Oct 6, 2009 - 10:42 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) |
So you want to be Dope Status now? Maybe your life goal is to make it on HellaFlush, well this is the offset numbers you need for that to happen.
First: You will need to run stretched tires for this to work and preferably a nicely lowered car.......... Or 4x4 your car and run it Donk status. I don't care, but you will have to choose one of those options. FOR THE FRONT WHEELS ONLY **Your fronts should have been rolled from the factory. 9.0+ will probably need a bit of a roll to crush the plastic liner in a bit. Width ---------- Offset (et) 6.0" ---------- et-5mm 6.5" ---------- et 0mm 7.0" ---------- et+10mm 7.5" ---------- et+15mm 8.0" ---------- et+22mm 8.5" ---------- et+27mm 9.0" ---------- et+33mm (you will be cutting it close with the strut. May need to start running negative camber at this point) 9.5" ---------- et+40mm (you will be cutting it close with the strut. Probably need to start running negative camber at this point) 10.0" ---------- et+45mm (At this point, you will need negative camber, a good fender pull and probably better off with a +35ish offset and going with wide fenders.) 10.5" ---------- et+50mm (At this point, you will need negative camber, a good fender pull and probably better off with a +35ish offset and going with wide fenders.) FOR THE REAR WHEELS ONLY **You need to roll your fenders for all of these. Width ---------- Offset (et) 6.0" ---------- et-20mm 6.5" ---------- et-15mm 7.0" ---------- et-8mm 7.5" ---------- et-2mm 8.0" ---------- et+5mm 8.5" ---------- et+10mm 9.0" ---------- et+18mm 9.5" ---------- et+23mm 10.0" ---------- et+30mm (Will start to cut it close with the strut. Negative camber may be needed. My best guess is you will be alright) 10.5" ---------- et+36mm (At this point, you will probably hit strut. Negative camber is needed. Probably would want to run a lower offset and just pull the crap out of your rear fender to make it tuck.) As for tires, I highly suggest you run 45 series tires and I HIGHLY recommend Falken 512s. They handle stretching very well. These numbers will make your wheel flush with the body. If you want to wheel to poke then run a lower offset then I have listed. This in turn means you need to run a smaller diameter tire and some negative camber. Spacers: For those of you who need a 25mm spacer or larger for your look. I suggest A-Dapt-It USA (http://adaptitusa.com/) or Motorsport Technologies (http://www.motorsport-tech.com/) The A-Dapt-It's will be cheaper and will be lug centric to the wheel. Motorsport Tech can make you hubcentric to hubcentric adapters which are double the cost of A-Dapt-It's. Either choice is fine, I run lug centric and so do plenty of other people. Toyota still ships cars off the assembly line with lug centric wheels. Don't let the scare tactics of hubcentric or die mess with your head. With lug centric you just need to tighten your lugnuts in the standard star pattern starting from the top. This thread was made separate due to not wanting to have an e-thug battle. This post has been edited by Harold_Fastwaker: Oct 6, 2009 - 11:30 PM -------------------- |
Harold_Fastwaker Flush Fit Wheel Fitment Oct 6, 2009 - 10:42 PM
95CelicaST Vote for sticky Oct 6, 2009 - 10:55 PM
RoyO QUOTE (95CelicaST @ Oct 7, 2009 - 5... Oct 7, 2009 - 11:11 AM
Harold_Fastwaker Lets talk about Lug Centric Vs Hub Centric Wheels
... Oct 6, 2009 - 11:21 PM
qatar11 +1 Oct 7, 2009 - 8:12 AM
playr158 info looks good, should help someone go VIP Oct 7, 2009 - 8:44 AM
Harold_Fastwaker QUOTE (playr158 @ Oct 7, 2009 - 9:44... Oct 7, 2009 - 12:05 PM
richee3 QUOTE (Harold_Fastwaker @ Oct 7, 2009 - ... Oct 8, 2009 - 6:18 PM
95CelicaST Give me until spring and I'll be there. Got to... Oct 7, 2009 - 1:21 PM
808celica i ****en love your sig fastwaker wanna make me on... Oct 7, 2009 - 1:35 PM
freddy121389 I vote sticky as well Oct 7, 2009 - 1:48 PM
Sinyk Good info, but I'm just not a fan of the stret... Oct 7, 2009 - 2:19 PM
Harold_Fastwaker QUOTE (95CelicaST @ Oct 7, 2009 - 2... Oct 7, 2009 - 3:11 PM
trdproven this is based on our 6gc specifically? Oct 7, 2009 - 4:35 PM
Harold_Fastwaker QUOTE (trdproven @ Oct 7, 2009 - 5:3... Oct 7, 2009 - 4:45 PM
SoundSlut_dotcom i know this is annoying... but.. im about to order... Oct 12, 2009 - 11:21 AM
95CelicaST You'll be golden, but how much bigger are your... Oct 12, 2009 - 12:42 PM
SoundSlut_dotcom ill be honest i have no clue, maybe about an inch ... Oct 12, 2009 - 12:49 PM
95CelicaST What is your current setup? Wheel width and offset... Oct 12, 2009 - 12:59 PM
SoundSlut_dotcom 17 x 7.5 sunk in like crazy.. im guessin a +45 ? Oct 12, 2009 - 1:05 PM
95CelicaST Based on my math, you'll actually gain a bit o... Oct 12, 2009 - 2:04 PM
Harold_Fastwaker QUOTE (SoundSlut_dotcom @ Oct 12, 2009 ... Oct 12, 2009 - 3:02 PM
Harold_Fastwaker An example. Jan 27, 2010 - 2:40 PM
nintyfourcelicaman maybe this is a dumb question with a simple answer... Feb 7, 2010 - 8:59 PM
808celica 114.3 pattern wont fit our cars. stretched tire is... Feb 7, 2010 - 9:45 PM
Harold_Fastwaker Look on the inside of your wheel. Somewhere it wil... Feb 7, 2010 - 11:32 PM
808celica just something i keep forgetting to post
http://... Feb 8, 2010 - 3:21 AM
Harold_Fastwaker QUOTE (808celica @ Feb 8, 2010 - 3:2... Feb 9, 2010 - 12:36 AM
sunwukongg QUOTE (Harold_Fastwaker @ Feb 9, 2010 - ... Aug 16, 2010 - 10:19 PM
diegohiga Ok I have question.. Someone might asked this befo... Sep 7, 2010 - 5:49 PM
Spider77 ..... Feb 8, 2010 - 8:59 AM
SwissFerdi I'm sorry, but I just don't get this Hella... Feb 9, 2010 - 12:45 AM
Harold_Fastwaker QUOTE (SwissFerdi @ Feb 9, 2010 - 12... Feb 9, 2010 - 12:12 PM
SwissFerdi QUOTE (Harold_Fastwaker @ Feb 9, 2010 - ... Feb 9, 2010 - 3:45 PM
nintyfourcelicaman okay so i decided not to go with 19" rims and... Mar 2, 2010 - 10:07 PM
95CelicaST You'll need an 8mm spacer up front to bring th... Mar 4, 2010 - 2:39 PM
Harold_Fastwaker QUOTE (95CelicaST @ Mar 4, 2010 - 2... Mar 4, 2010 - 2:49 PM
95CelicaST That is going to be a LOT of poke up front, camber... Mar 4, 2010 - 3:31 PM
Harold_Fastwaker QUOTE (95CelicaST @ Mar 4, 2010 - 3... Mar 4, 2010 - 3:53 PM
nintyfourcelicaman I can buy 20mm adapters for the front....that woul... Mar 4, 2010 - 3:50 PM
95CelicaST QUOTE (nintyfourcelicaman @ Mar 4, 2010 ... Mar 4, 2010 - 4:04 PM
nintyfourcelicaman ok...so if i am running 1/2 inch past the stock fe... Mar 4, 2010 - 4:42 PM
95CelicaST With fiberglass fenders you're going to need t... Mar 4, 2010 - 5:19 PM
nintyfourcelicaman thank you for the link and the advice!!... Mar 4, 2010 - 10:56 PM
Goonter k i'm planning on using spacers/adapters. but ... Mar 12, 2010 - 6:03 AM
Harold_Fastwaker both eat up your bearings at the same rate. It wi... Mar 13, 2010 - 12:02 AM
Goonter arg .. i see thanks for the response. guess ill tr... Mar 13, 2010 - 12:21 AM
Harold_Fastwaker QUOTE (Goonter @ Mar 13, 2010 - 12:2... Mar 13, 2010 - 5:14 PM
Goonter thanks Mar 13, 2010 - 6:41 PM
whatthe Throwing my 17x8 +35 with 225/45/17 this week back... May 2, 2010 - 6:19 AM
Driveby Snap! (almost)
Just fitted 30mm H&R rear s... May 2, 2010 - 11:47 AM
whatthe Driveby how much negative camber are you running o... May 2, 2010 - 12:04 PM
Driveby I dont know the exact reading mate, I set it up wi... May 2, 2010 - 12:19 PM
Driveby By looking at the pictures Im running a bit of neg... May 3, 2010 - 1:07 PM
Ted95 QUOTE (Driveby @ May 3, 2010 - 2:07 ... Oct 2, 2010 - 11:38 AM
vincent_doggy Guys do some math for me, I have 17x7.5 offset30 a... May 4, 2010 - 5:54 AM
whatthe VC you will need 15mm on the front and 30 at the b... May 20, 2010 - 4:55 AM
whatthe Okay 6gc, i have a serious dilemma.
My 15mm bolt ... May 28, 2010 - 5:06 AM
Promasta marco has 18x8 +15 front and rear, and it looks am... May 28, 2010 - 1:05 PM
whatthe ^ Thanks for that. Marcos running 225 anyway and i... May 28, 2010 - 1:39 PM
808celica i got bigger ones May 30, 2010 - 3:38 AM
whatthe ^Dude how big are they? May 30, 2010 - 5:12 AM
808celica 1.5" converted into mm??? Jun 1, 2010 - 4:16 AM
Harold_Fastwaker QUOTE (808celica @ Jun 1, 2010 - 5:1... Jun 1, 2010 - 10:08 AM
HectortheRican So my wheel is 7.5" and 45mm offset. the char... Aug 3, 2010 - 12:26 PM
block this wheel flush thing is confusing me. LOL....i... Sep 13, 2010 - 11:36 PM
easternpiro1 QUOTE (block @ Sep 13, 2010 - 11:36 ... Sep 14, 2010 - 12:55 AM
HectortheRican QUOTE (easternpiro1 @ Sep 13, 2010 - 11... Sep 14, 2010 - 10:26 PM
block tell me about it bro i just want my wheels flu... Sep 14, 2010 - 7:50 PM
easternpiro1 right now i have some 7.5 widths on there, but i p... Sep 15, 2010 - 12:12 AM
HectortheRican QUOTE (easternpiro1 @ Sep 14, 2010 - 11... Sep 15, 2010 - 1:16 AM
whatthe http://www.youtube.com/watch?v=IBWeQHZy_nw...ture=... Sep 23, 2010 - 10:32 AM
HectortheRican Great video!! Sep 23, 2010 - 2:58 PM
chacha so do we use hub centric spacers or the lugs space... Sep 23, 2010 - 8:53 PM
HectortheRican QUOTE (chacha @ Sep 23, 2010 - 7:53 ... Sep 23, 2010 - 10:42 PM
whatthe HUB centric Sep 23, 2010 - 10:09 PM
chacha i saw the first page...with mines...since the rims... Sep 23, 2010 - 11:06 PM
HectortheRican QUOTE (chacha @ Sep 23, 2010 - 10:06... Sep 23, 2010 - 11:21 PM
chacha thanks...so i would ask for a -2mm rear hub cent s... Sep 23, 2010 - 11:58 PM
HectortheRican QUOTE (chacha @ Sep 23, 2010 - 10:58... Sep 24, 2010 - 12:06 AM
chacha man...hahaha....craziness...reading didn't see... Sep 25, 2010 - 3:00 AM
HectortheRican No problem man Sep 25, 2010 - 9:37 AM
sunwukongg is it possible for me to just get a flushed aggres... Oct 1, 2010 - 12:28 PM
HectortheRican QUOTE (sunwukongg @ Oct 1, 2010 - 11... Oct 1, 2010 - 12:47 PM
96stgreendemon Ok so i think that i may have this,
with my 7th g... Nov 16, 2010 - 4:32 PM
HectortheRican Damn, 7th gen wheels are 8"?! Didn't ... Nov 16, 2010 - 4:36 PM
96stgreendemon the wheels are 6.5 wide but a 205 tire is 8 inches... Nov 16, 2010 - 4:54 PM
HectortheRican QUOTE (96stgreendemon @ Nov 16, 2010 - 3... Nov 16, 2010 - 4:56 PM
whatthe QUOTE (96stgreendemon @ Nov 17, 2010 - 8... Nov 16, 2010 - 8:40 PM
96stgreendemon was oem spec on the tire and gives me more grip Nov 16, 2010 - 4:59 PM
HectortheRican QUOTE (96stgreendemon @ Nov 16, 2010 - 3... Nov 16, 2010 - 5:01 PM
96stgreendemon Yeah looking at 240 bucks for the set...... but go... Nov 16, 2010 - 5:04 PM
HectortheRican Dayyum lol. I want to get new wheels by this time ... Nov 16, 2010 - 5:09 PM
BonzaiCelica +39mm offset for 7gc rims Nov 16, 2010 - 8:33 PM
BonzaiCelica QUOTE (whatthe @ Nov 16, 2010 - 9:40... Nov 17, 2010 - 8:29 PM
BonzaiCelica this is a one man job if ya use your logic a littl... Nov 28, 2010 - 10:41 PM
njccmd2002 ^^^ Bro be carerful with that pry bar, that can ac... Nov 29, 2010 - 5:55 PM
BonzaiCelica what are you talking about. how can I break them??... Nov 29, 2010 - 8:33 PM
sunwukongg pics of your rides stance please bonzai haha Nov 30, 2010 - 10:51 AM
BonzaiCelica QUOTE (sunwukongg @ Nov 30, 2010 - 11... Dec 1, 2010 - 1:58 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 10:35 AM |
