3 Pages V  < 1 2 3
> how to start, where to start
post Jul 8, 2009 - 5:49 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
my gt4 out of the factory (with slightly elevated boost level) should be good for a mid 13 second run. if u had my motor directly swapped into ur car with the lower weight of your car, front wheel drive and good conditions, you may be able to find enough traction to run anywhere between a 13 second and a 14 second quarter, or you may end up spinning your front wheels on the spot.
at this stage if you still want to drive your car on the road you'll have to start looking at your wheels, brakes and suspension, or any use of power could end up dangerous for you.
Mike W
269awhp / 273ft-lbs
post Jul 8, 2009 - 6:00 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (babi_boi @ Feb 11, 2009 - 12:39 AM) *
right now all is stock exept intake, car is running good but it cant compete in the 1/4 mile. so the power goal is just to b able to run in the 1/4 and actually have a 1/2 way decent time.(somewhere around 10-12 sec in a 1/4 when the car is done)
it is a 94 and the maintenance seems to b ok but the sparkplug wires are tiny so when i do the tune up i dont really want to put the same tiny stock wires on, do i?
and if i get bigger wires how big can i go with out going to big, then with bigger wires am i going to have to get a better distributor or injectors?
10-12 second 1/4 mile in a 6gc, your looking at e153 tranny conversion with a 3s-gte or 5s-gte pushing 300+WHP
maybe an MR2 would be a better bet for you my friend!
post Jul 9, 2009 - 10:50 AM
jimmykay
Joined Jul 14, '08
From St. Louis
QUOTE (babi_boi @ Jul 8, 2009 - 3:07 PM) *
my goal is to come as close to a 10 sec. car as possible.
I would find a front engine rear wheel drive car with a decent sized engine bay and start there. much more practical. However, if your pockets run deep then you could do something like this.
No offense, I love my car, but if my goal was to build a quick 1/4 mile car, I wouldn't start with a celica. I'd start with an old F-body pony car( Mustang, Camaro, Firebird, etc.)
'99 Celica GT - Sold
'11 Mazdaspeed3
post Jul 9, 2009 - 11:03 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
do you know how hard it is to make a 10 sec FWD car? i have a 2001 Celica GTS making 545 WHP and its still not in the 10's thats because i was on a drag radial and not a slick and i havent a tranny to support it. once i finish the E153 conversion and put on slicks, im sure ill be in the 10's. its going to take alot to get a 5S-FE in that range. fully built internals, a medium sized turbo, fuel system to support, and engine management.
read up on my threads and Pressure2's threads. i think we will have the most information that you need. and ofcourse the stickies.
dont get your hopes up on 10 seconds. that is not an easy feat to reach.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 9, 2009 - 1:20 PM
babi_boi
Joined Feb 10, '09
From pa
QUOTE (jimmykay @ Jul 9, 2009 - 10:50 AM) *
i already have a 1995 nissan 240 sx se. that is rwd and the motor is built. not sure what it does in a 1/4 but i know with it built it kills the celica every time
BABI BOI
post Jul 9, 2009 - 1:32 PM
babi_boi
Joined Feb 10, '09
From pa
QUOTE (Smaay @ Jul 9, 2009 - 11:03 AM) *
the car doesnt have to reach 10 secs. i would just like it to be as close as i can possible get it. i know it is really hard to get a fwd car to be a 10sec car but i like to try the impossible or nearly impossible. so i am going to do all the research that i can possibly do than after the research i will review it all than decide on what i want. thanks for the reply
BABI BOI
post Jul 9, 2009 - 1:37 PM
babi_boi
Joined Feb 10, '09
From pa
QUOTE (delusionz @ Jul 8, 2009 - 5:49 PM) *
i plan on doing the wheels, brakes, suspension, etc as well as the motor. my plan is to get all the stuff and then do it all together.
BABI BOI
3 Pages V  < 1 2 3
Lo-Fi Version Time is now: September 1st, 2026 - 7:21 PM
