the castle nut and cotter pin, but it just keeps coming loose again....it like my 6th or 7th time... im really getting tired of it... so what can be the problem??? could it be my clutch?
Jul 28, 2008 - 6:34 PM
how many times did you click the torque wrench?
Jul 28, 2008 - 7:01 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Check the thread on the axle maybe you over-torqued it and damaged the threads on it thats why it keeps coming loose if thats the case you'll have to get a new axle.
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Jul 29, 2008 - 2:13 AM
click only 2 time... i didnt want to over tighten the nut..
Jul 31, 2008 - 3:17 AM
bump
| Lo-Fi Version | Time is now: September 14th, 2026 - 5:55 AM |
