Feb 12, 2009 - 4:31 PM
Enthusiast ![]() Joined Mar 10, '08 From Ct Currently Offline Reputation: 0 (0%) |
can someone tell me the diffrence between the celica and camry throttle body (2.2L), what differs between them when its a auto or manual, federal or cali. emissions?
Feb 12, 2009 - 4:46 PM
can someone tell me the diffrence between the celica and camry throttle body (2.2L), what differs between them when its a auto or manual, federal or cali. emissions? the only diffrence i can think of off the top of my head is the EGR ports on the top of the TB. -------------------- Former Team 5SFTE pro member ;)
Feb 12, 2009 - 6:09 PM
thats what i thought too, but all the junkyards i called always ask me about fed. or cali. or MT/AT.
not that i had much luck..one guy said that theres a diff between MT/AT? ok...but he also told me that he didnt agree when i asked to check for camry because they have same 4cyl motor. im just looking to get one because my IACV is f@#%ed and im not enjoying the high idle |
Feb 13, 2009 - 12:48 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
thats what i thought too, but all the junkyards i called always ask me about fed. or cali. or MT/AT. not that i had much luck..one guy said that theres a diff between MT/AT? ok...but he also told me that he didnt agree when i asked to check for camry because they have same 4cyl motor. im just looking to get one because my IACV is f@#%ed and im not enjoying the high idle you can clean the IACv, hopefully it would help your problem.. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Feb 13, 2009 - 1:53 PM
already done that, actually i think thats the reason is messed up. i think i took the actual valve apart too much (silve plate on the back). i have tried messing with it so much. i just wanna get a new one all thgehter and hope its the problem.
Feb 14, 2009 - 1:20 AM
i actually have an ST one i can sell, but idk if they're interchangeable
Feb 14, 2009 - 4:57 AM
Enthusiast ![]() Joined Jan 3, '09 From Middlebrough, UK Currently Offline Reputation: 0 (0%) |
The auto throttle body has 2 throttle cables if it is the same as the UK GT.
Feb 14, 2009 - 10:57 AM
not too sure about the ST, but there are noticable diffrences, looking in a pic at least.
so if it was an auto one, could just remove that other cable braket i assume. i think thats what my TB i have now was at one point. |
Feb 14, 2009 - 1:56 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 3, '07 From Sunny Florida Currently Offline Reputation: 18 (91%) |
not too sure about the ST, but there are noticable diffrences, looking in a pic at least. so if it was an auto one, could just remove that other cable braket i assume. i think thats what my TB i have now was at one point. Anyone know if you fit a 3sgte Tb to a 5sfe ? -------------------- ![]() |
Apr 22, 2012 - 3:06 PM
Enthusiast ![]() ![]() ![]() Joined Oct 2, '07 From Manitoba, Canada Currently Offline Reputation: 6 (100%) |
So will an auto camry throttle body work on the celica gt?
Apr 23, 2012 - 4:40 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
So will an auto camry throttle body work on the celica gt? Yes if it's the same year as the Celica. OBD1 and OBD2 will be different as the EGR. Auto doesn't have two cables... any Celica/Camry will have two cables if there is cruse control. Gaskets are the same... everything matches up. In fact, I think even the air box is the same lol. Only place it differs is in the hose from the box to the intake (last I checked). -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Apr 24, 2012 - 8:54 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
So will an auto camry throttle body work on the celica gt? Yes if it's the same year as the Celica. OBD1 and OBD2 will be different as the EGR. Auto doesn't have two cables... any Celica/Camry will have two cables if there is cruse control. Gaskets are the same... everything matches up. In fact, I think even the air box is the same lol. Only place it differs is in the hose from the box to the intake (last I checked). The auto does have two cables going to the TB. One goes to the gas pedal and the other goes inside the transmission. For the cruise control, that cable actually goes to the gas pedal. So on an auto 5s with cruise control, there are three cables altogether. Since my swap, I still have the auto TB. The only difference from the auto to manual TB's is that the connection for the throttle cable on the Auto has two cable mounts / connections, where as the manual only has one cable mount / connection. |
| Lo-Fi Version | Time is now: June 13th, 2026 - 3:56 PM |
