> 4age trans bolt up to 7afe?, transmissions
post Sep 12, 2008 - 12:52 PM
j0ch0a94ST
Joined Sep 27, '07
From Raleigh, NC
i've been having some slippage issues with my 94st...i was curious if anyone knew if the 4age transmission would bolt up directly to my 7afe? would there be any issues that i should take into consideration before attempting the swap? thanks
post Sep 12, 2008 - 1:17 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
QUOTE (j0ch0a94ST @ Sep 12, 2008 - 1:52 PM) *
It should bolt up as long as your not using the 4age transmission off the MR2s where the shifters are reversed. Use all bolts and mounts off your old tranny. Clutch, flywheel and everything else is the same on the 4age.
post Sep 15, 2008 - 12:05 PM
j0ch0a94ST
Joined Sep 27, '07
From Raleigh, NC
QUOTE (soulshadow @ Sep 12, 2008 - 1:17 PM) *
hey i really appeciate the help.
post Sep 19, 2008 - 7:56 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
They bolt up but the 4AGE trans are geared differently and will run the motor normally around 500 or so rpms faster. Might not really be a good thing...
Lo-Fi Version Time is now: August 11th, 2026 - 10:58 PM
