Nov 1, 2008 - 3:31 PM
Enthusiast Joined Oct 16, '08 From New York Currently Offline Reputation: 0 (0%) |
I have just installed a 45 trim, 7lb externally waste gated turbo... when I puut in the two bar map sensor and the 7m-ge injectors, and the 1 step colder spark pulgs gapped to .030 I had a problem.
I'm idling around around 4 or 5 hundred and I have trouble getting above like 5300. I think Its two separate issues. The idle issue is probably due to injectors and colder plugs and should be fixed with a safc II. But my boost gauge isn't hooked up yet so I think the top end may be a "too much boost" problem. can anyone think of a different reason? I think my waste gate might be seized up or something??? |
94silverbullet rpm issues Nov 1, 2008 - 3:31 PM
presure2 if your using the 315cc injectors, your asking for... Nov 1, 2008 - 7:36 PM
94silverbullet The gauge is in its a two second fix I just need ... Nov 2, 2008 - 6:05 PM
94silverbullet Better way to ask you about the injectors, which w... Nov 2, 2008 - 8:18 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 7:53 AM |
