> HELP WITH OVERDRIVE TRANSMISSION, I NEED TO KNOW WHAT OVERDRIVE DOES??
post Oct 15, 2008 - 10:06 PM
BlazedInMyCeli
Joined Oct 15, '08
From Florida
i recently purchased an automatic 97 celica ST hatchback. I have been wondering if most people leave there car in or out of overdrive? Any benefits to better mpg with overdrive??? what exactly does overdrive do?
post Oct 15, 2008 - 10:09 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Overdrive is basically like a 5th gear for automatics. I recommend keeping it on.
post Oct 15, 2008 - 10:11 PM
Add45
Joined Sep 1, '08
From STL
QUOTE (GotToyota @ Oct 15, 2008 - 11:09 PM) *
exactly...
unless for some reason you need alot of acceleration and your in like 4th gear...
over drive keeps rpms low which is want you want for more mpgs
This post has been edited by Add45: Oct 15, 2008 - 10:12 PM
post Oct 16, 2008 - 1:03 AM
xredjokerx
Joined Apr 18, '08
From Oakland, bay area, California
i thought overdrive WAS 4th gear...
when overdrive is off it stays on third right? otherwise theres no way to get to third... since it shifts from 1-2-4 right?
post Oct 16, 2008 - 6:40 AM
3SGTE-auto
Joined Sep 13, '08
From Australia
Red joker is right. Overdrive gear is gear #4. Its called od because its gear ratio is less than 1, which means it delivers more rpm to the final drive (differential) gear than the rpm of the engine. Turn off overdrive when hauling heavy loads, to help preserve the 4th gear in your transmission. OD off will mean you can only use gears 1,2&3. Otherwise, leave it enabled (due to is nature of being overdrive, it is therefore the gear that is more likely to get damaged from friction or physical stress). The U140 transmission in some late model corollas is a rare example of a fwd trans that has no overdrive gear: it's 4th gear is ratio of 1. And yet, the U140 and the A140 use almost the same rpm as each other in each gear. Its able to achieve this by using a different final drive ratio.
This post has been edited by 3SGTE-auto: Oct 16, 2008 - 7:00 AM
post Oct 16, 2008 - 8:38 AM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
Leave it on...it lowers RPM by about 1k in each gear.
This post has been edited by RickJamesBish: Oct 16, 2008 - 8:38 AM
post Oct 17, 2008 - 2:29 PM
enderswift
Joined Jul 12, '08
im pretty sure overdrive is a run mode for the transmission where the torque converter locks with the flywheel (usually above 40 mph), thus giving you highway cruise mileage like a manual. I've never heard of it being a separate gear... Turning overdrive off allows the flywheel to spin faster than the torque converter, which multiplies torque but wastes gas.
i've been wrong before, but im confident with this assumption
post Oct 18, 2008 - 2:55 AM
3SGTE-auto
Joined Sep 13, '08
From Australia
QUOTE (enderswift @ Oct 17, 2008 - 3:29 PM) *
That would be incorrect. Try turning off the OD button, and then count the times the car shifts gears as you accelerate on the freeway. Also, look up the definition of "Overdrive". Overdrive is defined as an transmission putting out output which is faster than the input speed (RPM).
The torque converter lockup is something that should occur automatically, and in the electronically controlled transmissions, this is controlled to occur when there the engine is not under heavy load and when at crusing speed.
post Oct 18, 2008 - 7:50 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
3SGTE-auto is right
The basics of it is this, the Celica's automatic transmissions are 4 speeds
L = 1st gear
2 = 1st and 2nd gears
D = 1st thru 3rd gears
O/D = 1st thru 4th gears
I <3 Dustin---07/16/06
Lo-Fi Version Time is now: September 13th, 2026 - 12:00 PM
