Jun 17, 2009 - 1:38 PM
Enthusiast ![]() ![]() Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
So Ive been having issues with my idle for quite some time now. For a while it was bouncing consistently between 1800rpm and 2200rpm. so I swapped throttle bodies (i couldnt get the iac out). so problem solved! its no longer bouncing, now it is stuck at 3000rpm.
So I pulled off that throttle body and because I had the new screws I forced the screws off my original tb, cleaned it and put it back together. same problem. I dont know what to do anymore, I'm stumped, any ideas are very much welcome. -------------------- ![]() The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
nightryder Idle Problems Jun 17, 2009 - 1:38 PM
presure2 QUOTE (nightryder @ Jun 17, 2009 - 1... Jun 17, 2009 - 2:14 PM
nightryder i actually thought of that, and I did it, with the... Jun 17, 2009 - 4:50 PM
presure2 QUOTE (nightryder @ Jun 17, 2009 - 4... Jun 17, 2009 - 5:56 PM
nics QUOTE (nightryder @ Jun 17, 2009 - 11... Jun 17, 2009 - 6:31 PM
nightryder QUOTE (nics @ Jun 17, 2009 - 7:31 PM... Jun 17, 2009 - 6:48 PM
nics Man, i know what u feel.. It pisses me off when i ... Jun 17, 2009 - 11:33 PM
nightryder so ive gone through everything I can think of. An... Jun 28, 2009 - 11:35 AM
xrav22 QUOTE (nightryder @ Jun 28, 2009 - 11... Jun 29, 2009 - 12:15 AM
nightryder ill take a look, are we talking about that kinda c... Jun 29, 2009 - 8:58 AM
presure2 yea, tahts what he's talking about nate, but f... Jun 29, 2009 - 9:01 AM
lagos disconnect the throttle and cruise control cables ... Jun 29, 2009 - 9:08 AM
nightryder i did try the throttle cable...hadnt thot of the c... Jul 2, 2009 - 1:49 PM
nightryder ok so I gave the cruise control a shot...nothing..... Jul 7, 2009 - 10:10 AM
presure2 nate, does the car run?
if so, gimme a call, and w... Jul 7, 2009 - 12:01 PM
nightryder it runs, but the rpms stick @ wherever they are re... Jul 8, 2009 - 12:18 PM
GriffGirl So what did the problem turn out to be? Any update... Jul 17, 2009 - 12:27 PM
95CelicaST Check your distributor shaft for play. I had bad i... Jul 17, 2009 - 12:51 PM
GriffGirl Mine seems to be more like an airflow issue... I... Jul 17, 2009 - 3:10 PM
bigjohn671 i had the same problem. i tapped on the valve with... Jul 21, 2009 - 12:07 PM
nightryder yeah i have been working steadily with no progress... Aug 14, 2009 - 12:19 PM
nightryder ok guys... think we got it....
so i had the sou... Aug 23, 2009 - 9:16 PM
nics fixed? Sep 29, 2009 - 3:31 PM
DGolden32 Ok so im having same problem as you i believe with... Jun 9, 2010 - 1:09 AM![]() ![]() |
| Lo-Fi Version | Time is now: September 12th, 2026 - 8:58 PM |
