> couple of vids of my 7AFTE
post Mar 14, 2009 - 7:49 PM
FunkySR
Joined Apr 22, '07
From Buckinghamshire, UK
post Mar 14, 2009 - 7:52 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
Nice Jay, the car sounds awesome! I wish I could find a tunnel like that to take a video of mine.
I <3 Dustin---07/16/06
post Mar 14, 2009 - 7:53 PM
FunkySR
Joined Apr 22, '07
you Know Steff, I still havent linked my o2 but I still get 14's and low 15 AFR on cruise. Want me to email you my map..you might like it.
post Mar 14, 2009 - 8:03 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
Same here. I got an external wastegate in hopes of keeping my boost around 10psi and not creeping to 15. Yeah you can e-mail me your map, I'd like to see the differences from mine. My map could be a lot better since I don't really have time to ride around with someone and tune, I kinda do it by myself while I'm driving which is not really the best idea... haha
post Mar 14, 2009 - 8:39 PM
cool vid!
post Mar 14, 2009 - 9:03 PM
aznpnoiboi55
Joined Nov 19, '07
From las vegas
nice
post Mar 14, 2009 - 9:39 PM
cheela
Joined Feb 2, '07
From Berlin, WI
sweet!!!
post Mar 15, 2009 - 5:34 AM
FunkySR
Joined Apr 22, '07
QUOTE (hurley97 @ Mar 15, 2009 - 1:03 AM) *
same here dont worry. I also do the same..then fine tune offline at home in front of the tele. biggrin.gif
post Mar 15, 2009 - 9:53 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
haha yea I do that sometimes. Do you use the logger? It just puts everything in a big list of numbers, AEM does have a program that deciphers the numbers into a visual graph but I haven't spent enough time with it to really understand how to set it up so it makes any sense.
post Mar 15, 2009 - 6:43 PM
FunkySR
Joined Apr 22, '07
no the logger is too complicated for my simple mind. ha ha. used it a few times when i was setting up...but now i know where i am i dont bother. will reply to youyr pm now
post Mar 15, 2009 - 6:59 PM
FunkySR
Joined Apr 22, '07
i'll take a better vid of the boost guage and speedo tonight and post.
post Mar 15, 2009 - 9:58 PM
FunkySR
Joined Apr 22, '07
here you go steff...i think u can get view of the boost gauge a bit better here
pls email me jdridesmail@gmail.com and I will reply with a copy of my map for you.
post Mar 16, 2009 - 7:52 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
Nice! I like how you stay in the higher 10's afr, I think mine goes too rich sometimes, like 10.1:1
post Mar 16, 2009 - 8:40 PM
FunkySR
Joined Apr 22, '07
yeh. I will try and get you one on cruise....it stays dead on 14.7 without O2 map. I dont think we need to hook it up. One problem I have though, the AEM editing screen shows the rpm jumping all over the place...no matter how many times i calibrate. Not too bothered as the car is working. Did you wore your crank signals different to me?
hope you got my email.
post Mar 16, 2009 - 11:41 PM
post Mar 17, 2009 - 12:09 AM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
i like your headunit tongue.gif...i have the same one.
post Mar 17, 2009 - 6:03 AM
NGHTKD
Joined Feb 2, '06
sounds really nice. good work!!!
post Mar 17, 2009 - 6:52 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE (FunkySR @ Mar 16, 2009 - 9:40 PM) *
yeah I got your e-mail. Yeah the positive crank wire I cut and connected like they say, on the negative side I only tapped the input wire.
I think I have a similar problem though, I can't get the TPS signal to work properly, it's hooked up right and I tested the connection, it just won't read anything in the gauge window. Maybe the same sort of interference issue?
I think I might hook up the O2 and try to play with it, I feel like my ECU sort of fights with the F/IC sometimes, I don't know how that's going to work out though.
post Jun 16, 2009 - 5:41 PM
FunkySR
Joined Apr 22, '07
Hey Stef. Just saw this. My TPS seems ok....but i still get the 'locator' jumping to the high RPM's and load when i'm not actually there. if that makes sense. I took all the wiring apart, and made sure that the crank wires were as close to their sheath as possible. that cuts interferance.
Lo-Fi Version Time is now: September 20th, 2026 - 12:34 AM
