> Need help after installing fpr and fuel pump, and car sputters
post Nov 8, 2008 - 12:49 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
Well I been gathering parts for mycar ., supras 550, fpr, walbaro fuel pump, powerfc , 3inch downpipe, a slightly bigger charge cooler for my w/a setup and next on the list is the ct20b and a tune biggrin.gif
well today i decided i wanted to install the fpr, injectors, and the fuel pump raise the bost to 15 psi . After iam finish i start up the car and it idles good, so i let it warm up and take it for a spin. iam on second gear and decide to revved up a little , i reached 4500 rpm and the car sputters really bad. (btw this is on 8 psi) so i go home and check the fpr, and it reads 55psi. ..... I tought it should be 35-38? well now iam stumped on why my car is running bad so any help is really appreciated.
Replies (1 - 19)
post Nov 8, 2008 - 1:26 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
what brand fpr do you have? I'm hoping its not the cheap ebay crap.
94 Celica gt white (sold)
post Nov 8, 2008 - 8:47 AM
_Jim_
Joined Sep 22, '08
From Bergenfield
so it sounds as tho you have a GEN2 3SGTE. So you installed the 550cc injectors, did you also install your PowerFC, and tune for them. If not then that is your problem. And for what is is worth, you wont really NEED the PowerFC with you setup. Especially now, with you being on the ct26 (from what it sounds) you have plenty of fuel even for 15 psi with your stock 440cc injectors, walboro fuel pump, and FPR. You can go about 275whp on those injectors, you wont be able to get anywhere close to that with the ct26. Depending on how much boost you want to run, you will have trouble reaching the limits with the CT20B. You will be able to run about 18 psi and be around 270ish WHP. Just something else to throw at you, hope it helps. But back to your original question, if you haven't tunned for your new 550cc injectors, then that is your problem.
330whp 309ft/lbs @ 21 PSI
post Nov 8, 2008 - 11:48 AM
^ listen to this guy, he knows what hes talking about.
You also installed an fpr and say its reading high. Did you try adjusting it, with the vac line disconnected?
post Nov 8, 2008 - 2:32 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
QUOTE (_Jim_ @ Nov 8, 2008 - 7:47 AM) *
no ihvent installed my power fc yet cause it hasnt arrived in the mail. well i guess ill have to go back to the 440s from what your telling me but what is the fpr suppose to read? i heard 38 psi but idk btw i have 2nd gen 3sgte and a Aeromotive FPR
oh btw i checked the spark plugs and on the tip it looks like a white spot....
post Nov 8, 2008 - 2:58 PM
the fpr is ADJUSTABLE. Meaning that you ADJUST it to the base pressure that you want.
And yes, you need to put your 440s back in. There is no reason to run 550s with the ct26 or ct20b.
This post has been edited by lagos: Nov 8, 2008 - 2:59 PM
post Nov 8, 2008 - 6:23 PM
QUOTE (_Jim_ @ Nov 8, 2008 - 8:47 AM) *
great post jim.
follow jim and arts advice, you dont need the 550s, your choking on fuel.
post Nov 8, 2008 - 7:21 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
QUOTE (presure2 @ Nov 8, 2008 - 5:23 PM) *
great post jim.
post Nov 9, 2008 - 2:24 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
well i did put my 440 injectors back and the cars still sputter, also i cant seem to get fpr lower than 55psi .. could that be the problem
post Nov 9, 2008 - 2:27 PM
are you adjusting the fpr with the car shut off, and just the fuel pump running?
post Nov 9, 2008 - 2:34 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
QUOTE (lagos @ Nov 9, 2008 - 1:27 PM) *
no with the car running , am i doing it wrong?
post Nov 10, 2008 - 7:36 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
QUOTE (02bluerolla @ Nov 9, 2008 - 1:34 PM) *
well i got the fpr to read
35 psi but its still sputters.... my friend says it could be the fuel filter or....and to check the gap on my spark plugs...
post Nov 11, 2008 - 5:23 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
anyone
post Nov 11, 2008 - 6:29 PM
Your supposed to adjust it with the engine NOT running, just the fuel pump on. Thats your base pressure. If thats what your doing, then it should be set correctly, but why did you have problems adjusting it in the first place? Are you sure you installed it correctly?
post Nov 11, 2008 - 9:16 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
QUOTE (lagos @ Nov 11, 2008 - 5:29 PM) *
well at first i had installed it incorrectly but then my friend help me and looked through the forums on how to install the fpr...and bingo !1 i had the fpr lines backwards and i never took off my stock fpr so i had completly wrong so then we installed it correctly http://www.aeromotiveinc.com/pdf/13101.pdf. What is the bas pressure for the 3sgte?
post Nov 11, 2008 - 11:09 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
well i just came back from re checking my fuel pressure and at idle it stays at 32 psi but when i take off the vac line its at 41 psi and it still sputters in high rpms !!!!
post Nov 11, 2008 - 11:19 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Try this. Leave the vac line on and jump the diagnostics box. FP and B+. Turn the key one click and adjust that pressure to 32 psi. Either do it that way or have you car idle and pull the vac line and adjust that to 32 psi. Either way should work, because I think thats what you are suppose to have the fpr set to before taking it to get tuned.
post Nov 12, 2008 - 7:51 PM
celica7afe
Joined Jun 2, '08
From houston
post Nov 12, 2008 - 10:39 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
are you serious? Did you check the spark plugs? Maybe that is an issue. Whens the last time you've changed the fuel filter?
post Nov 12, 2008 - 11:24 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
QUOTE (bccentaur3 @ Nov 12, 2008 - 9:39 PM) *
ok heres what i done i have change the spark plugs , spark plug wires, fuelfilter, i tried two spare afm but still the same ....
Lo-Fi Version Time is now: August 12th, 2026 - 1:06 AM
