> Gear Ratios
post Jan 12, 2010 - 9:17 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
I was wondering what the purpose of the final drive gear ratio?
also what is this? http://auctions.nengun.com/item/k113042803
- BonzaiCelica   Gear Ratios   Jan 12, 2010 - 9:17 PM
- - Edophus   QUOTE (BonzaiCelica @ Jan 13, 2010 - 2...   Jan 13, 2010 - 5:38 AM
- - BonzaiCelica   thanks edophus. So do you think the gearing for th...   Jan 13, 2010 - 11:17 AM
|- - Edophus   QUOTE (BonzaiCelica @ Jan 13, 2010 - 4...   Jan 13, 2010 - 11:34 AM
- - Mstoochn   the S54 also cruises on the HWY at 3500RPM the RS...   Jan 13, 2010 - 7:50 PM
|- - Edophus   QUOTE (Mstoochn @ Jan 14, 2010 - 12...   Jan 14, 2010 - 5:21 AM
- - pittfirefighter   camry e153 ftw   Jan 13, 2010 - 9:27 PM
- - Mstoochn   best idealistic trans i can think of for an NA 3s/...   Jan 14, 2010 - 5:46 AM
|- - Edophus   QUOTE (Mstoochn @ Jan 14, 2010 - 10...   Jan 14, 2010 - 6:29 AM
- - BonzaiCelica   i just looked up this gear ratio calculator. can a...   Mar 4, 2010 - 7:22 AM
|- - azian_advanced   QUOTE (BonzaiCelica @ Mar 4, 2010 - 6...   Mar 7, 2010 - 9:47 PM
- - BonzaiCelica   anybody ^   Mar 7, 2010 - 5:54 PM
- - Rusty   Im a bit baffled about the e56 being able go have ...   Mar 7, 2010 - 11:59 PM
- - BonzaiCelica   useless and incorrect information....   Sep 6, 2011 - 2:17 AM
- - BonzaiCelica   I got the information from this link : http://www....   Sep 6, 2011 - 8:39 PM
|- - sir_smeghed   Does anyone know if the ring and pinion from the 4...   May 6, 2017 - 9:00 AM
|- - sir_smeghed   PLEASE! Someone..... I have an SW20 with an ...   Jun 9, 2017 - 5:30 AM
|- - slavie   QUOTE (sir_smeghed @ Jun 9, 2017 - 5...   Jun 9, 2017 - 9:49 AM
|- - sir_smeghed   That helps a lot, thanks. Since I left my last po...   Jun 9, 2017 - 10:58 PM
- - azian_advanced   i think you have the general idea.. but just remem...   Sep 6, 2011 - 11:46 PM
- - BonzaiCelica   no I am very well aware of the shorter gears that ...   Sep 7, 2011 - 12:43 AM
|- - Ted95   QUOTE (BonzaiCelica @ Sep 7, 2011 - 1...   Apr 30, 2012 - 10:49 AM
|- - mkernz22   QUOTE (Ted95 @ Apr 30, 2012 - 11:49 ...   Apr 30, 2012 - 11:15 AM
- - BonzaiCelica   someone help me put this to rest... so does the c ...   May 7, 2012 - 11:24 PM
- - BonzaiCelica   ok ok this is the one. BUMP   May 13, 2012 - 1:06 AM
- - BonzaiCelica   Which one of these pieces is the pinion? I know th...   Jul 3, 2012 - 4:31 PM
- - BonzaiCelica   bump!!   Jul 5, 2012 - 3:58 PM
- - rdyzz   sorry to review a dead thread, just try to get mor...   Jan 15, 2013 - 8:41 PM
- - BonzaiCelica   OEM s54 ring count is 71 teeth and pinion is 17 te...   Jan 15, 2013 - 9:32 PM
- - rdyzz   the output shaft gears look smaller than the s54...   Jan 16, 2013 - 4:35 PM
- - BonzaiCelica   Output shaft part numbers : S54 transmission : 3...   Mar 20, 2014 - 9:52 PM
- - mi645   im running e56 i like the trans but the gears r a ...   Mar 21, 2014 - 2:54 AM
- - BonzaiCelica   Final Drive Ring Gear specs : S55F transmission :...   Mar 22, 2014 - 3:04 AM
- - mkernz22   https://partsouq.com/en/catalog/toyota/part......   Mar 26, 2014 - 9:46 PM
- - mkernz22   ooooo, more info. http://www.newcelica.org/forum...   Mar 26, 2014 - 10:08 PM
|- - BonzaiCelica   QUOTE (mkernz22 @ Mar 26, 2014 - 10...   Mar 26, 2014 - 11:06 PM
- - BonzaiCelica   blah, useless info   Mar 10, 2017 - 6:33 PM
- - slavie   So were you ever able to rule out if C56 pinion wo...   Mar 24, 2017 - 10:13 PM
- - BonzaiCelica   it wouldn't work look at the part numbers....   Mar 27, 2017 - 1:03 PM
Lo-Fi Version Time is now: July 29th, 2026 - 3:36 PM
