> Error 54, Does error 54 on the st205 slows the car down?
post Aug 4, 2008 - 3:14 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
Hi guys/gals... I own a Rav4 model year 2000 and ive swapped in a 3sgte st205. The engine seem to be perfect but however my check engine light is on... I bridged E1-TE1 and ive detected an error code 54. Ive read in a message posted by insanity on 6gc.net, where he proposed to bridge the coolant level sensor, which i did! But the problem is still persisting, my water pump is working.
Well guys i need help, i dunno if my car's boost has lowered because of the 54 error code? Or is it that i havent changed my fuel pump which is holding my car back? But Rav4 use a 2L fuel pump, n i doubt that this is the problem. Plz advise me:(
Another question, after bridging the sensor, should i take out a fuse or something just to delete the problem from ecu memory?
thnx for all;)
post Aug 4, 2008 - 4:04 AM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
yeh 54 is coolant level,
like you have done bridging the sensor is the cure.
54 puts the car into limp mode, and therefore you need to reset the ecu to clear it, either disconnect the battery for 30 seconds, or pull the efi fuse for 30 seconds.
i like the batt method just to be sure.
this should cure your dramas.
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Aug 4, 2008 - 9:36 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE (Rav4Race @ Aug 4, 2008 - 3:14 AM) *
thnx for all;)
Unless you've kept the ST205 pump wiring exactly the same as it was in the celica you'll need to wire up a relay and resistors at the ECU... Here's a wiring diagram for you:
This post has been edited by WannabeGT4: Aug 4, 2008 - 9:38 AM
post Aug 4, 2008 - 10:18 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
Thnx brothers... In fact i fitted the 3sgte engine together with its ECU gear box etc...complete set...Am praying that i get my car to its top 100% fit as soon as possible:(
When i remove the water cooler cap i can see movements of water when the engine is on, which should mean that the water pump is working right? I bridged the sensor, disconnected battry cable n still engine light on:(
post Aug 4, 2008 - 4:54 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE (Rav4Race @ Aug 4, 2008 - 10:18 AM) *
How did you wire up the charge cooler relay? If you just have the pump wired to run constantly you'll need to install the relay and resistors I refered to in my first post in order to trick the ECU into thinking everything is normal.
post Aug 5, 2008 - 12:35 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
ah ok! i'll try this 1 and let u know! I think i havent done that:p Thnx mate!
post Aug 14, 2008 - 10:17 AM
Rav4Race
Joined Jul 14, '08
From Mauritius
Hi guys..
Got some news:)
Well i sorted out the error 54 code and the power has improved a bit.
But the problem which am now facing is that am getting a low turbo boost:( My turbo is
not boosting more than 0.4 bar:(
Do u think its because i havent changed the rear diff? Am still running with my 1AZ rear diff
but can a diff reduce the turbo boost??
plz help and thnx again bros:)
post Aug 14, 2008 - 4:28 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Glad to see that worked to clear the code 54.
If the rear diff and the center diff are of different ratios you'll be putting the drive train under some serious stress the further out of sync they are. The front wheels will try and spin at a different rate than the rear wheels at the same engine speed. I wouldn't suggest driving it like that for very long/at all if they are of different ratios.
I'd be willing to bet that you're running too lean and getting boost limited and timing pulled due to knock response since you haven't upgraded your fuel pump. The fuel demands of a turbo engine are much higher than those of an NA engine of the same size.
post Sep 17, 2008 - 6:50 AM
3SGTE-auto
Joined Sep 13, '08
From Australia
I have a Carlos Sainz Engine and ECU, and I set up the water pump in on my WTA to run constantly, and I tricked the ECU by simply installing a resistor between the INT wire and ground. This got rid of the Error 54 message... The wiring diagram up there looks more complicated, but probably is correct for that ECU.
post Sep 17, 2008 - 10:19 AM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
x2 on the fuel pump and rear diff.
whether these are the direct causes of your problems or not. BOTH are a very important issue to address before continuing driving the car.
post Sep 17, 2008 - 12:23 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE (3SGTE-auto @ Sep 17, 2008 - 6:50 AM) *
that is the proper procedure for the carlos sainz and rc ecu but the st205 ecu is a little bit smarter and requires advanced trickery to eliminate the code 54.
post Sep 17, 2008 - 7:51 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Make sure you upgrade the fuel pump too. I understand that the fuel pump is a 2L fuel pump, but that was the factory FP. You gotta get something that will supply enough fuel to your 3s.
94 Celica gt white (sold)
Lo-Fi Version Time is now: August 22nd, 2026 - 7:59 AM
