> What parts can or cant buy here in US for 3 Gen 3s?
post Sep 6, 2008 - 5:59 PM
erahman85
Joined Aug 29, '07
From San Diego
Well I am about to buy a front clip with 3rd gen 3s but I was thinking that I want to replace gaskets and misc parts but do all the 2nd gen parts fit on the 3rd gen 3sgte?
post Sep 6, 2008 - 6:44 PM
QUOTE (erahman85 @ Sep 6, 2008 - 6:59 PM) *
www.kbox.ca carries a bunch of 3rd gen specific parts, there are a few threads with PT #s ect in it over on mr2oc.
as well as the thread found here in the stickys.
i suggest spending a bit of time reading thru those threads, there is lots of good information to be had if you search for it.
http://www.6gc.net/forums/index.php?showtopic=56652
post Sep 8, 2008 - 11:41 AM
erahman85
Joined Aug 29, '07
From San Diego
so all those parts listed are not interchangeable???
post Sep 8, 2008 - 4:58 PM
http://mr2oc.com/showthread.php?t=113
post Sep 9, 2008 - 5:59 PM
for a beams and 3sgte engine they only had gasket set, what about pistons and stuff?
post Sep 9, 2008 - 8:23 PM
CELL_PROTOTYPE_X
Joined Aug 7, '05
From Columbus OH
Pretty sure 2nd and 3rd Gen 3sgte motors share the same internal parts, so cams, valvetrain, headgasket, pistons, rods.
QUOTE (njccmd2002 @ Sep 9, 2008 - 5:59 PM) *
post Sep 9, 2008 - 8:41 PM
erahman85
Joined Aug 29, '07
From San Diego
Well that's good. I was looking to do some maintenance work before I put the engine in the car. So we'll see. I suppose I could buy the parts and if they don't fit I'll return them.
post Sep 10, 2008 - 4:40 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
pistons, rod, crank, exhaust cam, cam gears, valves, springs are interchangeable, you can interchange the gen3 intake cam with gen 2 on but you will loose some duration and some lift. For the Headgasket, toyota use different P/N for gen2 and gen3... but I guess they are interchangeable.
post Sep 11, 2008 - 1:33 AM
QUOTE (pitcelica @ Sep 10, 2008 - 5:40 PM) *
sweet jesus no.
^^st185 single layer paper type
^^st205 multi-layer steel type
and both
the 205 hg is 1.4mm while the 185 is 1mm and the 205 has more jacket holes.
post Sep 12, 2008 - 2:17 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
ok, thanks for the clarification, I was assuming that if you can put a gen3 head on a gen2 block, the headgaskets would be interchangeable.
Lo-Fi Version Time is now: August 22nd, 2026 - 3:50 AM
