Aug 26, 2008 - 10:30 PM
First off I got a good deal on a st205 engine set (basically everything from a clip) and I bought everything I would need to freshen it up. Then I picked up a low mileage e153 (from a 2000 Camry) and MR2 turbo inners and all-trac outers.
pics from the day I got the engine ![]() ![]() ![]() ![]() ![]() ![]() ^^ Manny (presure2) was pretty excited then we did some things to the motor ![]() ![]() ![]() ^^ what a mess ![]() mmm clean the valve cover, heat shield, and intake manifold we coated with a high temp ceramic coating (no pics) and I lagged the IC with this, thermo-tech the "lagging" is an adhesive backed aluminized heat barrier which will reduce heat soak with the IC. ![]() ![]() ![]() ![]() cleaned it out and this is what I'm running it in. ![]() then axle madness began first, 2 sets ![]() then one set ![]() spacer ![]() ![]() ![]() and spare parts ![]() I then did the wire harness so it would be plug and play for the car. I first wired in a seperat relay box for the IC and fuel pump relays but after I swaped I rewired it to the stock st205 FP and IC replay box, pics later. not the best pic of the motor but something ![]() then the st205 front end went on (see the 3s in the backround) ![]() I really didn't take too many pics of things because every time I was with the motor, I was doing something to make the swap easier. then the fun began Friday night - day one ![]() ![]() ![]() ![]() remove motor, clean bay, remove battery tray put in IC pump ![]() ![]() ![]() and with st205 puke tank ![]() I'm tired ![]() ![]() Saturday - day two extend the wire harness ? hell no. Cut a hole in the firwall and put harness through. ![]() played with new e153 tranny, clutch, attach to motor and put in car ![]() ![]() Sunday - day three - the exhaust. I already have a HKS cat-back so Manny made a b pipe - from the berk dp to the HKS. started with this ![]() and it became... ![]() tacked and almost finished ![]() done and a quick paint job (that got a little scratched when installed). Manny says "I stand by my exhaust" ![]() and a few installed ![]() ![]() and the exhaust cut out from Q T P ![]() I have 3" from the turbo to the cat-back (which is 2.5") so as Corey did we installed a butterfly open exhaust valve. I put in a toggle switch so I can open and close the butterfly whenever I want. Quiet cruising with it closed and all the exhaust goes out the back OR I open it up, it gets loud and free flowing exhaust - no restriction put on a new "2000 twin entry turbo" sticker and done for that day. BTW it started and purred like a CHAMP ! FIRST TRY !!!!!!!!!!!!!111!!!!!1!!! The car runs great and feels INCREDIBLE. Now I have had a couple of (expected) problems. The freakin axles. First, driver's side axle just popped out on a test drive, car towed back to Mannys. next day, have the axle machined to fit in the tranny and added a 1/2 spacer, good as new. then on the second test drive the pass side axle popped out. Car towed back to Mannys. The axle carrier came off the block - the bolts weren't tightened down enough. Sorted that tonight and now it runs perfect, hits boost very well but I think the carrier bearing is bad or the pass side axle is just plain bad. I hear a bit of noise from that side and I think I need another all-trac axle (I think I know where I'll be getting that from) and I'll rebiuld it again. And that's where I'm at right now. The place all the majic happened was presure2's (Manny) garage and I had some help from Manny & Jenn, my woman Stef (hurley97), and Manny's cousin Joey. A small "pit crew" how each did their thing to help me. I'll take and post up some finished pics tomorrow night or so, I've had a stressful and busy 4-5 days. This post has been edited by Batman722: Mar 22, 2009 - 6:43 PM -------------------- |
Batman722 Guess what I did this weekend Aug 26, 2008 - 10:30 PM
808celica RE: Guess what I did this weekend Aug 26, 2008 - 10:38 PM
jcaron9gt4 damn, nice work as usual from you guys Aug 26, 2008 - 10:49 PM
bccentaur3 Dang!!!! I was wondering what you ... Aug 26, 2008 - 10:52 PM
1bwilson Looks great! I wish I had a JDM guy shop here ... Aug 26, 2008 - 11:25 PM
97lestyousay NIce work guys. someday.... my clip will come in... Aug 26, 2008 - 11:43 PM
j0e_p3t its threads like these that make me wish i lived o... Aug 27, 2008 - 1:03 AM
malpaso you are just unbelievable... amazing work Dustin... Aug 27, 2008 - 1:34 AM
purplegt4 my goodness! i was wondering when this would h... Aug 27, 2008 - 1:57 AM
easternpiro1 living near you guys would make me brave enough to... Aug 27, 2008 - 2:03 AM
Rusty welcome to the world of 3S-GE/3SGTE, nice swork
... Aug 27, 2008 - 2:11 AM
manphibian i just to you guys. Aug 27, 2008 - 2:25 AM
presure2 yay! Aug 27, 2008 - 4:08 AM
Batman722 I forgot to thank Manny & Jenn, Stef, and Mann... Aug 27, 2008 - 7:21 AM
RUNNIN-LOW nice nice nice!!!!!!loving... Aug 27, 2008 - 7:36 AM
playr158 Holy crapola....you guys are ridiculous!
yet ... Aug 27, 2008 - 8:06 AM
x_itchy_b_x popping out swaps like its your job! (hint hin... Aug 27, 2008 - 9:19 AM
DEATH Freakin sweet. Three reasons -
1. I didn't th... Aug 27, 2008 - 9:37 AM
Batman722 QUOTE (DEATH @ Aug 27, 2008 - 10:37 ... Aug 27, 2008 - 12:10 PM
97lestyousay That looks so f***en clean. is the ps working stil... Aug 27, 2008 - 12:39 PM
Batman722 QUOTE (97lestyousay @ Aug 27, 2008 - 1... Aug 27, 2008 - 3:59 PM
Defgeph QUOTE (97lestyousay @ Aug 27, 2008 - 1... Aug 29, 2008 - 12:33 AM
lagos 1. Make some videos!
2. Get to the dyno. I a... Aug 27, 2008 - 12:23 PM
95st-celica great job guy's and girls....really clean work... Aug 27, 2008 - 12:45 PM
NuclearHappineS 2-3 lbs of boost from the cutout means that there ... Aug 27, 2008 - 12:51 PM
RUNNIN-LOW well humm...at 20psi my buddy got 304 to the wheel... Aug 27, 2008 - 12:51 PM
WALKER Nice work you guys. Looks great! Aug 27, 2008 - 1:16 PM
KAOS QUOTE (WALKER @ Aug 27, 2008 - 12:16... Aug 27, 2008 - 1:25 PM
ETNRIDER Can my Ceilca come stay with you next weekend?? ..... Aug 27, 2008 - 1:53 PM
D-Man great work guys!! i cant believe you all k... Aug 27, 2008 - 2:25 PM
x_itchy_b_x being a 6gc OG (Original Gangsta) has it perks. Aug 27, 2008 - 2:33 PM
D-Man QUOTE (x_itchy_b_x @ Aug 27, 2008 - 2... Aug 27, 2008 - 2:49 PM
97lestyousay QUOTE (D-Man @ Aug 27, 2008 - 12... Aug 27, 2008 - 9:00 PM
x_itchy_b_x why wasn't I informed sooner I like to play c... Aug 27, 2008 - 4:05 PM
D-Man What are you doing with your old engine? it was a ... Aug 27, 2008 - 4:27 PM
DEATH 5S-FE but yeah - you want his cams [I have a sneak... Aug 27, 2008 - 4:48 PM
presure2 QUOTE (DEATH @ Aug 27, 2008 - 5:48 P... Aug 27, 2008 - 5:06 PM
DEATH I KNEW you were gonna be the recipient of those ca... Aug 27, 2008 - 5:11 PM
presure2 QUOTE (DEATH @ Aug 27, 2008 - 6:11 P... Aug 27, 2008 - 6:00 PM
DEATH Nice - i assumed with the powerband being smoother... Aug 27, 2008 - 6:04 PM
x_itchy_b_x i expect big gains with them Manny. more lift + du... Aug 27, 2008 - 6:20 PM
DEATH Exactly [itchy will you be my translator? That... Aug 27, 2008 - 6:21 PM
easternpiro1 whats the ps? and death i think ftmfbbqw means fo... Aug 27, 2008 - 6:22 PM
Batman722 QUOTE (easternpiro1 @ Aug 27, 2008 - 7... Aug 27, 2008 - 6:25 PM
DEATH Or passenger side depending on the context.
MFBBQW... Aug 27, 2008 - 6:28 PM
zero07 You guys did a great job in such a short time... Aug 27, 2008 - 6:59 PM
snapshotgt Dustin, here is the picture of my drivers side spa... Aug 27, 2008 - 11:05 PM
Batman722 thanks Snap lookin good ! Aug 27, 2008 - 11:09 PM
snapshotgt You car is officially an animal, congrats. Aug 28, 2008 - 12:43 AM
devilsden97 so this finally hit 6gc.net? lol
nice work.
soun... Aug 28, 2008 - 8:45 AM
hurley97 QUOTE (devilsden97 @ Aug 28, 2008 - 9... Aug 28, 2008 - 8:19 PM
jcaron9gt4 so where is your 5's going?
i know someone th... Aug 28, 2008 - 9:42 AM
easternpiro1 QUOTE (Batman722 @ Aug 27, 2008 - 7... Aug 28, 2008 - 8:09 PM
Havok1997GT Unreal job guys. Fantastic work. Aug 28, 2008 - 9:53 PM
SeverX13 it look sooo clean. i love it.
props!
i... Aug 28, 2008 - 10:38 PM
stetsonaw looks great! Aug 30, 2008 - 1:28 PM
Batman722 and some info for others.
when I got the motor I n... Sep 8, 2008 - 4:53 PM
Batman722 oh yea, read this site a few times over.
http://w... Sep 8, 2008 - 5:03 PM
azian_advanced as i said before, good job to you and to the peopl... Sep 8, 2008 - 7:07 PM
jeffrosie Hi batman722, very impressed with the work you hav... Sep 12, 2008 - 1:39 PM
Batman722 QUOTE (azian_advanced @ Sep 8, 2008 - 8... Sep 18, 2008 - 9:56 PM
DEATH QUOTE (Batman722 @ Sep 18, 2008 - 9... Sep 19, 2008 - 9:44 AM
x_itchy_b_x QUOTE (Batman722 @ Sep 18, 2008 - 10... Sep 18, 2008 - 10:58 PM
jeffrosie Thanks for the headsup on the axles batman, about ... Sep 19, 2008 - 7:44 PM
Batman722 QUOTE (jeffrosie @ Sep 19, 2008 - 8... Sep 22, 2008 - 11:16 AM
lagos damn you. I get a rocking 19mpg. Sep 22, 2008 - 1:52 PM
jgreening Looks great, Dustin. Congrats on the swap. I kne... Sep 22, 2008 - 1:56 PM
playr158 out of curiosity did you get an OBD2 motor? Sep 22, 2008 - 2:05 PM
presure2 QUOTE (playr158 @ Sep 22, 2008 - 3:0... Sep 22, 2008 - 2:40 PM
Batman722 2 quick vids
first is just a small pull 2nd to 3r... Sep 22, 2008 - 5:08 PM
lagos cutout sounds nice dude. Sep 22, 2008 - 5:24 PM
DEATH Sweet Sep 22, 2008 - 5:59 PM
Batman722 those vids suck, I know. I will have better vids s... Sep 22, 2008 - 8:45 PM
97lestyousay That cutout is the ****, the first one looks like ... Sep 24, 2008 - 12:56 AM
zero07 Sounds good............ but stop teasing us and po... Sep 24, 2008 - 8:31 AM
Daftboy yea it looks like the circle by pressure2's ho... Sep 24, 2008 - 8:55 AM
presure2 QUOTE (Daftboy @ Sep 24, 2008 - 9:55... Sep 24, 2008 - 9:17 AM
_mikeE I really like how you placed that wideband meter, ... Sep 25, 2008 - 1:03 AM
Batman722 the single pod was made by an overseas member here... Sep 25, 2008 - 7:10 AM
Daftboy When you taking this to the dyno....I want to see ... Sep 25, 2008 - 8:09 AM
6strngs that's F'in sweet dude! congrats on th... Oct 16, 2008 - 1:32 AM
Batman722 just a quick update.
I installed some tworus bras... Oct 27, 2008 - 12:08 PM
95celgt yea dustin, get rid of them, what i learned recent... Oct 28, 2008 - 4:38 PM
Batman722 went to the dyno today, I thought Jim was coming u... Feb 7, 2009 - 11:54 PM
lagos it looks like youre running out of fuel. Feb 8, 2009 - 12:36 AM
presure2 QUOTE (lagos @ Feb 8, 2009 - 12:36 A... Feb 8, 2009 - 8:01 AM
lagos I was going to say, that **** looked crazy lean...... Feb 8, 2009 - 10:53 AM
presure2 QUOTE (lagos @ Feb 8, 2009 - 10:53 A... Feb 8, 2009 - 10:55 AM
_Jim_ Great numbers Dustin, please send me the run files... Feb 8, 2009 - 11:01 AM
supershannon77 Awesome Dustin congrats Feb 8, 2009 - 11:56 AM
lagos Further proof that Dustin is THE MAN! Feb 8, 2009 - 12:05 PM
Defgeph Now thats what I call fried chicken. Thats bomb r... Feb 8, 2009 - 1:02 PM
Batman722 thanks guys.
Yeah I was a little drunk last night... Feb 8, 2009 - 1:13 PM
Batman722 hey Manny, post the pic of my car on the dyno ... Feb 8, 2009 - 1:16 PM
x_itchy_b_x AWESOME numbers. Feb 8, 2009 - 2:05 PM
manphibian Big numbers! Nice work Feb 8, 2009 - 5:00 PM
Fate wow that is awesome. is this what i have to look f... Feb 8, 2009 - 7:28 PM
Supersprynt You guys are putting 6GCs on the map! Nice wor... Feb 8, 2009 - 10:52 PM
_Jim_ That is pretty consistent results, proving what t... Feb 8, 2009 - 11:00 PM
playr158 WOOOHOOOO Dustin!
thanks for the call letting... Feb 9, 2009 - 7:22 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 10:35 PM |
