> Help with wiring, 4 gage..
post Aug 20, 2008 - 9:47 AM
sanjuk
Joined Aug 20, '08
From Slough UK
Does anyone have a decent guide on how to wire this car up? I really dont know where to start frown.gif
Replies (1 - 19)
post Aug 20, 2008 - 3:39 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Wire what up?
post Aug 20, 2008 - 4:08 PM
sanjuk
Joined Aug 20, '08
From Slough UK
QUOTE (Spider77 @ Aug 20, 2008 - 4:39 PM) *
Wire what up?
Well i need to wire up the power leads and remote leads but have no idea how to wire them from the battery/headunit to the boot
post Aug 20, 2008 - 4:09 PM
D-Man
Joined Jan 18, '08
From Houston
confused.gif you need to know how to wire a radio?
This post has been edited by D-Man: Aug 20, 2008 - 4:09 PM
Damn D-Man - most impressive.
post Aug 20, 2008 - 5:30 PM
sanjuk
Joined Aug 20, '08
From Slough UK
QUOTE (D-Man @ Aug 20, 2008 - 5:09 PM) *
no but i need the 4 gauge to be wired up to the battery to lead to my boot where my amp is waiting right ? And i also need to know how to get the remote wire from the back of my headunit to my boot where again my amp is waiting smile.gif..Any ideas?
post Aug 20, 2008 - 7:11 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Wow, a 4 gauge remote wire would be insane! SO you pretty much need to run your power (4gauge wire) from the battery to the correct terminal, and the same with the remote (ACC) wire? But dont know how to do it, or where to run it? What do you mean by boot?
post Aug 20, 2008 - 7:14 PM
sanjuk
Joined Aug 20, '08
From Slough UK
QUOTE (Spider77 @ Aug 20, 2008 - 8:11 PM) *
Thats correct about the wires. I dont know how to run them through the car..does anyone have a guide i could use?
Boot = The thing ppl put their subwoofers/amp/shopping in. Usually located at the rear of the car smile.gif
post Aug 20, 2008 - 8:40 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
the boot is what us americans call the trunk of the car. I thought that there was something in the stickies about an amp install but I couldn't really find anything. I think most people run it through the firewall by either drilling a hole then using a grommet or just running it through the big bundle of wires going through there anyways. then they will run the power on one side of the car under the door sills and the output cables on the opposite side to avoid interference. You could always just pull up the carpet and run it that way as well.
Here's a link to the sticky on how to relocate the battery to the trunk/boot you could follow as well.
post Aug 20, 2008 - 9:42 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
just take out the amp for the speakers...
go to crutchfield.com they have everything!!!
This post has been edited by CelicaST_CALI: Aug 20, 2008 - 9:43 PM
BANNED. for life, you moron.
post Aug 21, 2008 - 5:51 AM
sanjuk
Joined Aug 20, '08
From Slough UK
QUOTE (goferris @ Aug 20, 2008 - 9:40 PM) *
I could do this but I still wouldnt know how to get the remote wire to my trunk?
post Aug 21, 2008 - 8:13 AM
D-Man
Joined Jan 18, '08
From Houston
Run a wire from your head units ACC (red usualy) thru a toggle on your dash and then run it under the carpet/back seats to the trunk/ "boot"
Sorry, i've never heard it referred to a boot before, but it does make sense. lol.
post Aug 21, 2008 - 8:36 AM
sanjuk
Joined Aug 20, '08
From Slough UK
QUOTE (D-Man @ Aug 21, 2008 - 9:13 AM) *
lol.
My remote lead is blue smile.gif..what do you mean via a toggle? im assuming the dash and centre console come off easily?
post Aug 21, 2008 - 8:43 AM
D-Man
Joined Jan 18, '08
From Houston
A toggle switch, so that you maintain manuel control over you amp. And yeah, it all comes off pretty easy. Just drop that panel under you steering wheel.
I believe its a total of 4 philips and 4 10mm bolts, and 2 "clips" that just click in and out of place. Easy easy.
And the blue wire off of a head-unit is normally to a power antenna, witch will not give you the power to turn on your amp. Just FYI.
post Aug 21, 2008 - 8:57 AM
sanjuk
Joined Aug 20, '08
From Slough UK
QUOTE (D-Man @ Aug 21, 2008 - 9:43 AM) *
Also to get the power cable from my battery to my "trunk" im going to have to remove the glove box right?
post Aug 21, 2008 - 9:06 AM
D-Man
Joined Jan 18, '08
From Houston
I didn't. I ran threw a hole in the driver side fire wall. Right next to the steering column.
EDIT: oh nevermind, you're UK, you cab is mirrored. My fault.
IDK if you'll have to remove it or not. You'll have to ask some UK guys.
This post has been edited by D-Man: Aug 21, 2008 - 9:07 AM
post Aug 21, 2008 - 9:17 AM
sanjuk
Joined Aug 20, '08
From Slough UK
QUOTE (D-Man @ Aug 21, 2008 - 10:06 AM) *
Thank you for your help so far smile.gif..il let you guys know how i get on tonight
post Aug 21, 2008 - 3:12 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
I think im going to refer to my trunk as a boot from now on, just to confuse people stateside.
post Aug 21, 2008 - 3:13 PM
sanjuk
Joined Aug 20, '08
From Slough UK
So i took my glovebox off..
Engine
found this hole on the top left of the engine..wire went in but had no idea where it went to
Anyone got any ideas..i dont really want to pay £100 to get this done at my local audio place:(
post Aug 21, 2008 - 3:44 PM
D-Man
Joined Jan 18, '08
From Houston
Dude, you realy just gotta figure it out. That's EXACALY what a shop is going to do, they'll just figure it out rolleyes.gif
now if you want to deal with the hassle, then from your battary, you can follow some black lines into the fender, (remove the fender) and run them back into the cab. This is a massive PITA, but if you cant figure out anything else, it's pretty sure-fire. (it'll just take a while laugh.gif )
But i reccomend getting under that glove box, and reaching for that wire. It's where mine is wired thru. Right on the firewall, it's the best place to run it IMO. But IDK if you gotta drop the glove box or what, you'll have to figure that out on your own. Just remember where all your screws go.
post Aug 21, 2008 - 3:57 PM
sanjuk
Joined Aug 20, '08
From Slough UK
QUOTE (D-Man @ Aug 21, 2008 - 4:44 PM) *
whats this firewall you talk about? and what is a fender?
im such a noob:(
Lo-Fi Version Time is now: June 12th, 2026 - 10:18 AM
