Oct 12, 2009 - 10:17 PM
Enthusiast ![]() ![]() Joined Nov 23, '07 From NJ Currently Offline Reputation: 7 (100%) |
![]() ![]() Megan Racing Street Series Coilovers for 94-99 Toyota Celica FWD $850/set with Discount Code! Free Shipping (lower 48 states)! Brand New with Warranty! Simply enter code "6GCMRCDK" during checkout - follow the links below! Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications. The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you're a professional mechanic or an automotive enthusiast with amateur mechanical skills. The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car's handling capabilities. On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street. The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, Megan Racing stands by their product with a strong warranty. Features: Spring Rates: Front 10kg/Rear 8kg 32 Levels of Adjustable Damper Pillow Ball Upper Mounts Rubber Dust Covers Adjustable Ride Height Aggressive Spring Rates Single-Cylinder Design Aluminum Brackets 32 Levels of Adjustment: 1-8: Suggested for track use 9-16: Suggested for mountain/aggressive use 17-32: Suggested for common street use All coilover damper kits come with 1 year manufacture-defect warranty $850/set with Discount Code! Free Shipping (lower 48 states)! Brand New with Warranty! Simply enter code "6GCMRCDK" during checkout - follow the links below! Megan Racing Street Series Coilovers for 94-99 Toyota Celica GT/ST FWD ![]() ![]() This group buy is now open and active to all members. We can accept payment directly via Paypal or through our website checkout. For website checkout, enter code "6GCMRCDK" to receive discount! Megan Racing Street Series Coilovers for 94-99 Toyota Celica GT/ST FWD Megan Racing Street Series Coilovers for 00+ Toyota Celica Megan Racing Street Series Coilovers for 89-93 Toyota Celica All-Trac Megan Racing Street Series Coilovers for 90-93 Toyota Celica GT/GTS FWD Megan Racing Street Series Coilovers for 93-98 Toyota Supra Megan Racing Street Series Coilovers for 00+ Toyota MR2 Spyder Megan Racing Street Series Coilovers for 91-95 Toyota MR2 $850/set with Discount Code! Free Shipping (lower 48 states)! Brand New with Warranty! Simply enter code "6GCMRCDK" during checkout - follow the links above! Note to admins: Coomer has not responded to PM's. If there is another admin who needs to verify/approve this posting, please PM and let us know. ![]() ![]() ![]() ![]() This post has been edited by upscaleauto: Aug 27, 2010 - 7:53 PM --------------------
upscaleauto GB: Megan Racing Coilovers (94-99 Celica)! Oct 12, 2009 - 10:17 PM
cjh4l22 ahh if i were done with my swap i'd grab a set... Oct 12, 2009 - 10:37 PM
upscaleauto QUOTE (cjh4l22 @ Oct 12, 2009 - 11:3... Oct 13, 2009 - 4:33 AM
upscaleauto QUOTE (cjh4l22 @ Oct 12, 2009 - 11:3... Oct 13, 2009 - 4:42 AM
BonzaiCelica how much longer will these deal be going on for?? Oct 13, 2009 - 1:36 AM
808celica did you go through 6gc management to set up a grou... Oct 13, 2009 - 3:35 AM
upscaleauto QUOTE (808celica @ Oct 13, 2009 - 4... Oct 13, 2009 - 4:27 AM
whatthe Interested, tho how much do you think shipping wil... Oct 13, 2009 - 5:33 AM
upscaleauto QUOTE (whatthe @ Oct 13, 2009 - 6:33... Oct 13, 2009 - 3:28 PM
whatthe QUOTE (upscaleauto @ Oct 14, 2009 - 7... Oct 16, 2009 - 7:38 PM
upscaleauto QUOTE (whatthe @ Oct 16, 2009 - 8:38... Oct 16, 2009 - 10:16 PM
trdproven QUOTE (whatthe @ Oct 17, 2009 - 10:3... Oct 18, 2009 - 6:26 AM
whatthe QUOTE (trdproven @ Oct 18, 2009 - 10... Oct 18, 2009 - 7:50 AM
upscaleauto QUOTE (trdproven @ Oct 18, 2009 - 7... Oct 18, 2009 - 1:20 PM
trdproven if this is upscaleauto the company, i bought direc... Oct 13, 2009 - 10:24 AM
808celica QUOTE (trdproven @ Oct 13, 2009 - 5... Oct 13, 2009 - 2:07 PM
samir0189 I purchased my megan springs from upscale auto, gr... Oct 13, 2009 - 11:08 AM
95CelicaST Low enough. I think he said he was at 3" or 3... Oct 13, 2009 - 2:09 PM
upscaleauto QUOTE (95CelicaST @ Oct 13, 2009 - 3... Oct 13, 2009 - 3:35 PM
808celica hmmmm...... anyone else in on this?? Oct 13, 2009 - 2:14 PM
TiGZ461 Damn looking foward to this, if it goes 3 or lower... Oct 13, 2009 - 4:35 PM
02bluerolla arghh damn it maybe next month for sure. Oct 13, 2009 - 4:49 PM
upscaleauto QUOTE (02bluerolla @ Oct 13, 2009 - 5... Oct 13, 2009 - 5:22 PM
trdproven with how much adjustability left that I see on the... Oct 13, 2009 - 5:01 PM
95CelicaST He means if it can go 3" drop or lower he... Oct 13, 2009 - 5:28 PM
upscaleauto QUOTE (95CelicaST @ Oct 13, 2009 - 6... Oct 13, 2009 - 10:23 PM
Stambo Damn, if you guys do another group buy in the spri... Oct 13, 2009 - 8:44 PM
upscaleauto Still need those first 3 to join the GB! Oct 15, 2009 - 4:04 PM
upscaleauto Offer still valid, just waiting on a few members t... Oct 16, 2009 - 2:37 PM
epocsirhc I might have to pick some of these up. Oct 16, 2009 - 11:17 PM
upscaleauto $850/set with Discount Code! Free Shippin... Oct 17, 2009 - 12:34 AM
TiGZ461 If I had the money, I would so be down for this. ... Oct 17, 2009 - 3:05 AM
epocsirhc I'm in, and hopefully two other people! Do... Oct 18, 2009 - 12:55 AM
upscaleauto QUOTE (epocsirhc @ Oct 18, 2009 - 1... Oct 18, 2009 - 1:14 PM
02bluerolla Im in but i will have the money till next month fo... Oct 18, 2009 - 1:12 AM
epocsirhc Un mas por favor Oct 18, 2009 - 1:34 AM
upscaleauto Come on guys, we need one more participant to kick... Oct 22, 2009 - 6:55 PM
upscaleauto To the top! One more person to get this going... Oct 26, 2009 - 3:59 PM
marco-polo if i had that money on hand i would jump on them... Oct 26, 2009 - 10:35 PM
Smaay can i get a set for the ST185 All-Trac at this pri... Oct 29, 2009 - 3:08 PM
upscaleauto QUOTE (Smaay @ Oct 29, 2009 - 4:08 P... Oct 29, 2009 - 4:45 PM
nics are the struts rebuildable? Oct 30, 2009 - 1:01 AM
upscaleauto QUOTE (nics @ Oct 30, 2009 - 2:01 AM... Oct 30, 2009 - 3:27 PM
Stambo Are we sending payments right away or just seeing ... Nov 1, 2009 - 11:15 AM
upscaleauto QUOTE (Stambo @ Nov 1, 2009 - 12:15 ... Nov 1, 2009 - 3:20 PM
epocsirhc I am sorry to do this but you are going to need to... Nov 1, 2009 - 11:00 PM
upscaleauto QUOTE (epocsirhc @ Nov 2, 2009 - 12... Nov 2, 2009 - 12:51 AM
02bluerolla NOOOOOOOOO . Upscaleauto: can you pm the normal... Nov 2, 2009 - 12:03 PM
upscaleauto QUOTE (02bluerolla @ Nov 2, 2009 - 1... Nov 2, 2009 - 5:18 PM
upscaleauto It's November 12th! Take advantage of this... Nov 12, 2009 - 12:10 AM
02bluerolla i ll have the money by next week for sure Nov 12, 2009 - 12:04 PM
upscaleauto QUOTE (02bluerolla @ Nov 12, 2009 - 1... Nov 12, 2009 - 4:28 PM
nics whats the default setting? might be a stupid q but... Nov 15, 2009 - 3:37 AM
Random_Stranger QUOTE (nics @ Nov 15, 2009 - 12:37 A... Nov 15, 2009 - 4:30 AM
808celica QUOTE (Random_Stranger @ Nov 14, 2009 - ... Nov 15, 2009 - 4:55 AM
nics QUOTE (808celica @ Nov 15, 2009 - 1... Nov 15, 2009 - 2:49 PM
trdproven QUOTE (Random_Stranger @ Nov 15, 2009 - ... Nov 15, 2009 - 7:35 PM
Random_Stranger QUOTE (trdproven @ Nov 15, 2009 - 4... Nov 15, 2009 - 7:41 PM
upscaleauto These are complete coilover damper assemblies. Sim... Nov 15, 2009 - 3:34 PM
nics relative to stock ride height, whats the minimum r... Nov 15, 2009 - 3:45 PM
95CelicaST Ride height is adjustable from a couple inches hig... Nov 15, 2009 - 4:51 PM
02bluerolla bump, ordering my coilovers has we speak! Nov 24, 2009 - 1:00 PM
upscaleauto Set to Ship Today! Nov 25, 2009 - 5:07 PM
TiGZ461 Dammit. I've been talking about this for the ... Nov 29, 2009 - 10:36 PM
upscaleauto QUOTE (TiGZ461 @ Nov 29, 2009 - 10:3... Nov 29, 2009 - 11:19 PM
nics will try to make it untill tom! Nov 29, 2009 - 10:48 PM
nics end of december? Nov 30, 2009 - 1:03 AM
TiGZ461 PLEASE make it till the end of Dec. I'm defin... Nov 30, 2009 - 1:07 PM
upscaleauto This is good through the end of December 2009 Nov 30, 2009 - 1:22 PM
TiGZ461 Great .
upscale how much are we talking if you in... Nov 30, 2009 - 1:53 PM
nics ^^good question. out of state ppl dont pay tax for... Nov 30, 2009 - 3:56 PM
upscaleauto Tax only if you are in South Carolina. $850 i... Nov 30, 2009 - 4:10 PM
nics ahh perfect! Nov 30, 2009 - 4:24 PM
TiGZ461 kool. damn I want these real bad guess I'll ju... Nov 30, 2009 - 4:25 PM
epocsirhc I really want these but I have to pay for next sem... Nov 30, 2009 - 11:57 PM
upscaleauto These really are a steal of a deal! Not only w... Dec 1, 2009 - 1:10 AM
02bluerolla i just recieved my coilovers and they look bad as... Dec 1, 2009 - 2:34 PM
upscaleauto QUOTE (02bluerolla @ Dec 1, 2009 - 2... Dec 1, 2009 - 2:54 PM
02bluerolla QUOTE (upscaleauto @ Dec 1, 2009 - 1... Dec 1, 2009 - 4:15 PM
TiGZ461 anyone care to buy a extra set and I'll be hap... Dec 1, 2009 - 5:47 PM
upscaleauto QUOTE (TiGZ461 @ Dec 1, 2009 - 5:47 ... Dec 1, 2009 - 6:00 PM
upscaleauto Not sure how you are planning to pay, but we do ac... Dec 1, 2009 - 6:04 PM
TiGZ461 Sounds great upscale. To be honest with you more ... Dec 3, 2009 - 8:47 PM
upscaleauto Sounds good, if it comes down to making a deposit ... Dec 3, 2009 - 11:31 PM
marco-polo wish i had the money for it, but got to pay for s... Dec 3, 2009 - 11:37 PM
upscaleauto Got some good news from Megan Racing! If we ca... Dec 4, 2009 - 2:34 PM
TiGZ461 I'm in for a deposit, let me know how much I n... Dec 6, 2009 - 12:16 AM
upscaleauto QUOTE (TiGZ461 @ Dec 6, 2009 - 12:16... Dec 7, 2009 - 5:27 PM
Harold_Fastwaker Gonna check my budget and see if I can get these o... Dec 7, 2009 - 5:25 PM
02bluerolla hmmm iam thinking of buying some coilovers for my ... Dec 8, 2009 - 3:21 AM
Harold_Fastwaker Where is the coupon entry at on the site? I went ... Dec 8, 2009 - 10:31 AM
upscaleauto QUOTE (Harold_Fastwaker @ Dec 8, 2009 - ... Dec 8, 2009 - 11:03 AM
Harold_Fastwaker Ah, you guys should move it above the recommended ... Dec 8, 2009 - 4:13 PM
upscaleauto QUOTE (Harold_Fastwaker @ Dec 8, 2009 - ... Dec 8, 2009 - 4:41 PM
Harold_Fastwaker QUOTE (upscaleauto @ Dec 8, 2009 - 4... Dec 8, 2009 - 10:35 PM
upscaleauto QUOTE (Harold_Fastwaker @ Dec 8, 2009 - ... Dec 11, 2009 - 4:40 PM
Harold_Fastwaker QUOTE (upscaleauto @ Dec 11, 2009 - 4... Dec 14, 2009 - 12:49 AM
CelicaST_CALI Ill be down for a set sometime in the middle of 20... Dec 9, 2009 - 2:13 AM
TiGZ461 Bump it up, I'm almost there ! Anyone rec... Dec 13, 2009 - 12:51 PM
kagemidnight Damn I'm in need a of a complete suspension ma... Dec 13, 2009 - 4:20 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 26th, 2026 - 4:17 AM |
