> Flush Fit Wheel Fitment, Offsets for Flush Fitment which is Proper Fitment
post Oct 6, 2009 - 10:42 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
So you want to be Dope Status now? Maybe your life goal is to make it on HellaFlush, well this is the offset numbers you need for that to happen.
First: You will need to run stretched tires for this to work and preferably a nicely lowered car.......... Or 4x4 your car and run it Donk status. I don't care, but you will have to choose one of those options.
FOR THE FRONT WHEELS ONLY **Your fronts should have been rolled from the factory. 9.0+ will probably need a bit of a roll to crush the plastic liner in a bit.
Width ---------- Offset (et)
6.0" ---------- et-5mm
6.5" ---------- et 0mm
7.0" ---------- et+10mm
7.5" ---------- et+15mm
8.0" ---------- et+22mm
8.5" ---------- et+27mm
9.0" ---------- et+33mm (you will be cutting it close with the strut. May need to start running negative camber at this point)
9.5" ---------- et+40mm (you will be cutting it close with the strut. Probably need to start running negative camber at this point)
10.0" ---------- et+45mm (At this point, you will need negative camber, a good fender pull and probably better off with a +35ish offset and going with wide fenders.)
10.5" ---------- et+50mm (At this point, you will need negative camber, a good fender pull and probably better off with a +35ish offset and going with wide fenders.)
FOR THE REAR WHEELS ONLY **You need to roll your fenders for all of these.
6.0" ---------- et-20mm
6.5" ---------- et-15mm
7.0" ---------- et-8mm
7.5" ---------- et-2mm
8.0" ---------- et+5mm
8.5" ---------- et+10mm
9.0" ---------- et+18mm
9.5" ---------- et+23mm
10.0" ---------- et+30mm (Will start to cut it close with the strut. Negative camber may be needed. My best guess is you will be alright)
10.5" ---------- et+36mm (At this point, you will probably hit strut. Negative camber is needed. Probably would want to run a lower offset and just pull the crap out of your rear fender to make it tuck.)
As for tires, I highly suggest you run 45 series tires and I HIGHLY recommend Falken 512s. They handle stretching very well.
These numbers will make your wheel flush with the body. If you want to wheel to poke then run a lower offset then I have listed. This in turn means you need to run a smaller diameter tire and some negative camber.
Spacers:
For those of you who need a 25mm spacer or larger for your look. I suggest A-Dapt-It USA (http://adaptitusa.com/) or Motorsport Technologies (http://www.motorsport-tech.com/)
The A-Dapt-It's will be cheaper and will be lug centric to the wheel. Motorsport Tech can make you hubcentric to hubcentric adapters which are double the cost of A-Dapt-It's. Either choice is fine, I run lug centric and so do plenty of other people. Toyota still ships cars off the assembly line with lug centric wheels. Don't let the scare tactics of hubcentric or die mess with your head. With lug centric you just need to tighten your lugnuts in the standard star pattern starting from the top.
This thread was made separate due to not wanting to have an e-thug battle.
This post has been edited by Harold_Fastwaker: Oct 6, 2009 - 11:30 PM
- Harold_Fastwaker   Flush Fit Wheel Fitment   Oct 6, 2009 - 10:42 PM
- - 95CelicaST   Vote for sticky   Oct 6, 2009 - 10:55 PM
|- - RoyO   QUOTE (95CelicaST @ Oct 7, 2009 - 5...   Oct 7, 2009 - 11:11 AM
- - Harold_Fastwaker   Lets talk about Lug Centric Vs Hub Centric Wheels ...   Oct 6, 2009 - 11:21 PM
- - qatar11   +1   Oct 7, 2009 - 8:12 AM
- - playr158   info looks good, should help someone go VIP   Oct 7, 2009 - 8:44 AM
|- - Harold_Fastwaker   QUOTE (playr158 @ Oct 7, 2009 - 9:44...   Oct 7, 2009 - 12:05 PM
|- - richee3   QUOTE (Harold_Fastwaker @ Oct 7, 2009 - ...   Oct 8, 2009 - 6:18 PM
- - 95CelicaST   Give me until spring and I'll be there. Got to...   Oct 7, 2009 - 1:21 PM
- - 808celica   i ****en love your sig fastwaker wanna make me on...   Oct 7, 2009 - 1:35 PM
- - freddy121389   I vote sticky as well   Oct 7, 2009 - 1:48 PM
- - Sinyk   Good info, but I'm just not a fan of the stret...   Oct 7, 2009 - 2:19 PM
- - Harold_Fastwaker   QUOTE (95CelicaST @ Oct 7, 2009 - 2...   Oct 7, 2009 - 3:11 PM
- - trdproven   this is based on our 6gc specifically?   Oct 7, 2009 - 4:35 PM
|- - Harold_Fastwaker   QUOTE (trdproven @ Oct 7, 2009 - 5:3...   Oct 7, 2009 - 4:45 PM
- - SoundSlut_dotcom   i know this is annoying... but.. im about to order...   Oct 12, 2009 - 11:21 AM
- - 95CelicaST   You'll be golden, but how much bigger are your...   Oct 12, 2009 - 12:42 PM
- - SoundSlut_dotcom   ill be honest i have no clue, maybe about an inch ...   Oct 12, 2009 - 12:49 PM
- - 95CelicaST   What is your current setup? Wheel width and offset...   Oct 12, 2009 - 12:59 PM
- - SoundSlut_dotcom   17 x 7.5 sunk in like crazy.. im guessin a +45 ?   Oct 12, 2009 - 1:05 PM
- - 95CelicaST   Based on my math, you'll actually gain a bit o...   Oct 12, 2009 - 2:04 PM
- - Harold_Fastwaker   QUOTE (SoundSlut_dotcom @ Oct 12, 2009 ...   Oct 12, 2009 - 3:02 PM
- - Harold_Fastwaker   An example.   Jan 27, 2010 - 2:40 PM
- - nintyfourcelicaman   maybe this is a dumb question with a simple answer...   Feb 7, 2010 - 8:59 PM
- - 808celica   114.3 pattern wont fit our cars. stretched tire is...   Feb 7, 2010 - 9:45 PM
- - Harold_Fastwaker   Look on the inside of your wheel. Somewhere it wil...   Feb 7, 2010 - 11:32 PM
- - 808celica   just something i keep forgetting to post http://...   Feb 8, 2010 - 3:21 AM
|- - Harold_Fastwaker   QUOTE (808celica @ Feb 8, 2010 - 3:2...   Feb 9, 2010 - 12:36 AM
|- - sunwukongg   QUOTE (Harold_Fastwaker @ Feb 9, 2010 - ...   Aug 16, 2010 - 10:19 PM
|- - diegohiga   Ok I have question.. Someone might asked this befo...   Sep 7, 2010 - 5:49 PM
- - Spider77   .....   Feb 8, 2010 - 8:59 AM
- - SwissFerdi   I'm sorry, but I just don't get this Hella...   Feb 9, 2010 - 12:45 AM
|- - Harold_Fastwaker   QUOTE (SwissFerdi @ Feb 9, 2010 - 12...   Feb 9, 2010 - 12:12 PM
|- - SwissFerdi   QUOTE (Harold_Fastwaker @ Feb 9, 2010 - ...   Feb 9, 2010 - 3:45 PM
- - nintyfourcelicaman   okay so i decided not to go with 19" rims and...   Mar 2, 2010 - 10:07 PM
- - 95CelicaST   You'll need an 8mm spacer up front to bring th...   Mar 4, 2010 - 2:39 PM
|- - Harold_Fastwaker   QUOTE (95CelicaST @ Mar 4, 2010 - 2...   Mar 4, 2010 - 2:49 PM
- - 95CelicaST   That is going to be a LOT of poke up front, camber...   Mar 4, 2010 - 3:31 PM
|- - Harold_Fastwaker   QUOTE (95CelicaST @ Mar 4, 2010 - 3...   Mar 4, 2010 - 3:53 PM
- - nintyfourcelicaman   I can buy 20mm adapters for the front....that woul...   Mar 4, 2010 - 3:50 PM
|- - 95CelicaST   QUOTE (nintyfourcelicaman @ Mar 4, 2010 ...   Mar 4, 2010 - 4:04 PM
- - nintyfourcelicaman   ok...so if i am running 1/2 inch past the stock fe...   Mar 4, 2010 - 4:42 PM
- - 95CelicaST   With fiberglass fenders you're going to need t...   Mar 4, 2010 - 5:19 PM
- - nintyfourcelicaman   thank you for the link and the advice!!...   Mar 4, 2010 - 10:56 PM
- - Goonter   k i'm planning on using spacers/adapters. but ...   Mar 12, 2010 - 6:03 AM
- - Harold_Fastwaker   both eat up your bearings at the same rate. It wi...   Mar 13, 2010 - 12:02 AM
- - Goonter   arg .. i see thanks for the response. guess ill tr...   Mar 13, 2010 - 12:21 AM
|- - Harold_Fastwaker   QUOTE (Goonter @ Mar 13, 2010 - 12:2...   Mar 13, 2010 - 5:14 PM
- - Goonter   thanks   Mar 13, 2010 - 6:41 PM
- - whatthe   Throwing my 17x8 +35 with 225/45/17 this week back...   May 2, 2010 - 6:19 AM
- - Driveby   Snap! (almost) Just fitted 30mm H&R rear s...   May 2, 2010 - 11:47 AM
- - whatthe   Driveby how much negative camber are you running o...   May 2, 2010 - 12:04 PM
- - Driveby   I dont know the exact reading mate, I set it up wi...   May 2, 2010 - 12:19 PM
- - Driveby   By looking at the pictures Im running a bit of neg...   May 3, 2010 - 1:07 PM
|- - Ted95   QUOTE (Driveby @ May 3, 2010 - 2:07 ...   Oct 2, 2010 - 11:38 AM
- - vincent_doggy   Guys do some math for me, I have 17x7.5 offset30 a...   May 4, 2010 - 5:54 AM
- - whatthe   VC you will need 15mm on the front and 30 at the b...   May 20, 2010 - 4:55 AM
- - whatthe   Okay 6gc, i have a serious dilemma. My 15mm bolt ...   May 28, 2010 - 5:06 AM
- - Promasta   marco has 18x8 +15 front and rear, and it looks am...   May 28, 2010 - 1:05 PM
- - whatthe   ^ Thanks for that. Marcos running 225 anyway and i...   May 28, 2010 - 1:39 PM
- - 808celica   i got bigger ones   May 30, 2010 - 3:38 AM
- - whatthe   ^Dude how big are they?   May 30, 2010 - 5:12 AM
- - 808celica   1.5" converted into mm???   Jun 1, 2010 - 4:16 AM
|- - Harold_Fastwaker   QUOTE (808celica @ Jun 1, 2010 - 5:1...   Jun 1, 2010 - 10:08 AM
- - HectortheRican   So my wheel is 7.5" and 45mm offset. the char...   Aug 3, 2010 - 12:26 PM
- - block   this wheel flush thing is confusing me. LOL....i...   Sep 13, 2010 - 11:36 PM
|- - easternpiro1   QUOTE (block @ Sep 13, 2010 - 11:36 ...   Sep 14, 2010 - 12:55 AM
|- - HectortheRican   QUOTE (easternpiro1 @ Sep 13, 2010 - 11...   Sep 14, 2010 - 10:26 PM
- - block   tell me about it bro i just want my wheels flu...   Sep 14, 2010 - 7:50 PM
- - easternpiro1   right now i have some 7.5 widths on there, but i p...   Sep 15, 2010 - 12:12 AM
|- - HectortheRican   QUOTE (easternpiro1 @ Sep 14, 2010 - 11...   Sep 15, 2010 - 1:16 AM
- - whatthe   http://www.youtube.com/watch?v=IBWeQHZy_nw...ture=...   Sep 23, 2010 - 10:32 AM
- - HectortheRican   Great video!!   Sep 23, 2010 - 2:58 PM
- - chacha   so do we use hub centric spacers or the lugs space...   Sep 23, 2010 - 8:53 PM
|- - HectortheRican   QUOTE (chacha @ Sep 23, 2010 - 7:53 ...   Sep 23, 2010 - 10:42 PM
- - whatthe   HUB centric   Sep 23, 2010 - 10:09 PM
- - chacha   i saw the first page...with mines...since the rims...   Sep 23, 2010 - 11:06 PM
|- - HectortheRican   QUOTE (chacha @ Sep 23, 2010 - 10:06...   Sep 23, 2010 - 11:21 PM
- - chacha   thanks...so i would ask for a -2mm rear hub cent s...   Sep 23, 2010 - 11:58 PM
|- - HectortheRican   QUOTE (chacha @ Sep 23, 2010 - 10:58...   Sep 24, 2010 - 12:06 AM
- - chacha   man...hahaha....craziness...reading didn't see...   Sep 25, 2010 - 3:00 AM
- - HectortheRican   No problem man   Sep 25, 2010 - 9:37 AM
- - sunwukongg   is it possible for me to just get a flushed aggres...   Oct 1, 2010 - 12:28 PM
|- - HectortheRican   QUOTE (sunwukongg @ Oct 1, 2010 - 11...   Oct 1, 2010 - 12:47 PM
- - 96stgreendemon   Ok so i think that i may have this, with my 7th g...   Nov 16, 2010 - 4:32 PM
- - HectortheRican   Damn, 7th gen wheels are 8"?! Didn't ...   Nov 16, 2010 - 4:36 PM
- - 96stgreendemon   the wheels are 6.5 wide but a 205 tire is 8 inches...   Nov 16, 2010 - 4:54 PM
|- - HectortheRican   QUOTE (96stgreendemon @ Nov 16, 2010 - 3...   Nov 16, 2010 - 4:56 PM
|- - whatthe   QUOTE (96stgreendemon @ Nov 17, 2010 - 8...   Nov 16, 2010 - 8:40 PM
- - 96stgreendemon   was oem spec on the tire and gives me more grip   Nov 16, 2010 - 4:59 PM
|- - HectortheRican   QUOTE (96stgreendemon @ Nov 16, 2010 - 3...   Nov 16, 2010 - 5:01 PM
- - 96stgreendemon   Yeah looking at 240 bucks for the set...... but go...   Nov 16, 2010 - 5:04 PM
- - HectortheRican   Dayyum lol. I want to get new wheels by this time ...   Nov 16, 2010 - 5:09 PM
- - BonzaiCelica   +39mm offset for 7gc rims   Nov 16, 2010 - 8:33 PM
- - BonzaiCelica   QUOTE (whatthe @ Nov 16, 2010 - 9:40...   Nov 17, 2010 - 8:29 PM
- - BonzaiCelica   this is a one man job if ya use your logic a littl...   Nov 28, 2010 - 10:41 PM
- - njccmd2002   ^^^ Bro be carerful with that pry bar, that can ac...   Nov 29, 2010 - 5:55 PM
- - BonzaiCelica   what are you talking about. how can I break them??...   Nov 29, 2010 - 8:33 PM
- - sunwukongg   pics of your rides stance please bonzai haha   Nov 30, 2010 - 10:51 AM
- - BonzaiCelica   QUOTE (sunwukongg @ Nov 30, 2010 - 11...   Dec 1, 2010 - 1:58 AM
4 Pages V   1 2 3 > »
Lo-Fi Version Time is now: August 26th, 2026 - 6:38 PM
