> Guess what I did this weekend, st205 w/ e153 - pg5 335whp, vids pg7
post Aug 26, 2008 - 10:30 PM
First off I got a good deal on a st205 engine set (basically everything from a clip) and I bought everything I would need to freshen it up. Then I picked up a low mileage e153 (from a 2000 Camry) and MR2 turbo inners and all-trac outers.
pics from the day I got the engine
^^ Manny (presure2) was pretty excited
then we did some things to the motor
^^ what a mess
mmm clean
the valve cover, heat shield, and intake manifold we coated with a high temp ceramic coating (no pics)
and I lagged the IC with this, thermo-tech
the "lagging" is an adhesive backed aluminized heat barrier which will reduce heat soak with the IC.
cleaned it out and this is what I'm running it in.
then axle madness began
first, 2 sets
then one set
spacer
and spare parts
I then did the wire harness so it would be plug and play for the car. I first wired in a seperat relay box for the IC and fuel pump relays but after I swaped I rewired it to the stock st205 FP and IC replay box, pics later.
not the best pic of the motor but something
then the st205 front end went on (see the 3s in the backround)
I really didn't take too many pics of things because every time I was with the motor, I was doing something to make the swap easier.
then the fun began Friday night - day one
remove motor, clean bay, remove battery tray
put in IC pump
and with st205 puke tank
I'm tired
Saturday - day two
extend the wire harness ? hell no. Cut a hole in the firwall and put harness through.
played with new e153 tranny, clutch, attach to motor and put in car
Sunday - day three - the exhaust. I already have a HKS cat-back so Manny made a b pipe - from the berk dp to the HKS.
started with this
and it became...
tacked and almost finished
done and a quick paint job (that got a little scratched when installed). Manny says "I stand by my exhaust"
and a few installed
and the exhaust cut out from Q T P
I have 3" from the turbo to the cat-back (which is 2.5") so as Corey did we installed a butterfly open exhaust valve. I put in a toggle switch so I can open and close the butterfly whenever I want. Quiet cruising with it closed and all the exhaust goes out the back OR I open it up, it gets loud and free flowing exhaust - no restriction biggrin.gif and more BOOST
put on a new "2000 twin entry turbo" sticker and done for that day.
BTW it started and purred like a CHAMP ! FIRST TRY !!!!!!!!!!!!!111!!!!!1!!!
The car runs great and feels INCREDIBLE.
Now I have had a couple of (expected) problems. The freakin axles.
First, driver's side axle just popped out on a test drive, car towed back to Mannys.
next day, have the axle machined to fit in the tranny and added a 1/2 spacer, good as new.
then on the second test drive the pass side axle popped out. Car towed back to Mannys.
The axle carrier came off the block - the bolts weren't tightened down enough. Sorted that tonight and now it runs perfect, hits boost very well but I think the carrier bearing is bad or the pass side axle is just plain bad. I hear a bit of noise from that side and I think I need another all-trac axle (I think I know where I'll be getting that from) and I'll rebiuld it again. And that's where I'm at right now.
The place all the majic happened was presure2's (Manny) garage and I had some help from Manny & Jenn, my woman Stef (hurley97), and Manny's cousin Joey. A small "pit crew" how each did their thing to help me.
I'll take and post up some finished pics tomorrow night or so, I've had a stressful and busy 4-5 days.
This post has been edited by Batman722: Mar 22, 2009 - 6:43 PM
- Batman722   Guess what I did this weekend   Aug 26, 2008 - 10:30 PM
- - 808celica   RE: Guess what I did this weekend   Aug 26, 2008 - 10:38 PM
- - jcaron9gt4   damn, nice work as usual from you guys   Aug 26, 2008 - 10:49 PM
- - bccentaur3   Dang!!!! I was wondering what you ...   Aug 26, 2008 - 10:52 PM
- - 1bwilson   Looks great! I wish I had a JDM guy shop here ...   Aug 26, 2008 - 11:25 PM
- - 97lestyousay   NIce work guys. someday.... my clip will come in...   Aug 26, 2008 - 11:43 PM
- - j0e_p3t   its threads like these that make me wish i lived o...   Aug 27, 2008 - 1:03 AM
- - malpaso   you are just unbelievable... amazing work Dustin...   Aug 27, 2008 - 1:34 AM
- - purplegt4   my goodness! i was wondering when this would h...   Aug 27, 2008 - 1:57 AM
- - easternpiro1   living near you guys would make me brave enough to...   Aug 27, 2008 - 2:03 AM
- - Rusty   welcome to the world of 3S-GE/3SGTE, nice swork ...   Aug 27, 2008 - 2:11 AM
- - manphibian   i just to you guys.   Aug 27, 2008 - 2:25 AM
- - presure2   yay!   Aug 27, 2008 - 4:08 AM
- - Batman722   I forgot to thank Manny & Jenn, Stef, and Mann...   Aug 27, 2008 - 7:21 AM
- - RUNNIN-LOW   nice nice nice!!!!!!loving...   Aug 27, 2008 - 7:36 AM
- - playr158   Holy crapola....you guys are ridiculous! yet ...   Aug 27, 2008 - 8:06 AM
- - x_itchy_b_x   popping out swaps like its your job! (hint hin...   Aug 27, 2008 - 9:19 AM
- - DEATH   Freakin sweet. Three reasons - 1. I didn't th...   Aug 27, 2008 - 9:37 AM
|- - Batman722   QUOTE (DEATH @ Aug 27, 2008 - 10:37 ...   Aug 27, 2008 - 12:10 PM
|- - 97lestyousay   That looks so f***en clean. is the ps working stil...   Aug 27, 2008 - 12:39 PM
|- - Batman722   QUOTE (97lestyousay @ Aug 27, 2008 - 1...   Aug 27, 2008 - 3:59 PM
|- - Defgeph   QUOTE (97lestyousay @ Aug 27, 2008 - 1...   Aug 29, 2008 - 12:33 AM
- - lagos   1. Make some videos! 2. Get to the dyno. I a...   Aug 27, 2008 - 12:23 PM
- - 95st-celica   great job guy's and girls....really clean work...   Aug 27, 2008 - 12:45 PM
- - NuclearHappineS   2-3 lbs of boost from the cutout means that there ...   Aug 27, 2008 - 12:51 PM
- - RUNNIN-LOW   well humm...at 20psi my buddy got 304 to the wheel...   Aug 27, 2008 - 12:51 PM
- - WALKER   Nice work you guys. Looks great!   Aug 27, 2008 - 1:16 PM
|- - KAOS   QUOTE (WALKER @ Aug 27, 2008 - 12:16...   Aug 27, 2008 - 1:25 PM
- - ETNRIDER   Can my Ceilca come stay with you next weekend?? .....   Aug 27, 2008 - 1:53 PM
- - D-Man   great work guys!! i cant believe you all k...   Aug 27, 2008 - 2:25 PM
- - x_itchy_b_x   being a 6gc OG (Original Gangsta) has it perks.   Aug 27, 2008 - 2:33 PM
|- - D-Man   QUOTE (x_itchy_b_x @ Aug 27, 2008 - 2...   Aug 27, 2008 - 2:49 PM
|- - 97lestyousay   QUOTE (D-Man @ Aug 27, 2008 - 12...   Aug 27, 2008 - 9:00 PM
- - x_itchy_b_x   why wasn't I informed sooner I like to play c...   Aug 27, 2008 - 4:05 PM
- - D-Man   What are you doing with your old engine? it was a ...   Aug 27, 2008 - 4:27 PM
- - DEATH   5S-FE but yeah - you want his cams [I have a sneak...   Aug 27, 2008 - 4:48 PM
|- - presure2   QUOTE (DEATH @ Aug 27, 2008 - 5:48 P...   Aug 27, 2008 - 5:06 PM
- - DEATH   I KNEW you were gonna be the recipient of those ca...   Aug 27, 2008 - 5:11 PM
|- - presure2   QUOTE (DEATH @ Aug 27, 2008 - 6:11 P...   Aug 27, 2008 - 6:00 PM
- - DEATH   Nice - i assumed with the powerband being smoother...   Aug 27, 2008 - 6:04 PM
- - x_itchy_b_x   i expect big gains with them Manny. more lift + du...   Aug 27, 2008 - 6:20 PM
- - DEATH   Exactly [itchy will you be my translator? That...   Aug 27, 2008 - 6:21 PM
- - easternpiro1   whats the ps? and death i think ftmfbbqw means fo...   Aug 27, 2008 - 6:22 PM
|- - Batman722   QUOTE (easternpiro1 @ Aug 27, 2008 - 7...   Aug 27, 2008 - 6:25 PM
- - DEATH   Or passenger side depending on the context. MFBBQW...   Aug 27, 2008 - 6:28 PM
- - zero07   You guys did a great job in such a short time...   Aug 27, 2008 - 6:59 PM
- - snapshotgt   Dustin, here is the picture of my drivers side spa...   Aug 27, 2008 - 11:05 PM
- - Batman722   thanks Snap lookin good !   Aug 27, 2008 - 11:09 PM
- - snapshotgt   You car is officially an animal, congrats.   Aug 28, 2008 - 12:43 AM
- - devilsden97   so this finally hit 6gc.net? lol nice work. soun...   Aug 28, 2008 - 8:45 AM
|- - hurley97   QUOTE (devilsden97 @ Aug 28, 2008 - 9...   Aug 28, 2008 - 8:19 PM
- - jcaron9gt4   so where is your 5's going? i know someone th...   Aug 28, 2008 - 9:42 AM
- - easternpiro1   QUOTE (Batman722 @ Aug 27, 2008 - 7...   Aug 28, 2008 - 8:09 PM
- - Havok1997GT   Unreal job guys. Fantastic work.   Aug 28, 2008 - 9:53 PM
- - SeverX13   it look sooo clean. i love it. props! i...   Aug 28, 2008 - 10:38 PM
- - stetsonaw   looks great!   Aug 30, 2008 - 1:28 PM
- - Batman722   and some info for others. when I got the motor I n...   Sep 8, 2008 - 4:53 PM
- - Batman722   oh yea, read this site a few times over. http://w...   Sep 8, 2008 - 5:03 PM
- - azian_advanced   as i said before, good job to you and to the peopl...   Sep 8, 2008 - 7:07 PM
- - jeffrosie   Hi batman722, very impressed with the work you hav...   Sep 12, 2008 - 1:39 PM
- - Batman722   QUOTE (azian_advanced @ Sep 8, 2008 - 8...   Sep 18, 2008 - 9:56 PM
|- - DEATH   QUOTE (Batman722 @ Sep 18, 2008 - 9...   Sep 19, 2008 - 9:44 AM
- - x_itchy_b_x   QUOTE (Batman722 @ Sep 18, 2008 - 10...   Sep 18, 2008 - 10:58 PM
- - jeffrosie   Thanks for the headsup on the axles batman, about ...   Sep 19, 2008 - 7:44 PM
|- - Batman722   QUOTE (jeffrosie @ Sep 19, 2008 - 8...   Sep 22, 2008 - 11:16 AM
- - lagos   damn you. I get a rocking 19mpg.   Sep 22, 2008 - 1:52 PM
- - jgreening   Looks great, Dustin. Congrats on the swap. I kne...   Sep 22, 2008 - 1:56 PM
- - playr158   out of curiosity did you get an OBD2 motor?   Sep 22, 2008 - 2:05 PM
|- - presure2   QUOTE (playr158 @ Sep 22, 2008 - 3:0...   Sep 22, 2008 - 2:40 PM
- - Batman722   2 quick vids first is just a small pull 2nd to 3r...   Sep 22, 2008 - 5:08 PM
- - lagos   cutout sounds nice dude.   Sep 22, 2008 - 5:24 PM
- - DEATH   Sweet   Sep 22, 2008 - 5:59 PM
- - Batman722   those vids suck, I know. I will have better vids s...   Sep 22, 2008 - 8:45 PM
- - 97lestyousay   That cutout is the ****, the first one looks like ...   Sep 24, 2008 - 12:56 AM
- - zero07   Sounds good............ but stop teasing us and po...   Sep 24, 2008 - 8:31 AM
- - Daftboy   yea it looks like the circle by pressure2's ho...   Sep 24, 2008 - 8:55 AM
|- - presure2   QUOTE (Daftboy @ Sep 24, 2008 - 9:55...   Sep 24, 2008 - 9:17 AM
- - _mikeE   I really like how you placed that wideband meter, ...   Sep 25, 2008 - 1:03 AM
- - Batman722   the single pod was made by an overseas member here...   Sep 25, 2008 - 7:10 AM
- - Daftboy   When you taking this to the dyno....I want to see ...   Sep 25, 2008 - 8:09 AM
- - 6strngs   that's F'in sweet dude! congrats on th...   Oct 16, 2008 - 1:32 AM
- - Batman722   just a quick update. I installed some tworus bras...   Oct 27, 2008 - 12:08 PM
- - 95celgt   yea dustin, get rid of them, what i learned recent...   Oct 28, 2008 - 4:38 PM
- - Batman722   went to the dyno today, I thought Jim was coming u...   Feb 7, 2009 - 11:54 PM
- - lagos   it looks like youre running out of fuel.   Feb 8, 2009 - 12:36 AM
|- - presure2   QUOTE (lagos @ Feb 8, 2009 - 12:36 A...   Feb 8, 2009 - 8:01 AM
- - lagos   I was going to say, that **** looked crazy lean......   Feb 8, 2009 - 10:53 AM
|- - presure2   QUOTE (lagos @ Feb 8, 2009 - 10:53 A...   Feb 8, 2009 - 10:55 AM
- - _Jim_   Great numbers Dustin, please send me the run files...   Feb 8, 2009 - 11:01 AM
- - supershannon77   Awesome Dustin congrats   Feb 8, 2009 - 11:56 AM
- - lagos   Further proof that Dustin is THE MAN!   Feb 8, 2009 - 12:05 PM
- - Defgeph   Now thats what I call fried chicken. Thats bomb r...   Feb 8, 2009 - 1:02 PM
- - Batman722   thanks guys. Yeah I was a little drunk last night...   Feb 8, 2009 - 1:13 PM
- - Batman722   hey Manny, post the pic of my car on the dyno ...   Feb 8, 2009 - 1:16 PM
- - x_itchy_b_x   AWESOME numbers.   Feb 8, 2009 - 2:05 PM
- - manphibian   Big numbers! Nice work   Feb 8, 2009 - 5:00 PM
- - Fate   wow that is awesome. is this what i have to look f...   Feb 8, 2009 - 7:28 PM
- - Supersprynt   You guys are putting 6GCs on the map! Nice wor...   Feb 8, 2009 - 10:52 PM
- - _Jim_   That is pretty consistent results, proving what t...   Feb 8, 2009 - 11:00 PM
- - playr158   WOOOHOOOO Dustin! thanks for the call letting...   Feb 9, 2009 - 7:22 AM
Lo-Fi Version Time is now: August 11th, 2026 - 2:29 PM
