> How do you know when your turbo is out?
post May 23, 2009 - 8:13 PM
mk7celica
Joined Feb 2, '09
From new orleans La.
This weekend I installed a new mbc and I had it set to stock boost at first then I raised it to 14lbs. I forgot to tighten a clamp for the coupler on the turbo going to my fmic. Well the engine killed I pulled over and put it back on tightened it and drove home. I decided to go for a test ride and I was in 2nd gear building boost got to about 12lbs and I heard a woosh of air like the intercooler pipe popped off again so I pulled over checked it and all other clamp an they all was on and tight. So I started to drive again and noticed my turbo was not making and sound and I was not building no voost. The car is like a n/a engine now less power no boost and the turbo lines,couplers ect are on and tight. I kind of hear a low clanking noise in the turbo I think. Is my turbo bad? Car runs and starts fine just have no boost and no sound from my ct26? whats the deal?
post May 23, 2009 - 9:39 PM
aznpnoiboi55
Joined Nov 19, '07
From las vegas
QUOTE (mk7celica @ May 23, 2009 - 9:13 PM) *
did you check if your bov works?
post May 23, 2009 - 10:57 PM
mk7celica
Joined Feb 2, '09
Took it off last month no bov
post May 23, 2009 - 11:22 PM
Nartanian
Joined Mar 26, '09
From Minnesota
QUOTE (mk7celica @ May 23, 2009 - 11:57 PM) *
NO BOV FOR A MONTH?!... That my friend is a HUGE problem... Seriously what were you thinking? You are VERY fortunate that your motor didn't get damage. I bet by now your turbo seals a shredded and your turbo fins are broken. The clanking noises you hear is probably for the fins hitting the turbine housing. Your turbo is done. I would remove the whole IC piping to make sure none of the chips from the fins is in there as well.
This post has been edited by Nartanian: May 23, 2009 - 11:41 PM
"God created turbo lag to give V8's a chance"
post May 23, 2009 - 11:46 PM
aznpnoiboi55
Joined Nov 19, '07
From las vegas
wow thats a big no no...you cant run it without a bov especially when your turning up the boost.....the bov is there to release all that excess air that your turbo had spooled up....when you release the acceleration it closes up the throttle and the excess air is pushed out of your bov.....thats your problem.... since you took it off....where do you think all that air went??.....yes to your turbo....and thats why your intercooler piping keeps coming off.....dude i think your turbo is done...you shouldnt have tooken off your bov....
post May 23, 2009 - 11:53 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
just remove the intake side and try spinning the blades... most likely your wastegate is stuck open... that is 100x more likely to happen then a blown turbo... with 14lbs of boost... you should definitely look into getting a BOV... it puts a lot of stress on your valves otherwise
Breaking Axles...
post May 24, 2009 - 1:06 AM
mk7celica
Joined Feb 2, '09
QUOTE (Nartanian @ May 23, 2009 - 11:22 PM) *
Well The alltrac the engine came from factory with no bov and I have been running stock boost until today so I figured at stock boost I did not need a bov Am I wrong? If so why did toyotanot put a bov on a alltrac gt4 3sgte from factory?
post May 24, 2009 - 1:24 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
i been running 8psi normally and 12psi in the weekends fr over a year on a stock tmic and never had a problem.
post May 24, 2009 - 2:27 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
you are absolutely maxing out the curve of the turbo at 14psi... its unneeded pressure on the turbo... i know mr2's have a stock recirc valve.. i thought st205's do too??
Breaking Axles...
post May 24, 2009 - 4:32 AM
aznpnoiboi55
Joined Nov 19, '07
From las vegas
QUOTE (pittfirefighter @ May 24, 2009 - 2:27 AM) *
yah i second that too..... all turbo set ups no matter if stock should have bov...a lot of the stock ones are recirculated
post May 24, 2009 - 7:06 AM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
205's do have a stock plumb back bov
dude dont listen to these people saying your car will die without a bov it wont, like you say it didnt have a bov factory, and neither do a lot of other cars.
Over say 12 psi a bov is a good idea, below that just be happy with your flutter.
Is it a ct26 or ct20b turbo? ceramic or steel wheeled?
a steel wheeled ct26 will be fine up to 15 psi or so, any more and its too inefficient.
steel wheeled ct20b will handle 20 psi for long periods of time
ceramic ct26 i wouldnt run any more then 12 psi
ceramic ct20b i wouldnt run more then 14 psi
do you have a stock dump pipe?
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post May 24, 2009 - 10:49 AM
QUOTE (mk7celica @ May 24, 2009 - 2:06 AM) *
the stock alltrac can get away with it because there is so little volume of actual air in that small top mount intercooler. you change all that when you convert to a fmic. there is a lot more air in those pipes that has no where to go when you let off the gas. so yes, even with stock boost, you should have a bov on a car with an upgraded intercooler.
but i do doubt thats whats causing your problem.
check all your piping again, and check to make sure your wastegate is not stuck open. then pull off the intake and downpipe if u want to inspect the turbo.
post May 24, 2009 - 1:30 PM
mk7celica
Joined Feb 2, '09
QUOTE (Cuts_the_Pilot @ May 24, 2009 - 7:06 AM) *
well its a jdm 2nd gen 3sgte not sure if its ceramic
post May 24, 2009 - 2:59 PM
95celgt
Joined Oct 5, '03
From South TX.
yes its a ceramic and with FMIC u must use a bov or preferably a diverter valve.
post May 24, 2009 - 3:35 PM
mk7celica
Joined Feb 2, '09
just pulled the intake the blade fan on the intake side of the turbo looks fine and is not rubbing. I did find a little metal shavings in the inlet pipr to my tb so maybe the exhaust side of the turbo blade is the proble since I found metal in the pipeing? I am about to pull the down pipe but first I am going to look at the waste gate and rod going to it to see if it stuck open. Because the turbo has no shaft play and spins fine by hand. If the waste gate is open will the turbo not spool up at all?
post May 24, 2009 - 4:51 PM
Cuts_the_Pilot
Joined Dec 15, '02
If your gate is open you will get no spool.
Ok so if these cars with ceramic turbos and fmic need bovs why dont say reputable engines from reputable manufacturers use then in the past, like 1j, rb25, sr20, 4g63 etc. Cars with stock fmic and ceramic snails.
Im not denying they are a good thing to have (I have one) but i am saying it wont cause the death of your turbo unless your screwing heaps of boost out of it, which is going to put it under heaps of load in more conditions then just backing off.
metal shavings in the inlet cant come from the exhaust wheel, only the inlet.
Was there any noise prior to the lack of boost? Either you have a massive boost leak (unlikely), your wastegate is stuck open, or your ceramic wheel has fallen off/disintigrated, the latter is especially possible if you were winding the boost into it at the time.
Lo-Fi Version Time is now: September 19th, 2026 - 9:23 AM
