20 Pages V   1 2 3 > »
Closed TopicStart new topic
> GB: Megan Racing Coilovers (94-99 Celica)!
post Oct 12, 2009 - 10:17 PM
upscaleauto
Joined Nov 23, '07
From NJ
Megan Racing Street Series Coilovers for 94-99 Toyota Celica FWD
$850/set with Discount Code! Free Shipping (lower 48 states)! Brand New with Warranty!
Simply enter code "6GCMRCDK" during checkout - follow the links below!
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you're a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car's handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, Megan Racing stands by their product with a strong warranty.
Features:
Spring Rates: Front 10kg/Rear 8kg
32 Levels of Adjustable Damper
Pillow Ball Upper Mounts
Rubber Dust Covers
Adjustable Ride Height
Aggressive Spring Rates
Single-Cylinder Design
Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use
9-16: Suggested for mountain/aggressive use
17-32: Suggested for common street use
All coilover damper kits come with 1 year manufacture-defect warranty
Megan Racing Street Series Coilovers for 94-99 Toyota Celica GT/ST FWD
This group buy is now open and active to all members. We can accept payment directly via Paypal or through our website checkout. For website checkout, enter code "6GCMRCDK" to receive discount!
Megan Racing Street Series Coilovers for 00+ Toyota Celica
Megan Racing Street Series Coilovers for 89-93 Toyota Celica All-Trac
Megan Racing Street Series Coilovers for 90-93 Toyota Celica GT/GTS FWD
Megan Racing Street Series Coilovers for 93-98 Toyota Supra
Megan Racing Street Series Coilovers for 00+ Toyota MR2 Spyder
Megan Racing Street Series Coilovers for 91-95 Toyota MR2
Simply enter code "6GCMRCDK" during checkout - follow the links above!
Note to admins: Coomer has not responded to PM's. If there is another admin who needs to verify/approve this posting, please PM and let us know.
This post has been edited by upscaleauto: Aug 27, 2010 - 7:53 PM
Upscale Automotive LLC
Your Source for Performance, Reliability, and Style
http://www.UpscaleAutomotive.com
fulfillment@upscaleautomotive.com
Phone: 201-298-3608
AIM: SalesUpscaleAuto
post Oct 12, 2009 - 10:37 PM
cjh4l22
Joined Oct 18, '06
From cincinnati
ahh if i were done with my swap i'd grab a set of these... damn. maybe next month.
post Oct 13, 2009 - 1:36 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
how much longer will these deal be going on for??
post Oct 13, 2009 - 3:35 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
did you go through 6gc management to set up a group buy???
post Oct 13, 2009 - 4:27 AM
upscaleauto
Joined Nov 23, '07
From NJ
QUOTE (808celica @ Oct 13, 2009 - 4:35 AM) *
As stated at the bottom of the original post we attempted to contact Coomer via PM as instructed in the forum rules, but did not receive any response. Coomer's last post on the forums looks to be August of this year, so we went ahead and posted the GB. Hopefully an admin will take a look over this thread send a PM over letting us know if anything needs to be changed about the GB. If you will refer us to someone other than Coomer who we can get in touch with about this GB, it would be much appreciated! Until we are able to get in touch with Coomer or another admin, please check out our 6GC profile including feedback and also feel free to contact Megan Racing to confirm that we are an official distributor in good standing.
QUOTE (BonzaiCelica @ Oct 13, 2009 - 2:36 AM) *
We currently do not have a date set. It will be running through at least the end of October.
This post has been edited by upscaleauto: Oct 13, 2009 - 4:33 AM
Phone: 201-298-3608
post Oct 13, 2009 - 4:33 AM
upscaleauto
Joined Nov 23, '07
From NJ
QUOTE (cjh4l22 @ Oct 12, 2009 - 11:37 PM) *
We should be able to offer this into November. We have no definite date set yet.
Phone: 201-298-3608
post Oct 13, 2009 - 4:42 AM
upscaleauto
Joined Nov 23, '07
From NJ
These would be great with a swap. The car in the photo has a 5SFE, full exhaust, and HKS filter. The coilover upgrade alone made a world of difference. The difference will be even more significant in a higher powered Celica with a swap. Compared to other brands, the adjustability of these is amazing - 32 levels really is a large range! You can go from super stiff to super soft and anything in between. The stiffness adjustment along with the ride height adjustment and front pillowball camber plates really allows you to dial these coilovers in to the exact setup that will match your performance setup, wheels, body kit, etc. These are definitely worth keeping an eye on for when you finish the swap!
Phone: 201-298-3608
post Oct 13, 2009 - 5:33 AM
whatthe
Joined Aug 13, '08
From Australia
Interested, tho how much do you think shipping will be to Australia?
post Oct 13, 2009 - 10:24 AM
trdproven
Joined Aug 2, '05
From Guam
if this is upscaleauto the company, i bought directly from this company.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 13, 2009 - 11:08 AM
samir0189
Joined Mar 8, '08
From Orlando, Florida
My F/S Thread!
Ferdi says (11:29)
post Oct 13, 2009 - 2:07 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (trdproven @ Oct 13, 2009 - 5:24 AM) *
whats the absolute max drop on these???
post Oct 13, 2009 - 2:09 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Low enough. I think he said he was at 3" or 3.5", you can probably do 4" no problem.
**** Photobucket
post Oct 13, 2009 - 2:14 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
hmmmm......biggrin.gif anyone else in on this??
post Oct 13, 2009 - 3:28 PM
upscaleauto
Joined Nov 23, '07
From NJ
QUOTE (whatthe @ Oct 13, 2009 - 6:33 AM) *
Unfortunately, the box is really large and heavy, so shipping is really expensive in the $200+ range via FedEx. This package is so large that even if you ship USPS, they hand it over to FedEx to finish the job! Please let us know if you are still interested in a quote and we will be glad to get an exact price based on your full address, but we just wanted to provide warning of the cost range first!
QUOTE (trdproven @ Oct 13, 2009 - 11:24 AM) *
QUOTE (samir0189 @ Oct 13, 2009 - 12:08 PM) *
Thanks for the references guys!
Phone: 201-298-3608
post Oct 13, 2009 - 3:35 PM
upscaleauto
Joined Nov 23, '07
From NJ
QUOTE (95CelicaST @ Oct 13, 2009 - 3:09 PM) *
We don't have exact numbers on this, but on the black Celica in the pictures, the drop was probably in the 3" range but could have gone lower if we had smaller diameter wheels/tires. Depending on your drop, you should strongly consider Eibach Pro-Alignment Rear Camber Bolts for 90-99 Toyota Celica GT/ST FWD (exc. All-Trac).
Phone: 201-298-3608
post Oct 13, 2009 - 4:35 PM
TiGZ461
Joined Aug 6, '09
From Bergen County,NJ
Damn looking foward to this, if it goes 3 or lower, I'm sold
1996 Toyota Celica ST 25th Anni. Edition #461
post Oct 13, 2009 - 4:49 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
arghh damn it maybe next month for sure.
post Oct 13, 2009 - 5:01 PM
trdproven
Joined Aug 2, '05
From Guam
with how much adjustability left that I see on the threads, looks to be at least 4 or over inch drop.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 13, 2009 - 5:22 PM
upscaleauto
Joined Nov 23, '07
From NJ
QUOTE (02bluerolla @ Oct 13, 2009 - 5:49 PM) *
We'll see what happens this month and go from there. Right now, there isn't any reason we shouldn't be able to offer this into November.
QUOTE (TiGZ461 @ Oct 13, 2009 - 5:35 PM) *
Not sure what you mean by "3 or lower"? Explain and we'll see what we can do!
Phone: 201-298-3608
post Oct 13, 2009 - 5:28 PM
95CelicaST
Joined Feb 5, '05
He means if it can go 3" drop or lower he's in.
**** Photobucket
Lo-Fi Version Time is now: September 18th, 2026 - 8:39 PM
